Download IMX6SDLRM Revision3
ソリューションへジャンプ
3,288件の閲覧回数
K_Steinhammer
Can someone tell me where to get IMX6SDLRM Revision3?
I have Revision 2 and Revision 4 and need to know the change history.
The history section in Revision 4 only describes the changes from Revision 3 to Revision 4 but not the changes from Revision 2 to Revision 3...
ラベル(2)
3,094件の閲覧回数
gusarambula
Hello Klaus Steinhammer,
You can find Revision 3 of this document attached. I’m apologize for the trouble of tracking down changes as there is not a centralized change log to know what changed from revision to revision.
I hope this helps!
3,095件の閲覧回数
gusarambula
I hope this helps!
