Enabling and using Ethernet port on Android 2.2 on EVK
1,662 次查看
RafaelG_Lopez
Has anyone tried enabling Ethernet port on EVX51 running Android? I have not been able to find a WiFi adapter for the EVK, and I need to give it web access. Can anyone suggest a way to give the EVK51 access to the web, whether using a WiFi adapter, a USB wireless adapter, or the Ethernet port available on the EVK? Thank you all!
标记 (2)
1,579 次查看
daiane_angolini
what android version are you using?
What´s your board?
Mike Petersen said:
Did you ever get this going?    What was the resolution?
1,578 次查看
mbp
Contributor V
