Failed to fetch URL git://source.codeaurora.org/external/imx/libdrm-imx
Kulasekaran
Hi, I'm facing issues while build Yocto image. I'm using MYD-Y6ULX-V3_L5.4.3. I see you have switched from source.codeaurora.org to git for your repos. But the source code that I have contains many recipes which is still trying to fetch from the old one. Not sure how to fix this. First the issue occurred for optee-os recipe. So, I disabled that and now it is occurring for libdrm recipe. Not sure what the side effect will be if I disable these.  What would you suggest me to find a way around this ? Thanks !
Labels (3)
weidong_sun
Dear @Kulasekaran ,
1. source code for i.mx has been moved to github.
2. the bsp you are using is very old, please select higher version of bsp!
Here is link, the latest bsp is Linux 6.1.55_2.2.0​
https://www.nxp.com/design/design-center/software/embedded-software/i-mx-software/embedded-linux-for...
Thanks!
weidong
