Error no elements found while building Android 10 OS for imx8mm
2,862 次查看
Ruban1
i have attached screenshot
[ 63% 68894/108660] AAPT2 compile out/target/common/obj/APPS/CactusPlayer_intermediates/flat-res/vendor/nxp/imx_android_mm/CactusPlayer/res/drawable_icn_media_play_pressed_holo_dark.png.flat <- vendor/nxp/imx_android_mm/CactusPlayer/res/drawable/icn_media_play_pressed_holo_dark.png
[ 63% 68895/108660] AAPT2 compile out/target/common/obj/APPS/CactusPlayer_intermediates/flat-res/vendor/nxp/imx_android_mm/CactusPlayer/res/drawable_progress.xml.flat <- vendor/nxp/imx_android_mm/CactusPlayer/res/drawable/progress.xml
FAILED: out/target/common/obj/APPS/CactusPlayer_intermediates/flat-res/vendor/nxp/imx_android_mm/CactusPlayer/res/drawable_progress.xml.flat
/bin/bash -c "out/host/linux-x86/bin/aapt2 compile -o out/target/common/obj/APPS/CactusPlayer_intermediates/flat-res/vendor/nxp/imx_android_mm/CactusPlayer/res/ --pseudo-localize --legacy vendor/nxp/imx_android_mm/CactusPlayer/res/drawable/progress.xml"
vendor/nxp/imx_android_mm/CactusPlayer/res/drawable/progress.xml:1: error: no element found.
vendor/nxp/imx_android_mm/CactusPlayer/res/drawable/progress.xml: error: file failed to compile.
[ 63% 68896/108660] AAPT2 compile out/target/common/obj/APPS/CactusPlayer_intermediates/flat-res/vendor/nxp/imx_android_mm/CactusPlayer/res/drawable_pause.png.flat <- vendor/nxp/imx_android_mm/CactusPlayer/res/drawable/pause.png
[ 63% 68897/108660] AAPT2 compile out/target/common/obj/APPS/CactusPlayer_intermediates/flat-res/vendor/nxp/imx_android_mm/CactusPlayer/res/drawable_play.png.flat <- vendor/nxp/imx_android_mm/CactusPlayer/res/drawable/play.png
[ 63% 68898/108660] AAPT2 compile out/target/common/obj/APPS/CactusPlayer_intermediates/flat-res/vendor/nxp/imx_android_mm/CactusPlayer/res/drawable_readme.txt.flat <- vendor/nxp/imx_android_mm/CactusPlayer/res/drawable/readme.txt
ninja: build stopped: subcommand failed.
13:49:38 ninja failed with: exit status 1
#### failed to build some targets (01:38:02 (hh:mm:ss)) ####
标签 (1)
3 回复数
2,856 次查看
Hi Ruban
for that issue one can try to rebuild all image from scratch using Android User Guide included in
Documentation​
2,852 次查看
Ruban1
I modified many files. So after building Once again i have to find every file and modify again
2,854 次查看
Ruban1
It takes almost 3 days .OK I will Do.
