Enabling LPI2C4 in IMX93EVK
1,076件の閲覧回数
Robbi
Hi team,
                I'm working with i.mx93 EVK kit. I tried to connect external I2C based sensor to J1001 connector on EVK kit. Hence I modified dts files
  1. GPIO_IO02_LPI2C4_SDA
  2. GPIO_IO03_LPI2C4_SCL
    are the ALT modes of GPIO2.
    I created a node and
    assigned pins. but in the board i2c3 is not populated i.e lpi2c4.
 Please guide me at which step I need to modify.
Robbi
2 返答(返信)
1,052件の閲覧回数
danielchen
Hi @Robbi
I tried this in my side with your settings. it can work on my side.
1,014件の閲覧回数
Robbi
Thanks @danielchen ,
     Got it, I had done changes in tmp/work/arch/arm/boot but changes need to be done in tmp/work/arch/arm64/boot path dts file.
Robbi
