Freemaster || Output File modification
quest123
Hello all,
I'm currently working with MIMXRT1160-EVK evaluation board to control PMSM motor.
I would like to know what's the procedure to add a new variable to the Output File  tab of Freemaster and generate the appconfig.h file ?
I tried to look for material and tried to change a few things in the MCAT/src file, but nothing works.
Any suggestion related to this would be appreciated.
Thanks and best regards,
Chetan
kerryzhou
Hi @quest123 ,
 Do you check the freemaster attached code?
 C:\nxp\FreeMASTER 3.1\FreeMASTER\doc\pcm_um.pdf
This document have the details about the freemaster variable adding.
Please check it at first.
If you still have issues, please kindly let me know, thanks.
kerry
