Error could not find aidl/activity
5,858件の閲覧回数
Grigoriy
I'm trying to build custom AAOS 14 based on nxp code. I extended CarSystemUI and flashed our board. When I tried to boot it booting stuck on bootanimation screen. And I looping this logs:
[ 2105.344347][ T6738] servicemanager: Caller(pid=6552,uid=1041,sid=u:r:audioserver:s0) Tried to start aidl service activity as a lazy service, but was unable to. Usually this happens when a service is not installed, but if the service is intended to be used as a lazy service, then it may be configured incorrectly.
[ 2106.332379][  T221] servicemanager: Caller(pid=6552,uid=1041,sid=u:r:audioserver:s0) Since 'activity' could not be found trying to start it as a lazy AIDL service. (if it's not configured to be a lazy service, it may be stuck starting or still starting).
[ 2106.360997][    T1] init: Control message: Could not find 'aidl/activity' for ctl.interface_start from pid: 221 (/system/bin/servicemanager)
[ 2106.375408][ T6739] servicemanager: Caller(pid=6552,uid=1041,sid=u:r:audioserver:s0) Tried to start aidl service activity as a lazy service, but was unable to. Usually this happens when a service is not installed, but if the service is intended to be used as a lazy service, then it may be configured incorrectly.
4 返答(返信)
5,782件の閲覧回数
Grigoriy
Any advice or help please?
5,504件の閲覧回数
Maruti
Hii @Grigoriy
Have you found a solution for this issue? It would be really helpful if you could share the details.
タグ(2)
5,850件の閲覧回数
Bio_TICFSL
The "Could not find 'aidl/activity'" error in Android development likely indicates that the build system cannot locate an AIDL file named activity within the aidl directory structure. This usually means the AIDL file or the directory structure is missing or incorrectly configured. To resolve this, ensure the AIDL file (e.g., activity.aidl) exists in the correct location and that the build system is configured to recognize AIDL files.
Here's a breakdown of the potential issues and how to fix them:
1. Missing or Misplaced AIDL File:
  • Check the file: Verify that an activity.aidl file exists.
  • Check the directory: Ensure the activity.aidl file is placed within the src/main/aidl directory of your Android project, or the appropriate source set if you're using custom source sets.
  • Package structure: The AIDL file's package declaration (e.g., package com.example.app.aidl;) must match the directory structure where it's located. If the file is in src/main/aidl/com/example/app/, the package declaration should be package com.example.app.aidl;.
2. Build System Configuration (Android Gradle Plugin):
  • Enable AIDL: Make sure the aidl build feature is enabled in your app/build.gradle file.
Código
    android {        buildFeatures {            aidl true        }    }
  • Source sets: If you are using custom source sets, you might need to specify the source directory for AIDL files in the sourceSets block.
Código
    android {        sourceSets {            main {                aidl {                    srcDirs 'src/main/aidl'                }            }        }    }
3. Clean and Rebuild:
  • After making changes to the AIDL file or build configuration, clean and rebuild your project to ensure the changes are applied.
    • In Android Studio, go to Build > Clean Project and then Build > Rebuild Project.
  • . Incremental Build (Android Studio):
    Android Studio's incremental build usually handles AIDL files efficiently, but if you encounter issues, try a full rebuild.
5. Stable AIDL:
  • If you're working with stable AIDL, ensure that all dependencies of your AIDL interface are also defined as stable AIDL.
  • Convert any parcelables to stable parcelables by defining their structure directly in AIDL files.
Example:
Let's say you have an AIDL interface called IMyInterface and you want to use it in your activity.
  1. Create IMyInterface.aidl:
Código
    // IMyInterface.aidl    package com.example.app.aidl;    interface IMyInterface {        void doSomething();    }
  1. Place it in src/main/aidl/com/example/app/:
Código
    my_app/    ├── src/    │   └── main/    │       ├── aidl/    │       │   └── com/    │       │       └── example/    │       │           └── app/    │       │               └── IMyInterface.aidl
  1. Enable AIDL in app/build.gradle:
  1.
Código
  1. Clean and Rebuild.
  1.
By following these steps, you should be able to resolve the "Could not find 'aidl/activity'" error and successfully use your AIDL interface in your Android project.
reegards
5,811件の閲覧回数
Grigoriy
Hi @Bio_TICFSL
Thank you for your respond. Here is what I found:
1) I tried to find `activity.aidl` in all AAOS folders and it doesn't exist.
2) In our code we don't use any `.aidl`
3) I tried to find in all AAOS code the call of `aidl/activity` by `grep` and there is no such a call.
4) The default CarSystemUI is working fine and we extended it without changing anything in the base code.
%3CLINGO-SUB%20id%3D%22lingo-sub-2121500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81aidl%2Factivity%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2121500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Enxp%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20AAOS%2014%20%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82CarSystemUI%20%E3%82%92%E6%8B%A1%E5%BC%B5%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%B5%B7%E5%8B%95%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%A2%E3%83%8B%E3%83%A1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E7%94%BB%E9%9D%A2%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%92%E3%83%AB%E3%83%BC%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5B%202105.344347%5D%5B%20T6738%5D%20servicemanager%3A%20Caller(pid%3D6552%2Cuid%3D1041%2Csid%3Du%3Ar%3Aaudioserver%3As0)%20Tried%20to%20start%20aidl%20service%20activity%20as%20a%20lazy%20service%2C%20but%20was%20unable%20to.%20Usually%20this%20happens%20when%20a%20service%20is%20not%20installed%2C%20but%20if%20the%20service%20is%20intended%20to%20be%20used%20as%20a%20lazy%20service%2C%20then%20it%20may%20be%20configured%20incorrectly.%0A%5B%202106.332379%5D%5B%20%20T221%5D%20servicemanager%3A%20Caller(pid%3D6552%2Cuid%3D1041%2Csid%3Du%3Ar%3Aaudioserver%3As0)%20Since%20'activity'%20could%20not%20be%20found%20trying%20to%20start%20it%20as%20a%20lazy%20AIDL%20service.%20(if%20it's%20not%20configured%20to%20be%20a%20lazy%20service%2C%20it%20may%20be%20stuck%20starting%20or%20still%20starting).%0A%5B%202106.360997%5D%5B%20%20%20%20T1%5D%20init%3A%20Control%20message%3A%20Could%20not%20find%20'aidl%2Factivity'%20for%20ctl.interface_start%20from%20pid%3A%20221%20(%2Fsystem%2Fbin%2Fservicemanager)%0A%5B%202106.375408%5D%5B%20T6739%5D%20servicemanager%3A%20Caller(pid%3D6552%2Cuid%3D1041%2Csid%3Du%3Ar%3Aaudioserver%3As0)%20Tried%20to%20start%20aidl%20service%20activity%20as%20a%20lazy%20service%2C%20but%20was%20unable%20to.%20Usually%20this%20happens%20when%20a%20service%20is%20not%20installed%2C%20but%20if%20the%20service%20is%20intended%20to%20be%20used%20as%20a%20lazy%20service%2C%20then%20it%20may%20be%20configured%20incorrectly.%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2147285%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Error%20could%20not%20find%20aidl%2Factivity%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147285%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248457%22%20target%3D%22_blank%22%3E%40Grigoriy%3C%2FA%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E8%A9%B3%E7%B4%B0%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E5%A4%A7%E5%A4%89%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2126387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Error%20could%20not%20find%20aidl%2Factivity%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2126387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%95%E3%81%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%84%E5%8A%A9%E3%81%91%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2123187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Error%20could%20not%20find%20aidl%2Factivity%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2123187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%20target%3D%22_blank%22%3E%40Bio_TICFSL%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E3%82%82%E3%81%AE%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CP%3E1)%3CSPAN%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20AAOS%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%81%A7%20%60activity.aidl%60%20%E3%82%92%E6%8E%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E2)%20%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%60.aidl%60%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E3)%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20AAOS%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%20%60aidl%2Factivity%60%20%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%82%92%20%60grep%60%20%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E4)%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%20CarSystemUI%20%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%95%E3%82%82%E5%A4%89%E6%9B%B4%E3%81%9B%E3%81%9A%E3%81%AB%E6%8B%A1%E5%BC%B5%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2121587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Error%20could%20not%20find%20aidl%2Factivity%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2121587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%22%20data-hveid%3D%22CAMQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQo_EKegQIAxAB%22%3E%3CSPAN%20data-huuid%3D%227073323573472920590%22%3EAndroid%E9%96%8B%E7%99%BA%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E3%80%8C'aidl%2Factivity'%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%3CCODE%20class%3D%22mv6bHd%22%3E%20aidl%3C%2FCODE%3E%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E6%A7%8B%E9%80%A0%E5%86%85%E3%81%A7%3CCODE%20class%3D%22mv6bHd%22%3E%20activity%20%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AEAIDL%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%89%E3%82%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FCODE%3E%3C%2FSPAN%3E%3CSPAN%20data-huuid%3D%227073323573472921267%22%3E%20%E3%81%93%E3%82%8C%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81AIDL%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E6%A7%8B%E9%80%A0%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%80%81%E6%AD%A3%E3%81%97%E3%81%8F%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20data-huuid%3D%227073323573472921944%22%3E%20%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81AIDL%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%88%E4%BE%8B%EF%BC%9A%3CCODE%20class%3D%22mv6bHd%22%3E%20activity.aidl%3C%2FCODE%3E%20%EF%BC%89%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E5%A0%B4%E6%89%80%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%93%E3%83%AB%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8CAIDL%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%8D%E8%AD%98%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%2225bc03ee-e82e-4c00-a017-9dd9bf006b50%22%20data-ih%3D%22%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%2225bc03ee-e82e-4c00-a017-9dd9bf006b50%22%20data-uuids%3D%227073323573472920590%2C7073323573472921267%2C7073323573472921944%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20fCrZyc%20LwdV0e%20FR7ZSc%20qVhvac%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CAUQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQ3fYKegQIBRAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%0A%3CDIV%20class%3D%22kHtcsd%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%22%20data-hveid%3D%22CAMQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQo_EKegQIAxAB%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%22%20data-hveid%3D%22CAoQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQo_EKegQIChAB%22%3E%3CSPAN%20data-huuid%3D%221325860628163946508%22%3E%E6%BD%9C%E5%9C%A8%E7%9A%84%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%A8%E3%81%9D%E3%81%AE%E8%A7%A3%E6%B1%BA%E6%96%B9%E6%B3%95%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20pyPiTc%22%20data-hveid%3D%22CAsQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQo_EKegQICxAB%22%3E%3CSPAN%20data-huuid%3D%221325860628163947426%22%3E1.%20AIDL%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%8B%E3%80%81%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E5%A0%B4%E6%89%80%E3%81%AB%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%3A%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CUL%20data-hveid%3D%22CBgQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQm_YKegQIGBAB%22%3E%0A%3CLI%3E%3CSPAN%20data-huuid%3D%221325860628163944707%22%3E%3CSTRONG%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20data-huuid%3D%221325860628163945166%22%3E%3CCODE%20class%3D%22mv6bHd%22%3Eactivity.aidl%3C%2FCODE%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20data-huuid%3D%221325860628163946084%22%3E%3CSTRONG%3E%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20data-huuid%3D%221325860628163946543%22%3E%3CCODE%20class%3D%22mv6bHd%22%3Eactivity.aidl%3C%2FCODE%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%20Android%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%3CCODE%20class%3D%22mv6bHd%22%3Esrc%2Fmain%2Faidl%3C%2FCODE%3E%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%86%85%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%80%81%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E9%81%A9%E5%88%87%E3%81%AA%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%82%BB%E3%83%83%E3%83%88%E5%86%85%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20data-huuid%3D%221325860628163947461%22%3E%3CSTRONG%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E6%A7%8B%E9%80%A0%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20data-huuid%3D%221325860628163947920%22%3EAIDL%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E5%AE%A3%E8%A8%80%EF%BC%88%E4%BE%8B%3A%20%3CCODE%20class%3D%22mv6bHd%22%3Epackage%20com.example.app.aidl%3B%3C%2FCODE%3E%20%EF%BC%89%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E6%A7%8B%E9%80%A0%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20data-huuid%3D%221325860628163948379%22%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%3CCODE%20class%3D%22mv6bHd%22%3Esrc%2Fmain%2Faidl%2Fcom%2Fexample%2Fapp%2F%3C%2FCODE%3E%E3%81%AB%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E5%AE%A3%E8%A8%80%E3%81%AF%3CCODE%20class%3D%22mv6bHd%22%3Epackage%20com.example.app.aidl%3B%3C%2FCODE%3E%E3%81%A8%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%2204001c57-9b21-4767-8165-2a3cd69eb592%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%2204001c57-9b21-4767-8165-2a3cd69eb592%22%20data-uuids%3D%221325860628163944707%2C1325860628163945166%2C1325860628163946084%2C1325860628163946543%2C1325860628163947461%2C1325860628163947920%2C1325860628163948379%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20fCrZyc%20LwdV0e%20FR7ZSc%20qVhvac%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CBMQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQ3fYKegQIExAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%0A%3CDIV%20class%3D%22kHtcsd%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20pyPiTc%22%20data-hveid%3D%22CB4QAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQo_EKegQIHhAB%22%3E%3CSPAN%20data-huuid%3D%225424812522083853793%22%3E2.%20%E3%83%93%E3%83%AB%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E6%A7%8B%E6%88%90%EF%BC%88Android%20Gradle%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%EF%BC%89%3A%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CUL%20data-hveid%3D%22CB8QAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQm_YKegQIHxAB%22%3E%0A%3CLI%3E%3CSPAN%20data-huuid%3D%225424812522083854690%22%3E%3CSTRONG%3EAIDL%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20data-huuid%3D%225424812522083854989%22%3E%3CCODE%20class%3D%22mv6bHd%22%3E%20app%2Fbuild.gradle%3C%2FCODE%3E%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%3CCODE%20class%3D%22mv6bHd%22%3E%20aidl%3C%2FCODE%3E%20%E3%83%93%E3%83%AB%E3%83%89%E6%A9%9F%E8%83%BD%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%2263121e9b-6675-45c6-bcd8-b2c61127c823%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22ecCNFc%22%3E%0A%3CDIV%20class%3D%22zYSUYd%22%3E%0A%3CDIV%20class%3D%22FS7GEb%22%3E%0A%3CDIV%20class%3D%22dDrxod%22%3E%0A%3CDIV%20class%3D%22x7ndcb%22%3E%3CSPAN%3E%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WDoJJe%22%20aria-live%3D%22polite%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22ecCNFc%22%3E%0A%3CDIV%20class%3D%22QQjpRc%22%3E%0A%3CDIV%20class%3D%22FS7GEb%22%3E%0A%3CPRE%20translate%3D%22no%22%3E%3CCODE%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQjZIMegQIKRAC%22%3E%3CSPAN%3E%20%20%20%20android%20%7B%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%20%20%20%20buildFeatures%20%7B%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20aidl%20true%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%7D%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%7D%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CUL%20data-hveid%3D%22CC8QAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQm_YKegQILxAB%22%3E%0A%3CLI%3E%3CSPAN%20data-huuid%3D%221325860628163945660%22%3E%3CSTRONG%3E%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%82%BB%E3%83%83%E3%83%88%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20data-huuid%3D%221325860628163946119%22%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%20%3CCODE%20class%3D%22mv6bHd%22%3EsourceSets%3C%2FCODE%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%20AIDL%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%2275935f2b-d20f-4468-bbbb-2775a7700390%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22ecCNFc%22%3E%0A%3CDIV%20class%3D%22zYSUYd%22%3E%0A%3CDIV%20class%3D%22FS7GEb%22%3E%0A%3CDIV%20class%3D%22dDrxod%22%3E%0A%3CDIV%20class%3D%22x7ndcb%22%3E%3CSPAN%3E%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WDoJJe%22%20aria-live%3D%22polite%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22ecCNFc%22%3E%0A%3CDIV%20class%3D%22QQjpRc%22%3E%0A%3CDIV%20class%3D%22FS7GEb%22%3E%0A%3CPRE%20translate%3D%22no%22%3E%3CCODE%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQjZIMegQIMRAC%22%3E%3CSPAN%3E%20%20%20%20android%20%7B%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%20%20%20%20sourceSets%20%7B%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20main%20%7B%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20aidl%20%7B%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20srcDirs%20'src%2Fmain%2Faidl'%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%7D%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%7D%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%7D%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20pyPiTc%22%20data-hveid%3D%22CDQQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQo_EKegQINBAB%22%3E%3CSPAN%20data-huuid%3D%2214770295032130245268%22%3E3.%20%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%A8%E5%86%8D%E6%A7%8B%E7%AF%89%3A%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CUL%20data-hveid%3D%22CDsQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQm_YKegQIOxAB%22%3E%0A%3CLI%3E%3CSPAN%20data-huuid%3D%2214770295032130245415%22%3EAIDL%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%E3%81%AB%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%9F%E5%BE%8C%E3%81%AF%E3%80%81%E5%A4%89%E6%9B%B4%E3%81%8C%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%83%AA%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%0A%3CUL%20data-hveid%3D%22CDgQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQm_YKegQIOBAB%22%3E%0A%3CLI%3E%3CSPAN%20data-huuid%3D%2214770295032130245562%22%3EAndroid%20Studio%20%E3%81%A7%E3%80%81%20%3CCODE%20class%3D%22mv6bHd%22%3EBuild%20%26gt%3B%20Clean%20Project%3C%2FCODE%3E%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%20%3CCODE%20class%3D%22mv6bHd%22%3EBuild%20%26gt%3B%20Rebuild%20Project%3C%2FCODE%3E%20%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%22e4f9da92-8690-4a04-9a60-c38ad5e571e1%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%22e4f9da92-8690-4a04-9a60-c38ad5e571e1%22%20data-uuids%3D%2214770295032130245415%2C14770295032130245562%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20fCrZyc%20LwdV0e%20FR7ZSc%20qVhvac%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CDcQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQ3fYKegQINxAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%0A%3CDIV%20class%3D%22kHtcsd%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CUL%20data-hveid%3D%22CDsQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQm_YKegQIOxAB%22%3E%0A%3CLI%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20pyPiTc%22%20data-hveid%3D%22CEIQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQo_EKegQIQhAB%22%3E%3CSPAN%20data-huuid%3D%2215306875794382665563%22%3E.%20%E5%A2%97%E5%88%86%E3%83%93%E3%83%AB%E3%83%89%EF%BC%88Android%20Studio%EF%BC%89%3A%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CSPAN%20data-huuid%3D%2215306875794382666116%22%3EAndroid%20Studio%20%E3%81%AE%E5%A2%97%E5%88%86%E3%83%93%E3%83%AB%E3%83%89%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81AIDL%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8A%B9%E7%8E%87%E7%9A%84%E3%81%AB%E5%87%A6%E7%90%86%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E5%AE%8C%E5%85%A8%E3%81%AA%E5%86%8D%E6%A7%8B%E7%AF%89%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%22b6695c8e-dba7-4b69-9881-a4eea7fccfb9%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%22b6695c8e-dba7-4b69-9881-a4eea7fccfb9%22%20data-uuids%3D%2215306875794382666116%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20fCrZyc%20LwdV0e%20FR7ZSc%20qVhvac%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CEQQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQ3fYKegQIRBAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%0A%3CDIV%20class%3D%22kHtcsd%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20pyPiTc%22%20data-hveid%3D%22CEoQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQo_EKegQIShAB%22%3E%3CSPAN%20data-huuid%3D%2214514545086911771585%22%3E5.%20%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%9FAIDL%3A%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CUL%20data-hveid%3D%22CE4QAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQm_YKegQIThAB%22%3E%0A%3CLI%3E%3CSPAN%20data-huuid%3D%2214514545086911772456%22%3E%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%9F%20AIDL%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81AIDL%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%82%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%9F%20AIDL%20%E3%81%A8%E3%81%97%E3%81%A6%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20data-huuid%3D%2214514545086911774402%22%3EAIDL%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%A7%8B%E9%80%A0%E3%82%92%E7%9B%B4%E6%8E%A5%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%A6%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%20Parcelable%20%E3%82%92%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%9F%20Parcelable%20%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%2271c00e61-e7dc-4bac-bafd-20645877a73a%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20pyPiTc%22%20data-hveid%3D%22CFgQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQo_EKegQIWBAB%22%3E%3CSPAN%20data-huuid%3D%227073323573472921808%22%3E%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20pyPiTc%22%20data-hveid%3D%22CFgQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQo_EKegQIWBAB%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20uP58nb%20MNX06c%22%20data-hveid%3D%22CFYQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQo_EKegQIVhAB%22%3E%3CSPAN%20data-huuid%3D%227073323573472923162%22%3E%3CSPAN%20aria-level%3D%222%22%3E%3CCODE%20class%3D%22mv6bHd%22%3EIMyInterface%3C%2FCODE%3E%E3%81%A8%E3%81%84%E3%81%86%20AIDL%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20uP58nb%20MNX06c%22%20data-hveid%3D%22CFYQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQo_EKegQIVhAB%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3COL%20data-hveid%3D%22CFkQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQnPYKegQIWRAB%22%3E%0A%3CLI%20value%3D%221%22%3E%3CSPAN%20data-huuid%3D%227073323573472921097%22%3E%3CCODE%20class%3D%22mv6bHd%22%3EIMyInterface.aidl%3C%2FCODE%3E%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3A%20%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22ecCNFc%22%3E%0A%3CDIV%20class%3D%22zYSUYd%22%3E%0A%3CDIV%20class%3D%22FS7GEb%22%3E%0A%3CDIV%20class%3D%22dDrxod%22%3E%0A%3CDIV%20class%3D%22x7ndcb%22%3E%3CSPAN%3E%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WDoJJe%22%20aria-live%3D%22polite%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22ecCNFc%22%3E%0A%3CDIV%20class%3D%22QQjpRc%22%3E%0A%3CDIV%20class%3D%22FS7GEb%22%3E%0A%3CPRE%20translate%3D%22no%22%3E%3CCODE%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQjZIMegQIXxAC%22%3E%20%20%20%20%3CSPAN%20class%3D%22a7yfkb%22%3E%2F%2F%20IMyInterface.aidl%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%20%20%20%20%3CSPAN%20class%3D%22VSzkzc%22%3Epackage%3C%2FSPAN%3E%3CSPAN%3E%20com.example.app.aidl%3B%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%20%20%20%20%3CSPAN%20class%3D%22VSzkzc%22%3Einterface%3C%2FSPAN%3E%3CSPAN%3E%20IMyInterface%20%7B%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22VSzkzc%22%3Evoid%3C%2FSPAN%3E%3CSPAN%3E%20doSomething()%3B%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%7D%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%3E%0A%3COL%20data-hveid%3D%22CGMQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQnPYKegQIYxAB%22%3E%0A%3CLI%20value%3D%221%22%3E%3CSPAN%20data-huuid%3D%2215592279729642680484%22%3E%3CCODE%20class%3D%22mv6bHd%22%3Esrc%2Fmain%2Faidl%2Fcom%2Fexample%2Fapp%2F%3C%2FCODE%3E%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%221b03ad84-b4c4-41b8-8c65-0d0d30687fbb%22%20data-uuids%3D%2215592279729642680484%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20fCrZyc%20LwdV0e%20FR7ZSc%20qVhvac%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CGEQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQ3fYKegQIYRAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%0A%3CDIV%20class%3D%22kHtcsd%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22ecCNFc%22%3E%0A%3CDIV%20class%3D%22zYSUYd%22%3E%0A%3CDIV%20class%3D%22FS7GEb%22%3E%0A%3CDIV%20class%3D%22dDrxod%22%3E%0A%3CDIV%20class%3D%22x7ndcb%22%3E%3CSPAN%3E%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WDoJJe%22%20aria-live%3D%22polite%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22ecCNFc%22%3E%0A%3CDIV%20class%3D%22QQjpRc%22%3E%0A%3CDIV%20class%3D%22FS7GEb%22%3E%0A%3CPRE%20translate%3D%22no%22%3E%3CCODE%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQjZIMegQIZxAC%22%3E%3CSPAN%3E%20%20%20%20my_app%2F%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%E2%94%9C%E2%94%80%E2%94%80%20src%2F%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%E2%94%82%20%20%20%E2%94%94%E2%94%80%E2%94%80%20main%2F%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%E2%94%9C%E2%94%80%E2%94%80%20aidl%2F%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%E2%94%82%20%20%20%E2%94%94%E2%94%80%E2%94%80%20com%2F%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%E2%94%94%E2%94%80%E2%94%80%20example%2F%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%20%20%20%20%E2%94%94%E2%94%80%E2%94%80%20app%2F%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E2%94%94%E2%94%80%E2%94%80%20IMyInterface.aidl%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%3E%0A%3COL%20data-hveid%3D%22CGkQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQnPYKegQIaRAB%22%3E%0A%3CLI%20value%3D%221%22%3E%3CSPAN%20data-huuid%3D%224734075391785567107%22%3E%3CCODE%20class%3D%22mv6bHd%22%3Eapp%2Fbuild.gradle%3C%2FCODE%3E%E3%81%A7%20AIDL%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%226cc7bece-06b9-4325-85ae-23873ce9807d%22%20data-ih%3D%22%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%226cc7bece-06b9-4325-85ae-23873ce9807d%22%20data-uuids%3D%224734075391785567107%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20fCrZyc%20LwdV0e%20FR7ZSc%20qVhvac%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CGoQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQ3fYKegQIahAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%0A%3CDIV%20class%3D%22kHtcsd%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%3E%0A%3COL%20data-hveid%3D%22CGkQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQnPYKegQIaRAB%22%3E%0A%3CLI%20value%3D%221%22%3E%26nbsp%3B%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22ecCNFc%22%3E%0A%3CDIV%20class%3D%22zYSUYd%22%3E%0A%3CDIV%20class%3D%22FS7GEb%22%3E%0A%3CDIV%20class%3D%22dDrxod%22%3E%0A%3CDIV%20class%3D%22x7ndcb%22%3E%3CSPAN%3E%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WDoJJe%22%20aria-live%3D%22polite%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22ecCNFc%22%3E%0A%3CDIV%20class%3D%22QQjpRc%22%3E%0A%3CDIV%20class%3D%22FS7GEb%22%3E%0A%3CPRE%20translate%3D%22no%22%3E%3CCODE%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQjZIMegQIbRAC%22%3E%3CSPAN%3E%20%20%20%20android%20%7B%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%20%20%20%20buildFeatures%20%7B%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20aidl%20true%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%7D%3C%2FSPAN%3E%3CBR%20aria-hidden%3D%22true%22%20%2F%3E%3CSPAN%3E%20%20%20%20%7D%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%3E%0A%3COL%20data-hveid%3D%22CG8QAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQnPYKegQIbxAB%22%3E%0A%3CLI%20value%3D%221%22%3E%3CSPAN%20data-huuid%3D%2210243939098318170308%22%3E%3CSTRONG%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%22fd702000-b9e3-444c-9319-83e527befa2a%22%20data-ih%3D%22%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%22fd702000-b9e3-444c-9319-83e527befa2a%22%20data-uuids%3D%2210243939098318170308%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20fCrZyc%20LwdV0e%20FR7ZSc%20qVhvac%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CHAQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQ3fYKegQIcBAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%0A%3CDIV%20class%3D%22kHtcsd%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%3E%0A%3COL%20data-hveid%3D%22CG8QAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQnPYKegQIbxAB%22%3E%0A%3CLI%20value%3D%221%22%3E%26nbsp%3B%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%3E%0A%3CDIV%20class%3D%22rPeykc%22%20data-hveid%3D%22CHYQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQo_EKegQIdhAB%22%3E%3CSPAN%20data-huuid%3D%223527624410120248109%22%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%80%8C'aidl%2Factivity'%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%80%81Android%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%20AIDL%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%220529ac40-f3b2-4064-8167-dd815d54a13c%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%220529ac40-f3b2-4064-8167-dd815d54a13c%22%20data-uuids%3D%223527624410120248109%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20fCrZyc%20LwdV0e%20FR7ZSc%20qVhvac%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CHkQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQ3fYKegQIeRAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%0A%3CDIV%20class%3D%22kHtcsd%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22rPeykc%22%20data-hveid%3D%22CHYQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQo_EKegQIdhAB%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22rPeykc%22%20data-hveid%3D%22CHYQAQ%22%20data-ved%3D%222ahUKEwjN0tHJi4iOAxU1JNAFHf2MATcQo_EKegQIdhAB%22%3E%3CSPAN%20data-huuid%3D%223527624410120248109%22%3E%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%220529ac40-f3b2-4064-8167-dd815d54a13c%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
