FRDM-IMX93 not recognizing RPI-CAM-MIPI
ソリューションへジャンプ
2,488件の閲覧回数
jventura
Hi, i´m trying to make RPI-CAM-MIPI work with the FRDM-IMX93 board.
I followed the user manual for the board:
https://docs.nxp.com/bundle/UM12181/page/topics/camera_module_rpi_cam_mipi.html
I connected the camera as instructed.
I got the ap1302_60fps_ar0144_27M_2Lane_awb_tuning.bin from ONSEMI github (https://github.com/ONSemiconductor/ap1302_binaries/tree/main/NXP_i.MX93), renamed it and put it in the board:
root@imx93-11x11-lpddr4x-frdm:~# ls /lib/firmware/imx/camera/
ap1302.fw
I rebooted the camera, but the log wasn´t the same as in the manual:
root@imx93-11x11-lpddr4x-frdm:~# dmesg | grep ap1302
[ 0.341004] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.371040] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 0.411142] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.433309] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.464010] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 0.476107] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.495817] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 2.093316] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 2.104580] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
and the camera doesn´t seem to appear:
root@imx93-11x11-lpddr4x-frdm:~# media-ctl -p
Failed to enumerate /dev/media0 (-2)
root@imx93-11x11-lpddr4x-frdm:~# v4l2-ctl --list-devices
mxc-isi-cap (platform:4ae40000.isi):
/dev/video0
/dev/video1
root@imx93-11x11-lpddr4x-frdm:~# i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- UU -- -- UU -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
I've rechecked everything. I'm stuck. Any ideas what i should try?
2,360件の閲覧回数
Zhiming_Liu
Hi @jventura
ap1302_60fps_ar0144_27M_2Lane_awb_tuning.bin is correct one.  Please try below suggestion from reference manual
A firmware named ap1302_ar0144_single_fw.bin is needed. Put it under the /lib/firmware folder.
Zhiming
8 返答(返信)
2,428件の閲覧回数
jventura
I´ve attached the photos, but i also checked continuity with a multimeter and it´s ok, the pins on the FRDM are reaching the CAM ones...
2,432件の閲覧回数
jventura
Here it is
2,432件の閲覧回数
jventura
From the other side 
2,419件の閲覧回数
Zhiming_Liu
Hi @jventura
Your connection is wrong, the blue side should be the same as the camera side.
Zhiming
2,410件の閲覧回数
jventura
thanks @Zhiming_Liu
I checked it so many times, and every time i missed.
Anyways, it got better but it seems I still have a problem with the .fw:
[ 0.340881] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.370918] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 0.411017] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.433185] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.463890] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 0.475987] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 0.495704] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 2.098808] /soc@0/bus@42800000/csi@4ae00000: Fixed dependency cycle(s) with /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c
[ 2.110107] /soc@0/bus@42000000/i2c@42530000/ap1302_mipi@3c: Fixed dependency cycle(s) with /soc@0/bus@42800000/csi@4ae00000
[ 10.757527] ap1302 2-003c: Direct firmware load for ap1302_ar0144_single_fw.bin failed with error -2
[ 10.757549] ap1302 2-003c: Falling back to sysfs fallback for: ap1302_ar0144_single_fw.bin
[ 10.770396] ap1302 2-003c: Failed to request firmware: -2
[ 10.818467] ap1302 2-003c: probe with driver ap1302 failed with error -2
ap1302.fw
Is the ap1302_60fps_ar0144_27M_2Lane_awb_tuning.bin from ONSEMI github (https://github.com/ONSemiconductor/ap1302_binaries/tree/main/NXP_i.MX93) the correct one?
2,360件の閲覧回数
Zhiming_Liu
Hi @jventura
Zhiming
2,170件の閲覧回数
jventura
thanks Zhiming, it worked!
The Gopoint DMS demo doesn´t see it though... I think it may be something with the media pipeline, I´ll look into that.
2,454件の閲覧回数
Zhiming_Liu
Hi @jventura
Can you share the photo to show the connection between RPI-CAM-MIPI and FRDM93?
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-2379079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-IMX93%E3%81%8CRPI-CAM-MIPI%E3%82%92%E8%AA%8D%E8%AD%98%E3%81%97%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81RPI-CAM-MIPI%E3%82%92FRDM-IMX93%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUM12181%2Fpage%2Ftopics%2Fcamera_module_rpi_cam_mipi.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUM12181%2Fpage%2Ftopics%2Fcamera_module_rpi_cam_mipi.html%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%8C%87%E7%A4%BA%E9%80%9A%E3%82%8A%E3%81%AB%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EONSEMI%E3%81%AEgithub%EF%BC%88%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FONSemiconductor%2Fap1302_binaries%2Ftree%2Fmain%2FNXP_i.MX93%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FONSemiconductor%2Fap1302_binaries%2Ftree%2Fmain%2FNXP_i.MX93%3C%2FA%3E%20%EF%BC%89%E3%81%8B%E3%82%89ap1302_60fps_ar0144_27M_2Lane_awb_tuning.bin%E3%82%92%E5%85%A5%E6%89%8B%E3%81%97%E3%80%81%E5%90%8D%E5%89%8D%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20ls%20%2Flib%2Ffirmware%2Fimx%2Fcamera%2F%3CBR%20%2F%3E%20ap1302.fw%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%AD%E3%82%B0%E3%81%AF%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%AF%E7%95%B0%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20dmesg%20%7C%20grep%20ap1302%3CBR%20%2F%3E%20%5B%200.341004%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.371040%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.411142%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.433309%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.464010%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.476107%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.495817%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%202.093316%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%202.104580%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20media-ctl%20-p%3CBR%20%2F%3E%20%2Fdev%2Fmedia0%20%E3%81%AE%E5%88%97%E6%8C%99%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(-2)%3CBR%20%2F%3E%20root%40imx93-11x11-lpddr4x-frdm%3A~%23%20v4l2-ctl%20--list-devices%3CBR%20%2F%3E%20mxc-isi-cap%20(%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%3A4ae40000.isi)%3A%3CBR%20%2F%3E%2Fdev%2Fvideo0%3CBR%20%2F%3E%20%2Fdev%2Fvideo1%3C%2FP%3E%3CP%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20i2cdetect%20-y%201%3CBR%20%2F%3E%200%201%202%203%204%205%206%207%208%209%20abcdef%3CBR%20%2F%3E%2000%3A%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E%2010%3A%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E%2020%3A%20--%20--%20%E3%81%86%E3%81%86%20--%20--%20%E3%81%86%E3%81%86%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E%2030%3A%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E%2040%3A%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E%2050%3A%2050%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E%2060%3A%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E%2070%3A%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E%20%3CA%20href%3D%22mailto%3Aroot%40imx93-11x11-lpddr4x-frdm%3A~%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A1%8C%E3%81%8D%E8%A9%B0%E3%81%BE%E3%81%A3%E3%81%A6%E3%81%97%E3%81%BE%E3%81%A3%E3%81%9F%E3%80%82%E4%BD%95%E3%81%8B%E8%A9%A6%E3%81%99%E3%81%B9%E3%81%8D%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263294%22%20target%3D%22_blank%22%3E%40jventura%E3%81%95%E3%82%93%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3E%E6%8E%A5%E7%B6%9A%E6%96%B9%E6%B3%95%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E9%9D%92%E8%89%B2%E3%81%AE%E9%9D%A2%E3%81%AF%E3%82%AB%E3%83%A1%E3%83%A9%E5%81%B4%E3%81%A8%E5%90%8C%E3%81%98%E5%90%91%E3%81%8D%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F388629i75417AA223BC31DB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhiming_Liu_0-1781136494125.png%22%20alt%3D%22Zhiming_Liu_0-1781136494125.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%86%99%E7%9C%9F%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%A7%E5%B0%8E%E9%80%9A%E3%82%82%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81FRDM%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AFCAM%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AB%E5%B1%8A%E3%81%84%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22RPICAMConectionBack.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConectionBack.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConectionBack.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConectionBack.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConectionBack.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F388595i78F0E83F0556BC55%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22RPICAMConectionBack.png%22%20alt%3D%22RPICAMConectionBack.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%8F%8D%E5%AF%BE%E5%81%B4%E3%81%8B%E3%82%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22RPICAMConection.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConection.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConection.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConection.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RPICAMConection.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F388594iBD7AA6D9459743E6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22RPICAMConection.png%22%20alt%3D%22RPICAMConection.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263294%22%20target%3D%22_blank%22%3E%40jventura%E3%81%95%E3%82%93%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3ERPI-CAM-MIPI%E3%81%A8FRDM93%E3%81%AE%E6%8E%A5%E7%B6%9A%E7%8A%B6%E6%85%8B%E3%82%92%E7%A4%BA%E3%81%99%E5%86%99%E7%9C%9F%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2380076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2380076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%3CLI-EMOJI%20id%3D%22lia_grinning-face-with-smiling-eyes%22%20title%3D%22%3Agrinning_face_with_smiling_eyes%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%95%E5%BA%A6%E3%82%82%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%91%E3%81%A9%E3%80%81%E6%AF%8E%E5%9B%9E%E8%A6%8B%E8%90%BD%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E3%80%81%E7%8A%B6%E6%B3%81%E3%81%AF%E6%94%B9%E5%96%84%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81.fw%20%E3%81%AB%E3%81%BE%E3%81%A0%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20dmesg%20%7C%20grep%20ap1302%3CBR%20%2F%3E%20%5B%200.340881%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.370918%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.411017%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.433185%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.463890%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.475987%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.495704%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%202.098808%5D%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%3A%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%202.110107%5D%20%2Fsoc%400%2Fbus%4042000000%2Fi2c%4042530000%2Fap1302_mipi%403c%3A%20%2Fsoc%400%2Fbus%4042800000%2Fcsi%404ae00000%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%2010.757527%5D%20ap1302%202-003c%3A%20ap1302_ar0144_single_fw.bin%20%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E7%9B%B4%E6%8E%A5%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-2%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%2010.757549%5D%20ap1302%202-003c%3A%20ap1302_ar0144_single_fw.bin%20%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%20sysfs%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%2010.770396%5D%20ap1302%202-003c%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%A6%81%E6%B1%82%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20-2%3CBR%20%2F%3E%20%5B%2010.818467%5D%20ap1302%202-003c%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20ap1302%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-2%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%20media-ctl%20-p%3CBR%20%2F%3E%20%2Fdev%2Fmedia0%20%E3%81%AE%E5%88%97%E6%8C%99%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(-2)%3CBR%20%2F%3E%20%3CA%20href%3D%22mailto%3Aroot%40imx93-11x11-lpddr4x-frdm%3A~%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eroot%40imx93-11x11-lpddr4x-frdm%3A~%23%3C%2FA%3E%3CBR%20%2F%3E%20root%40imx93-11x11-lpddr4x-frdm%3A~%23%20ls%20%2Flib%2Ffirmware%2Fimx%2Fcamera%2F%3CBR%20%2F%3E%20ap1302.fw%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EONSEMI%E3%81%AEgithub%EF%BC%88%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FONSemiconductor%2Fap1302_binaries%2Ftree%2Fmain%2FNXP_i.MX93%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20https%3A%2F%2Fgithub.com%2FONSemiconductor%2Fap1302_binaries%2Ftree%2Fmain%2FNXP_i.MX93%3C%2FA%3E%3CSPAN%3E%20%EF%BC%89%20%E3%81%AB%E3%81%82%E3%82%8Bap1302_60fps_ar0144_27M_2Lane_awb_tuning.bin%E3%81%AF%20%E6%AD%A3%E3%81%97%E3%81%84%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2380488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2380488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263294%22%20target%3D%22_blank%22%3E%40jventura%E3%81%95%E3%82%93%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3Eap1302_60fps_ar0144_27M_2Lane_awb_tuning.bin%20%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FRM00293%2Fpage%2Ftopics%2Far0144.html%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%3C%2FA%3E%E3%81%AE%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%8F%90%E6%A1%88%E3%82%92%E3%81%8A%E8%A9%A6%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CCODE%20class%3D%22ph%20codeph%22%3Eap1302_ar0144_single_fw.bin%3C%2FCODE%3E%3CSPAN%3E%20%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FSPAN%3E%3CSPAN%3E%20%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%3C%2FSPAN%3E%3CCODE%20class%3D%22ph%20codeph%22%3E%20%2Flib%2Ffirmware%3C%2FCODE%3E%3CSPAN%3E%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2381436%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-IMX93%20not%20recognizing%20RPI-CAM-MIPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2381436%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E5%BF%97%E6%98%8E%EF%BC%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%A3%E3%81%9F%E3%82%88%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3EGopoint%20DMS%E3%81%AE%E3%83%87%E3%83%A2%E3%81%A7%E3%81%AF%E8%AA%8D%E8%AD%98%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E2%80%A6%E3%80%82%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E9%85%8D%E4%BF%A1%E3%81%AE%E7%B5%8C%E8%B7%AF%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E8%AA%BF%E3%81%B9%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-BODY%3E
