Does IMX8MM support Proxy Application with Cortex-M4?
nxbg
Hi, We want to use IMX8MM Cortex-A53 running Linux and Cortex-M4 for realtime application, does it support Proxy Application with Cortex-M4?
Proxy Application means Cortex-M4 can use read/write file on the Linux master file system, is that possible for IMX8MM?
Thanks & Best Regards
