Functional Safety Support provided for imx8QXP platform
3,585 次查看
Ashil
I was interested in knowing about the safety features provided for the platform IMX8QXP. Is there any specific documents that I can refer to go forward
7 回复数
3,406 次查看
JorgeCas
At the moment there is no available a document/application note to describe this specific enquiry.
I suggest you check the chapter 15.6.2.4.4 "Display Controller Setup" of reference manual.
Best regards.
3,398 次查看
Ashil
If in case the the display driven by imx8 is there a fail safe display available.
I could see that in one of the presentations it was mentioned that if the main display fails. The cortex M4 can provide a 2D graphic display how it works how can I get data
3,321 次查看
JorgeCas
Could you please help me sharing which presentation are you referring for?
Best regards.
3,448 次查看
Ashil
Is there any specific document other than that for reference manual to know about the implementation in linux
3,452 次查看
Ashil
I was looking for for a fail safe feature that is implemented for this in imx8qxp platform
3,452 次查看
Ashil
I was not access these docs but can you guide me which all are the sections that I can refer to for knowing fail safe about display functionality
3,539 次查看
JorgeCas
Hello, I hope you are doing well.
An overall description about this enquiry can be found on reference manual, if you need a deeper description, you should request the security reference manual that provides an overview of the security components of the chip, explaining the purpose and features of them.
Best regards.
