Does the iMX6 Solox SDK include the PCIe protocol stack for Endpoint?
1,832 次查看
infantjesurajfr
I will be using the iMX6 Solox processor in my design which will be a PCIe endpoint system.
标记 (2)
2 回复数
1,644 次查看
Bharath_R
Hello James,
I am using IMX6 Dual lite processor, can I use SDK for PCIe test.
if yes, can i get test procedure.
Thanks and Regards,
Bharath R
1,748 次查看
jamesbone
Hello Infant,
Nop, the PCIe Module it is not available in the SDK,  you can try using the Linux BSP provided by NXP, that includes the PCIe  Endpoint Core,.
TIC
