Fetcher failure for URL: 'http://bugzilla.yoctoproject.org/report.cgi'. URL http://bugzilla.yoctoproject.org/report.cgi doesn't work.
3,007件の閲覧回数
zhangzy
I'm tring to build image based on imx-4.1.15-1.0.0, when I excute $ bitbake fsl-image-gui, below error occurs:
ERROR:  OE-core's config sanity checker detected a potential misconfiguration.
    Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
    Following is the list of potential problems / advisories:
    Fetcher failure for URL: 'http://bugzilla.yoctoproject.org/report.cgi'. URL http://bugzilla.yoctoproject.org/report.cgi doesn't work. Please ensure your network is configured correctly.
network works fine, 'http://bugzilla.yoctoproject.org/report.cgi can be accessed by browser.
git works fine also.
What's the problem ?
ラベル(3)
タグ(1)
1,843件の閲覧回数
joanxie
pls refer to the link as below, hope helpful for you, try to check if you set the environment  correct or not, more detailed information, you can refer to the yocto user guide.
https://community.nxp.com/message/882359
