Is there a way to toggle the USB VBUS only on demand? My current design switches on the VBUS on Kernel-startup, but it does not turn it off when nothing is connected. The port is configured as host, the gpio1_14 corresponds to the USB2_PWR_EN-Pin. I tried to use the ID-Pin for toggling, only to have no voltage at all on the port.
What's your design for the USB2? Could you share us the schematic of this section?
