Error while Integrating Chromium browser
dhanyahc
Hello
I hope, I am posting question to right group. If not please let me know whom to approach.
Here is my issue in brief
I am trying to integrate chromium browser to my Yocto build using open embedded recipe from meta-browser layer, but my build fails with following error message
The recipe imx-gpu-viv is trying to install files into a shared area when those files already exist. Those files and their manifest location are:…….few file names
(please refer attached log.txt file). I am not understating why error appears and how can I fix.
Attached also my local.conf file and BB layer file.
Could you please me to guide me to fix this issue.
Additional details about build
Image : core-image-sato (X11)
Processor – iMX6 from NXP
Board : form Phytec
Original Attachment has been moved to: bblayers.conf.zip
Original Attachment has been moved to: log.txt.zip
Original Attachment has been moved to: local.conf.zip
Labels (2)
Tags (2)
gusarambula
Hello Dhanyakumar Hosamane,
It seems like there may be a conflict in the dependencies between the BSP you are using and the meta-browser layer. The priginal phyFLEX BSP most likely already has OpenGL support and it’s conflicting with the OpenGL support on the meta-browser layer. You may try forcing a PREFFERED_VERSION for the conflicting packages on the local.conf file.
I’m not familiar with phyFLEX boards or BSP but perhaps phyTEC may have information on their documentation.
