Fail to install RPCBind
1,495件の閲覧回数
charleshuang
Senior Contributor II
I can't successfully install "RPCBind" package with fsl-linaro-toolchain successlly ,
It shows this error message:
   security.c:47:26: fatal error: rpcsvc/mount.h: No such file or directory
The header file is included by rpcbind/src/security.c, I found the similar .x file which have the same name in fsl-linaro-toolchain\arm-fsl-linux-gnueabi\multi-libs\default\usr\include\rpcsvc.
There are other shortage header files that are necessary in security.c,
#include <rpcsvc/mount.h>
#include <rpcsvc/rquota.h>
#include <rpcsvc/nfs_prot.h>
#include <rpcsvc/ypclnt.h>
#include <rpcsvc/yppasswd.h>
How could I generate the .h files from .x files ? or where to get these .h files?
ラベル(2)
0 返答(返信)
