FSL_imx_demo/ethernet BUG
1,385 次查看
lifusong
Dear sir.
  step 1. open fsl_ethernet app,click Check Ethernet button,and see the net connect mode is dhcp mode and ip is A
  step 2. click Configure Ethernet and set net connect to static IP mode.and click confirm
  step 3. through Browser access http://ip/ip.php to show the client (android os) ip is the manual set ip,it is different with A.
  step 4. through fsl_ethernet app set net connect to dhcp mode. and click the fsl_ethernet app button check Ethernet to see the ip address change to ip A.
  step 5. access http://ip/ip.php ,and see the client ip is still manual ip.
why?
append file is the ip.php source code.
Original Attachment has been moved to: ip.php.zip
标签 (2)
1,199 次查看
lifusong
Dear Freescale office'sir.
  help please.
1,199 次查看
lifusong
Dear All.
help please.
