Display rotation
Display rotation
3,013件の閲覧回数
pigi
Hi, we have an i.MX8MM with LVDS.
We had to run several applications on it and we had to rotate the display 180 degrees.
We have tried several canonical approaches but without success.
How can we rotate the display?
6 返答(返信)
2,994件の閲覧回数
joanxie
what bsp do you use? linux or android?
2,986件の閲覧回数
pigi
we are using Linux with 5.4.142 kernel onboard.
2,964件の閲覧回数
joanxie
you can change "transform" in the weston.ini
2,941件の閲覧回数
pigi
Thank you for your reply, but we choose to don't use weston.
Are there a lower level way?
2,900件の閲覧回数
joanxie
you can try to use GPU 2D to rotate, you can refer to the G2D api from gpu user guide, you can download the user guide from:
"https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat..."
2,878件の閲覧回数
pigi
Thank you, I'll give it a try.
