Error compiling gst-plugins-good
javiervalcarce
Hi all.
I'm trying to compile gst-plugins-good package but i get the following error.
cairo_overlay.c:27:19: fatal error: cairo.h: No such file or directory
Can anyone help me?
I have read gst-fsl-plugins build failed
I have tried to comment "export lines" at *.spec file but the result is the same.
make -C v4l2
make -C cairo
make[4]: Entering directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/rtp'
make[4]: Entering directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/cairo'
  CC     cairo_overlay-cairo_overlay.o
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/rtp'
make[4]: Entering directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/shapewipe'
make[4]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/shapewipe'
make[4]: Entering directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/equalizer'
make[4]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/equalizer'
make[4]: Entering directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/v4l2'
make[4]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/v4l2'
make[4]: Entering directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/spectrum'
make[4]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/spectrum'
compilation terminated.
make[4]: *** [cairo_overlay-cairo_overlay.o] Error 1
make[4]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/cairo'
make[3]: *** [cairo] Error 2
make[3]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30'
make: *** [all] Error 2
error: Bad exit status from /home/javier/ltib/tmp/rpm-tmp.47999 (%build)
RPM build errors:
Build time for gst-plugins-good: 19 seconds
Failed building gst-plugins-good
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Tue Sep  3 17:00:13 2013
Ended:   Tue Sep  3 17:00:35 2013
Elapsed: 22 seconds
These packages failed to build:
gst-plugins-good
Build Failed
Exiting on error or interrupt
LeonardoSandova
Specialist I
Hi Javier,
this is a known issue. Please remove the related rpm/BUILD folder and try again.
Leo
javiervalcarce
Hi Leonardo.
Thanks for your quick answer. I have removed rpm/BUILD/gst-plugins-good-0.10.30 but nothing changes. Is there any workaround?
YixingKong
Senior Contributor IV
Javier
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
YixingKong
Javier
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel
free to reply with an update to this discussion.
Yixing
LeonardoSandova
Specialist I
Pretty strange. IF you commented/removed the cairo lines on the .spec, then I have no idea what is going on. Can you try installing LTIB again? This time select GNOME profile a do not do any spec changes. I think you wont have problems with this profile because cairo package is already selected.
Leo
muthuswamydiksh
Hi Leonardo,
I am running into exactly the same problem.
I am using BSP 4.0.0 for SabreAuto with Ubuntu 12.04.
Here are the steps i followed:
1. https://community.freescale.com/docs/DOC-93455
2. commented the three lines:
          #export CAIRO_CFLAGS=-I/home/ashish/Desktop/dev_imx6/ltib/rootfs/usr/include/cairo
          #export CAIRO_LIBS=-L/home/ashish/Desktop/dev_imx6/ltib/rootfs/usr/lib/cairo
          #export LIBS=-lcairo
3. Removed rpm/BUILD and built again.
4. Tried a new LTIB installation. I mean I ran the ./install and made a new ltib.
It did not help.
Can you please help ?
Do you have any pointers ?
LeonardoSandova
Specialist I
Do not execute step 4, otherwise you will remove your spec changes (step 2).
