Error programming a Node 2 I/MX6 board with MFG tool
jbnl
Goodday
I have here a Bluesound Node 2 where the firmware is corrupted.
I have the MFG tool and all the firmware but when i start the tool and the unit is starting the OS image a get a red line in the MFG tool and a error.
I have attached the log file, can i recover this board on a other way ? Or is it a hardware fault ?
I can upload Uboot with USB but how can i proceed further ?
Hi jbnl
one can try to follow sect.4.4.1 Downloading images using U-Boot Linux Guide
  i.MX Linux User’s Guide​
Since this is third party design may be recommended to apply to is vendor support
https://support1.bluesound.com/hc/en-us
