Disable DRAM_CS1 on imx6
1,837 次查看
juanalbertogonz
we recently discover that we have a design problem on our DDR data lines on CS1, is there a quick way to disable the DRAM_CS1?
I'm using yocto framework to build de BSP.
1,815 次查看
nxf63675
Hi Juan,
Of which of the device from the i.MX6 are you trying to do this?
Probably this can be done by modifying the .dts on your system and send a specific instruction to this, you can take a look on the reference manual into this.
Israel H.
1,811 次查看
juanalbertogonz
Hi Israel,
we're using the MCIMX6Q5EYM10AD, will start looking to the dts file...
