Display video using clutter
1,396 次查看
barish_malshika
We have custom
i.MX 8M Mini board on which the two 480x320 TFT display is interfaced using MIPI DSI.
We can display the video using gstreamer using the following command from the terminal:
gst-launch-1.0 filesrc location=video.mp4 ! video/quicktime ! qtdemux ! queue ! vpudec ! queue ! waylandsink sync=false window-width=320 window-height=480
We want to display the video using the application and the requirement is that we have to use a clutter library. We have found from (
https://wiki.gnome.org/Projects/Clutter) that the clutter-gst can be used to display the video using the gstreamer.
Please provide a reference to the following things
1) Integrate the clutter and clutter-gst in yocto build.
2) Simple application recipe to display video using the clutter API.
1 回复
1,388 次查看
Hi barish_malshika
one can try to follow below links:
https://packages.debian.org/jessie/gstreamer1.0-clutter
https://boundarydevices.com/wiki/debian-for-nitrogen8/
