Driver for AR0521 (MIPI)
mirkoardinghi1
I need to write a driver for the CMOS AR0521 (ON Semicondutor) for i.MX 8M Mini.
Is there some draft/example of similar drivers from where to start?
Thanks in advance.
jamesko
Has anyone succeeded by adding the AR0521 driver to I.mx8mq?
I want help.
Thank you in advance.
Bio_TICFSL
Hello Mirko,
We have the Linux BSP where MIPI CSI-2 low-level interface for managing the mipi D-PHY register and clock, if you like to have similar we have the MIPI CSI-2 common API for communication between MIPI sensor and MIPI DPHY.  And we have the MIPI Camera Serial Interface.
