FRDM-MX95 5 sai?
FRDM-MX95 5 sai?
817 次查看
FlynHawaiian
I am wondering if it’s possible to enable all 5 of the SAI channels on the frdm or what the limitation is on the FRDM-MX95.  I’m also wondering how you configure them.  I plan to use Android automotive as the OS or Yocto, just unsure which yet.
标签 (2)
727 次查看
FlynHawaiian
so basically sai3 is the only possible for full functionality?
Is there a gui program where I can see the device tree and modify what each gpio I would want to be?
Would it be possible to set it to TDM mode, and send the audio to an analog devices adsp-21594, and let it handle the audio inputs from other devices and the main output?
Do you know what the audio output is from the sai3 tdm stream? Is it 32/768?
734 次查看
Zhiming_Liu
Hi @FlynHawaiian
SAI1-5 can be connected to the following pads
SAI1:
I2C2_SCL / I2C2_SDA
UART2_RXD
SAI1_TXFS / SAI1_TXC / SAI1_TXD0 / SAI1_RXD0
SAI2: IMX95_PAD_ENET2_XXX/IMX95_PAD_XSPI1_XXX
SAI3:
GPIO_IO12
GPIO_IO16 ~ GPIO_IO21
GPIO_IO26
SAI4:
ENET2_TD[2:0]
ENET2_RXC
ENET2_RD[1:0]
XSPI1_DATA[3:0]
XSPI1_SCLK
XSPI1_SS0_B
SAI5:
SD3_CLK / SD3_CMD / SD3_DATA[3:0]
XSPI1_DATA[7:4]
XSPI1_DQS
XSPI1_SS1_B
Next, let’s look at the device tree configuration in FRDM(arch/arm64/boot/dts/freescale/imx95-15x15-frdm.dts).
SAI Module Can it be fully muxed out currently? Main Reason
SAI1 No, only partially Some SAI1 PADs are occupied by lpi2c2 and mqs1
SAI2 Basically no The main PAD group ENET2_* is occupied by Ethernet and MDIO
SAI3 Yes, recommended The related GPIO_IO PADs are not occupied in the current DTS
SAI4 No, only partially The main PAD group ENET2_* is occupied by Ethernet, and some XSPI1 PADs are also occupied by GPIO functions
SAI5 No, only partially SD3_* is occupied by usdhc3 / WiFi SDIO, and some XSPI1 PADs are also occupied
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-2362769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-MX95%205%20sai%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2362769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%AF%E8%83%BD%E5%9C%A8%20FRDM%20%E4%B8%8A%E5%90%AF%E7%94%A8%E6%89%80%E6%9C%89%205%20%E4%B8%AA%20SAI%20%E9%A2%91%E9%81%93%EF%BC%8C%E6%88%96%E8%80%85%20FRDM-MX95%20%E6%9C%89%E4%BB%80%E4%B9%88%E9%99%90%E5%88%B6%E3%80%82%20%20%E6%88%91%E8%BF%98%E6%83%B3%E7%9F%A5%E9%81%93%E4%BD%A0%E6%98%AF%E5%A6%82%E4%BD%95%E9%85%8D%E7%BD%AE%E5%AE%83%E4%BB%AC%E7%9A%84%E3%80%82%20%20%E6%88%91%E8%AE%A1%E5%88%92%E4%BD%BF%E7%94%A8%20Android%20automotive%20%E6%88%96%20Yocto%20%E4%BD%9C%E4%B8%BA%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%EF%BC%8C%E5%8F%AA%E6%98%AF%E8%BF%98%E4%B8%8D%E7%A1%AE%E5%AE%9A%E4%BD%BF%E7%94%A8%E5%93%AA%E4%B8%80%E7%A7%8D%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2362769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E5%A4%9A%E5%AA%92%E4%BD%93%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2363631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MX95%205%20sai%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2363631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F261393%22%20target%3D%22_blank%22%3E%40FlynHawaiian%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3ESAI1-5%20%E5%8F%AF%E4%BB%A5%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%BB%A5%E4%B8%8B%E7%84%8A%E7%9B%98%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ESAI1%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3Ei2c2_scl%20%2F%20i2c2_sda%3CBR%20%2F%3Euart2_rxd%3CBR%20%2F%3Esai1_txfs%20%2F%20sai1_txc%20%2F%20sai1_txd0%20%2F%20sai1_rxd0%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ESAI2%3A%3C%2FSTRONG%3EIMX95_PAD_ENET2_XXX%2FIMX95_PAD_XSPI1_XXX%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ESAI3%EF%BC%9A%20%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3EGPIO_IO12%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3Egpio_io16%20~%20gpio_io21%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3EGPIO_IO26%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ESAI4%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3EENET2_TD%5B2%3A0%5D%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3EENET2_RXC%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3EENET2_RD%5B1%3A0%5D%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3Exspi1_data%5B3%3A0%5D%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3EXSPI1_SCLK%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3EXSPI1_SS0_B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ESAI5%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3Esd3_clk%20%2F%20sd3_cmd%20%2F%20sd3_data%5B3%3A0%5D%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3Exspi1_data%5B7%3A4%5D%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3EXSPI1_DQS%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3EXSPI1_SS1_B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%8E%A5%E4%B8%8B%E6%9D%A5%EF%BC%8C%E8%AE%A9%E6%88%91%E4%BB%AC%E7%9C%8B%E7%9C%8B%20FRDM%20%E4%B8%AD%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%E9%85%8D%E7%BD%AE%EF%BC%88arch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx95-15x15-frdm.dts%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%0A%3CTABLE%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTH%20width%3D%2270.1625px%22%20height%3D%2296px%22%3ESAI%E6%A8%A1%E5%9D%97%3C%2FTH%3E%0A%3CTH%20width%3D%22189.438px%22%20height%3D%2296px%22%3E%E7%9B%AE%E5%89%8D%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%85%B6%E5%AE%8C%E5%85%A8%E5%A4%8D%E7%94%A8%EF%BC%9F%3C%2FTH%3E%0A%3CTH%20width%3D%22478.8px%22%20height%3D%2296px%22%3E%E4%B8%BB%E8%A6%81%E5%8E%9F%E5%9B%A0%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTH%20scope%3D%22row%22%20width%3D%2270.1625px%22%20height%3D%2252px%22%3E%3CSTRONG%3ESAI1%3C%2FSTRONG%3E%3C%2FTH%3E%0A%3CTD%20width%3D%22189.438px%22%20height%3D%2252px%22%3E%E4%B8%8D%EF%BC%8C%E5%8F%AA%E6%98%AF%E9%83%A8%E5%88%86%3C%2FTD%3E%0A%3CTD%20width%3D%22478.8px%22%20height%3D%2252px%22%3E%E4%B8%80%E4%BA%9B%20SAI1%20PAD%20%E8%A2%AB%3CCODE%20translate%3D%22no%22%3Elpi2c2%3C%2FCODE%3E%20%E5%92%8C%20%3CCODE%20translate%3D%22no%22%3Emqs1%3C%2FCODE%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTH%20scope%3D%22row%22%20width%3D%2270.1625px%22%20height%3D%2252px%22%3E%3CSTRONG%3ESAI2%3C%2FSTRONG%3E%3C%2FTH%3E%0A%3CTD%20width%3D%22189.438px%22%20height%3D%2252px%22%3E%E5%9F%BA%E6%9C%AC%E4%B8%8A%E6%B2%A1%E6%9C%89%3C%2FTD%3E%0A%3CTD%20width%3D%22478.8px%22%20height%3D%2252px%22%3E%E4%B8%BB%20PAD%20%E7%BB%84%3CCODE%20translate%3D%22no%22%3EENET2_*%3C%2FCODE%3E%20%E7%94%B1%E4%BB%A5%E5%A4%AA%E7%BD%91%E5%92%8C%20MDIO%20%E5%8D%A0%E7%94%A8%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTH%20scope%3D%22row%22%20width%3D%2270.1625px%22%20height%3D%2252px%22%3E%3CSTRONG%3ESAI3%3C%2FSTRONG%3E%3C%2FTH%3E%0A%3CTD%20width%3D%22189.438px%22%20height%3D%2252px%22%3E%E6%98%AF%EF%BC%8C%E6%8E%A8%E8%8D%90%3C%2FTD%3E%0A%3CTD%20width%3D%22478.8px%22%20height%3D%2252px%22%3E%E5%9C%A8%E5%BD%93%E5%89%8D%E7%9A%84%20DTS%20%E4%B8%AD%EF%BC%8C%E7%9B%B8%E5%85%B3%E7%9A%84%3CCODE%20translate%3D%22no%22%3EGPIO_IO%3C%2FCODE%3E%20PAD%20%E6%9C%AA%E8%A2%AB%E5%8D%A0%E7%94%A8%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTH%20scope%3D%22row%22%20width%3D%2270.1625px%22%20height%3D%2252px%22%3E%3CSTRONG%3ESAI4%3C%2FSTRONG%3E%3C%2FTH%3E%0A%3CTD%20width%3D%22189.438px%22%20height%3D%2252px%22%3E%E4%B8%8D%EF%BC%8C%E5%8F%AA%E6%98%AF%E9%83%A8%E5%88%86%3C%2FTD%3E%0A%3CTD%20width%3D%22478.8px%22%20height%3D%2252px%22%3E%E4%B8%BB%20PAD%20%E7%BB%84%3CCODE%20translate%3D%22no%22%3EENET2_*%3C%2FCODE%3E%20%E8%A2%AB%E4%BB%A5%E5%A4%AA%E7%BD%91%E5%8D%A0%E7%94%A8%EF%BC%8C%E4%B8%80%E4%BA%9B%3CCODE%20translate%3D%22no%22%3EXSPI1%3C%2FCODE%3E%20PAD%20%E4%B9%9F%E8%A2%AB%20GPIO%20%E5%8A%9F%E8%83%BD%E5%8D%A0%E7%94%A8%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTH%20scope%3D%22row%22%20width%3D%2270.1625px%22%20height%3D%2252px%22%3E%3CSTRONG%3ESAI5%3C%2FSTRONG%3E%3C%2FTH%3E%0A%3CTD%20width%3D%22189.438px%22%20height%3D%2252px%22%3E%E4%B8%8D%EF%BC%8C%E5%8F%AA%E6%98%AF%E9%83%A8%E5%88%86%3C%2FTD%3E%0A%3CTD%20width%3D%22478.8px%22%20height%3D%2252px%22%3E%3CCODE%20translate%3D%22no%22%3ESD3_*%3C%2FCODE%3E%20%3CCODE%20translate%3D%22no%22%3Eusdhc3%3C%2FCODE%3E%20%2F%20WiFi%20SDIO%20%E5%8D%A0%E7%94%A8%EF%BC%8C%E4%B8%80%E4%BA%9B%3CCODE%20translate%3D%22no%22%3EXSPI1%3C%2FCODE%3E%20PAD%20%E4%B9%9F%E8%A2%AB%E5%8D%A0%E7%94%A8%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3C%2FDIV%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2363714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MX95%205%20sai%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2363714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%82%A3%E4%B9%88%EF%BC%8C%E5%9F%BA%E6%9C%AC%E4%B8%8A%E5%8F%AA%E6%9C%89%20Sai3%20%E6%89%8D%E8%83%BD%E5%AE%9E%E7%8E%B0%E5%85%A8%E9%83%A8%E5%8A%9F%E8%83%BD%EF%BC%9F%20%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E4%B8%80%E4%B8%AA%20gui%20%E7%A8%8B%E5%BA%8F%E5%8F%AF%E4%BB%A5%E8%AE%A9%E6%88%91%E7%9C%8B%E5%88%B0%E8%AE%BE%E5%A4%87%E6%A0%91%E5%B9%B6%E4%BF%AE%E6%94%B9%E6%88%91%E6%83%B3%E8%A6%81%E7%9A%84%E6%AF%8F%E4%B8%AA%20gpio%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%85%B6%E8%AE%BE%E7%BD%AE%E4%B8%BA%20TDM%20%E6%A8%A1%E5%BC%8F%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%86%E9%9F%B3%E9%A2%91%E5%8F%91%E9%80%81%E5%88%B0%E6%A8%A1%E6%8B%9F%E8%AE%BE%E5%A4%87%E7%9A%84%20adsp-%3CSPAN%3E21594%EF%BC%8C%E7%84%B6%E5%90%8E%E8%AE%A9%E5%AE%83%E5%A4%84%E7%90%86%E6%9D%A5%E8%87%AA%E5%85%B6%E4%BB%96%E8%AE%BE%E5%A4%87%E7%9A%84%E9%9F%B3%E9%A2%91%E8%BE%93%E5%85%A5%E5%92%8C%E4%B8%BB%3C%2FSPAN%3E%E8%BE%93%E5%87%BA%EF%BC%9F%3C%2FP%3E%3CP%3E%E4%BD%A0%E7%9F%A5%E9%81%93%20sai3%20tdm%20%E6%95%B0%E6%8D%AE%E6%B5%81%E7%9A%84%E9%9F%B3%E9%A2%91%E8%BE%93%E5%87%BA%E6%98%AF%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%E6%98%AF%2032%2F768%20%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
