Error while Compute OTFAD KEK value for mx93
794件の閲覧回数
pilotnite
Support,
Trying to generate OTFAD KEK value but getting error with 'fuses'. Following exact command as stated in the documentation:
nxpimage otfad get-kek [OPTIONS]
Options
-m, --otp-master-key <otp_master_key>
OTP MASTER KEY in hexadecimal format or file name to binary or text file with key.
-k, --otfad-key <otfad_key>
OTFAD KEY (OTFAD KEK seed) in hexadecimal format or file name to binary or text file with key.
-f, --family <family>
Optional family, if specified, the tool generates the BLHOST scripts to load key fuses. To use this feature, the ‘-o’ options has to be also defined!
Options:
mx93 | rt1010 | rt116x | rt117x | rt118x | rt5xx | rt6xx
-o, --output <output>
Optional result output folder (otfad_kek.bin/txt, optionally BLHOST scripts to load keys into Fuses)
When executed:
nxpimage otfad get-kek --otp-master-key 3dbc924eb2db87da8f6e27a8c9e88966c840efc1d335a7037c9556d215880076 --otfad-key 740058eead98392c92383408b477aa29 -f mx93 -o otfad_kek_output
OTP MASTER KEY: 3dbc924eb2db87da8f6e27a8c9e88966c840efc1d335a7037c9556d215880076
OTFAD KEY:      740058eead98392c92383408b477aa29
OTFAD KEK:      07a4d5a1cabe56b254fdd91881b2045e
ERROR:SPSDK: Unavailable item 'fuses' in feature 'otfad'
Can you please advise?
タグ(1)
0 返答(返信)
