Ethernet PHY
Ethernet PHY
1,470件の閲覧回数
saida
hi
i am designed a custom i.mx6 based board with atheros PHY(ref is Sabre SD board)
Ehternet link is not established (auto negotiation is not working properly)
some times link is establishing and transmitting with missing packets
when i do restart it is not establishing the link
what could be the problem ?
is any pcb guide lines should i follow ?
thanks and regards
saida
1,383件の閲覧回数
Hi Saida
one can check rgmii timings with oscilloscope using
Table 58. RGMII Signal Switching Specifications i.MX6Q Satasheet
https://www.nxp.com/docs/en/data-sheet/IMX6DQCEC.pdf
and hardware requirements described in Hardware Guide
https://www.nxp.com/webapp/Download?colCode=IMX6DQ6SDLHDG
