Device Tree for new Audio codec under imx8qm Custom
13,135 次查看
vinothkumars
Senior Contributor IV
Hi All,
I am working on IMX8QM Custom Platform. I unable to achieve new codec (nau8810) interface in my platform. Please find my below code and give your feedback.
Using I2C0 interface with SAI1
/* Do not have fsl codec interface driver, So I used the simple codec driver for interface */
+ sound{
+ compatible = "simple-audio-card";
+ lable = "nau8810-audio";
+ simple-audio-card,frame-master = <&nacpu>;
+ simple-audio-card,bitclock-master = <&nacpu>;
+ simple-audio-card,widgets = "Speaker", "Speaker";
+ simple-audio-card,routing = "Speaker", "Speaker";
+ simple-audio-card,dai-link {
+ format = "i2s";
+ cpu {
+ sound-dai = <&sai1 1>;
+ nacpu: codec {
+ sound-dai = <&nau8810>;
/* Under I2C0 */
+ nau8810: nau8810@1a {
+ #sound-dai-cells = <0>;
+ compatible = "nuvoton,nau8810";
+ reg = <0x1a>;
Vinothkumar Sekar
12 回复数
4,643 次查看
RutvijTrivedi207
One good link to check detailed Audio bring up for NXP in Android and Linux - https://siliconsignals.io/audio-codec-bring-up-simplified-your-guide-to-android-linux-bsp-developmen...
11,538 次查看
KBL
@vinothkumars did you find a soulution? We have the same problem and get the error:
nau8810 0-001a: ASoC: error at snd_soc_component_update_bits on nau8810.0-001a: -6
Blume
12,968 次查看
DhavalS
Hi Team,
I am working on the same task. We have shared the part of the schematic to provide the idea how the SOC SAI1 and  codec pins are interfaced.
Just to provide more info on machine driver and also some more details
file : sound/soc/fsl/fsl-asoc-card.c
With this interfacing, we can see clock as follows on SAI1_TXC_CODEC and so on MCLK pin of the codec
  • Configure codec as slave and format is I2S (SND_SOC_DAIFMT_I2S)
    • Format S16_LE and two channel
    • Clock for Sampling rate 8k = 256000HZ
    • Clock for Sampling rate 48k = 1536000HZ
    • Audio output = Only noise and no audio
  • Configure codec as slave and format is PCM (SND_SOC_DAIFMT_DSP_A)
    • Clock for Sampling rate 8k = 512000HZ
    • Clock for Sampling rate 48k = 3072000HZ
Can you please let us know that MCLK_OUT0 of the SOC need to connect with the Codec MCLK pin instead of the SAI1_TXC_CODEC pin?
Any pointers are really appreciated.
12,953 次查看
for MCLK_OUT0 connection one can look at p.12, p.31 U43 NC7WV16, p.24
U29 WM8960 SPF-29420  MCIMX8QM-CPU MEK – Schematics
12,945 次查看
DhavalS
Hi Igor,
Thanks a lot for your quick reponse.
I have seen this MCLK_OUT0 is connected with Codec MCLK pin in MEK board.
But, same thing is not connected in our case so to get proper clock and make codec work is MCLK_OUT0 required to connect with MCLK pin of codec or that is not mandetory ?
We are using sai1 for connection with codec and codec is nau8810.
12,931 次查看
suggest to ask tech support vendor of this codec, if nau8810 codec MCLK is mandatory:
https://www.nuvoton.com/support/technical-support/nuforum/
12,913 次查看
DhavalS
Thanks Igor for the reply.
Just give me one information that If we use SAI1_TXC pin for clock instead of MCLK_OUT0 pin then
Is there any software configuration required in machine driver or dts node?
Thanks & Regards,
Dhaval
12,909 次查看
sorry nxp did not use such configuration in its bsps.
13,129 次查看
Hi Vinothkumar
for porting new codec one can look at Chapter 16 Porting Audio Codecs  i.MX Porting Guide​
and Chapter 7 Audio   i.MX Linux Reference Manual​
13,109 次查看
vinothkumars
Thank you @igorpadykov ,
I did the configuration and codec also detecting now, But, I got error while capture and playback. and also there is no audio from speaker
root@root:~# cat /proc/asound/cards
0 [D59050000sainau]: 59050000_sai-na - 59050000.sai-nau8810-hifi
root@root:~# arecord -d 0 -f u8 viz.wav
Recording WAVE 'viz.wav' : Unsigned 8 bit, Rate 8000 Hz, Mono
[ 1066.472264] nau8810 3-001a: ASoC: error at snd_soc_component_update_bits on nau8810.3-001a: -110
[ 1067.488257] nau8810 3-001a: ASoC: error at snd_soc_component_update_bits on nau8810.3-001a: -110
[ 1068.504247] nau8810 3-001a: ASoC: error at snd_soc_component_update_bits on nau8810.3-001a: -110
root@root:~# aplay viz.wav
Playing WAVE 'viz.wav' : Unsigned 8 bit, Rate 8000 Hz, Mono
[ 1670.316265] nau8810 3-001a: ASoC: error at snd_soc_component_update_bits on nau8810.3-001a: -110
[ 1671.332247] nau8810 3-001a: ASoC: error at snd_soc_component_update_bits on nau8810.3-001a: -110
[ 1672.348247] nau8810 3-001a: ASoC: error at snd_soc_component_update_bits on nau8810.3-001a: -110
Vinothkumar Sekar
13,081 次查看
vinothkumars
Thank you @igorpadykov for the reply,
Audio Codec DTS:
/* Connected with I2C0 */
                reg = <0x1a>;
                clocks = <&mclkout0_lpcg 0>;
                clock-names = "mclk";
                assigned-clocks = <&clk IMX_SC_R_AUDIO_PLL_0 IMX_SC_PM_CLK_PLL>,
                                <&clk IMX_SC_R_AUDIO_PLL_0 IMX_SC_PM_CLK_SLV_BUS>,
                                <&clk IMX_SC_R_AUDIO_PLL_0 IMX_SC_PM_CLK_MST_BUS>,
                                <&mclkout0_lpcg 0>;
                assigned-clock-rates = <786432000>, <49152000>, <12288000>, <12288000>;
/* Connected with SAI1 */
        sound-nau8810{
                        "Speaker", "Ext Spk",
                        "Microphone", "Mic Jack";
                        "Ext Spk", "MONOOUT",
                        "Ext Spk", "SPKOUTP",
                        "Ext Spk", "SPKOUTN",
                        "MICN", "Mic Jack",
                        "MICP", "Mic Jack",
                        "Mic Jack", "Mic Bias";
                        format = "i2s";
                        cpu {
                                sound-dai = <&sai1>;
                        nacpu: codec {
But, problem I here I don't MCLK line. MCLK and BCLK are shorted.
So, There is no separate MCLK and BCLK.
Vinothkumar Sekar
13,065 次查看
vinothkumars
Hi @igorpadykov ,
Audio codec is working, But, I got noise instead of proper sound, Will you please check the device tree and schematic.
Vinothkumar Sekar
%3CLINGO-SUB%20id%3D%22lingo-sub-1344155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8qm%20%E8%87%AA%E5%AE%9A%E4%B9%89%E4%B8%8B%E6%96%B0%E9%9F%B3%E9%A2%91%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1344155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%BC%80%E5%8F%91%20IMX8QM%20%E5%AE%9A%E5%88%B6%E5%B9%B3%E5%8F%B0%E3%80%82%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%E6%88%91%E7%9A%84%E5%B9%B3%E5%8F%B0%E4%B8%8A%E5%AE%9E%E7%8E%B0%E6%96%B0%E7%9A%84%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%3CSTRONG%3E(%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3Enau8810%3C%2FFONT%3E)%3C%2FSTRONG%3E%E6%8E%A5%E5%8F%A3%E3%80%82%E8%AF%B7%E6%89%BE%E5%88%B0%E6%88%91%E4%B8%8B%E9%9D%A2%E7%9A%84%E4%BB%A3%E7%A0%81%E5%B9%B6%E6%8F%90%E4%BE%9B%E5%8F%8D%E9%A6%88%E6%84%8F%E8%A7%81%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%BF%E7%94%A8%20SAI1%20%E7%9A%84%20I2C0%20%E6%8E%A5%E5%8F%A3%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20translate%3D%22no%22%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%3E%3CSTRONG%3E%2F*%20Do%20not%20have%20fsl%20codec%20interface%20driver%2C%20So%20I%20used%20the%20simple%20codec%20driver%20for%20interface%20*%2F%3C%2FSTRONG%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20sound%7B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20compatible%20%3D%20%22simple-audio-card%22%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20lable%20%3D%20%22nau8810-audio%22%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20simple-audio-card%2Cframe-master%20%3D%20%26lt%3B%26amp%3Bnacpu%26gt%3B%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20simple-audio-card%2Cbitclock-master%20%3D%20%26lt%3B%26amp%3Bnacpu%26gt%3B%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20simple-audio-card%2Cwidgets%20%3D%20%22Speaker%22%2C%20%22Speaker%22%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20simple-audio-card%2Crouting%20%3D%20%22Speaker%22%2C%20%22Speaker%22%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20simple-audio-card%2Cdai-link%20%7B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20format%20%3D%20%22i2s%22%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20cpu%20%7B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20sound-dai%20%3D%20%26lt%3B%26amp%3Bsai1%201%26gt%3B%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20%7D%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20nacpu%3A%20codec%20%7B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20sound-dai%20%3D%20%26lt%3B%26amp%3Bnau8810%26gt%3B%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20%7D%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20%7D%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20%7D%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%3E%3CSTRONG%3E%2F*%20Under%20I2C0%20*%2F%3C%2FSTRONG%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20nau8810%3A%20nau8810%401a%20%7B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20%23sound-dai-cells%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20compatible%20%3D%20%22nuvoton%2Cnau8810%22%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20reg%20%3D%20%26lt%3B0x1a%26gt%3B%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22book%20antiqua%2Cpalatino%22%20color%3D%22%23800000%22%3E%2B%20%7D%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1344155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2199103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Device%20Tree%20for%20new%20Audio%20codec%20under%20imx8qm%20Custom%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2199103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%20Android%20%E5%92%8C%20Linux%20%E4%B8%AD%E6%A3%80%E6%9F%A5%E6%81%A9%E6%99%BA%E6%B5%A6%E9%9F%B3%E9%A2%91%E8%B0%83%E8%AF%95%E8%AF%A6%E6%83%85%E7%9A%84%E4%B8%80%E4%B8%AA%E5%BE%88%E5%A5%BD%E7%9A%84%E9%93%BE%E6%8E%A5%20-%3CA%20href%3D%22https%3A%2F%2Fsiliconsignals.io%2Faudio-codec-bring-up-simplified-your-guide-to-android-linux-bsp-development%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fsiliconsignals.io%2Faudio-codec-bring-up-simplified-your-guide-to-android-linux-bsp-development%2F%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1585960%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Device%20Tree%20for%20new%20Audio%20codec%20under%20imx8qm%20Custom%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1585960%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F65315%22%20target%3D%22_blank%22%3E%40vinothkumars%3C%2FA%3E%E4%BD%A0%E6%89%BE%E5%88%B0%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E4%BA%86%E5%90%97%EF%BC%9F%E6%88%91%E4%BB%AC%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%87%BA%E7%8E%B0%E4%BA%86%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Enau8810%200-001a%EF%BC%9AASoC%EF%BC%9Anau8810.0-001a%20%E4%B8%8A%E7%9A%84%20snd_soc_component_update_bits%20%E5%87%BA%E9%94%99%EF%BC%9A-6%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E5%B8%83%E5%8D%A2%E5%A7%86%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1364725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Device%20Tree%20for%20new%20Audio%20codec%20under%20imx8qm%20Custom%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1364725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%26gt%3B%E4%BD%BF%E7%94%A8%20SAI1_TXC%20%E5%BC%95%E8%84%9A%E4%BB%A3%E6%9B%BF%20MCLK_OUT0%20%E5%BC%95%E8%84%9A%E4%BD%9C%E4%B8%BA%E6%97%B6%E9%92%9F%EF%BC%8C%E9%82%A3%E4%B9%88%3C%2FP%3E%0A%3CP%3E%26gt%3B%E6%9C%BA%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%88%96%20dts%20%E8%8A%82%E7%82%B9%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E4%BB%BB%E4%BD%95%E8%BD%AF%E4%BB%B6%E9%85%8D%E7%BD%AE%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%BE%88%E6%8A%B1%E6%AD%89%20nxp%20%E6%B2%A1%E6%9C%89%E5%9C%A8%E5%85%B6%20bsps%20%E4%B8%AD%E4%BD%BF%E7%94%A8%E8%BF%99%E6%A0%B7%E7%9A%84%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%97%AE%E5%80%99%3CBR%20%2F%3Eigor%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1364553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Device%20Tree%20for%20new%20Audio%20codec%20under%20imx8qm%20Custom%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1364553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E4%BC%8A%E6%88%88%E5%B0%94%E7%9A%84%E7%AD%94%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E4%B8%80%E4%B8%AA%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%20SAI1_TXC%20%E5%BC%95%E8%84%9A%E8%80%8C%E4%B8%8D%E6%98%AF%20MCLK_OUT0%20%E5%BC%95%E8%84%9A%E4%BD%9C%E4%B8%BA%E6%97%B6%E9%92%9F%EF%BC%8C%E9%82%A3%E4%B9%88%3C%2FP%3E%3CP%3E%E6%9C%BA%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%88%96%20dts%20%E8%8A%82%E7%82%B9%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E4%BB%BB%E4%BD%95%E8%BD%AF%E4%BB%B6%E9%85%8D%E7%BD%AE%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%26amp%3B%20%E3%80%81%3C%2FP%3E%3CP%3E%E8%BE%BE%E7%93%A6%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1364132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Device%20Tree%20for%20new%20Audio%20codec%20under%20imx8qm%20Custom%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1364132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%26gt%3B%20%E5%9B%A0%E6%AD%A4%EF%BC%8C%E4%B8%BA%E4%BA%86%E8%8E%B7%E5%BE%97%E9%80%82%E5%BD%93%E7%9A%84%E6%97%B6%E9%92%9F%E5%B9%B6%E4%BD%BF%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E5%B7%A5%E4%BD%9C%EF%BC%8CMCLK_OUT0%3C%2FP%3E%0A%3CP%3E%26gt%3B%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E8%BF%9E%E6%8E%A5%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E7%9A%84%20MCLK%20%E5%BC%95%E8%84%9A%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%BB%BA%E8%AE%AE%E8%AF%A2%E9%97%AE%E8%AF%A5%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E7%9A%84%E6%8A%80%E6%9C%AF%E6%94%AF%E6%8C%81%E4%BE%9B%E5%BA%94%E5%95%86%EF%BC%8Cnau8810%20%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E7%9A%84%20MCLK%20%E6%98%AF%E5%90%A6%E6%98%AF%E5%BC%BA%E5%88%B6%E6%80%A7%E7%9A%84%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nuvoton.com%2Fsupport%2Ftechnical-support%2Fnuforum%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nuvoton.com%2Fsupport%2Ftechnical-support%2Fnuforum%2F%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%97%AE%E5%80%99%3CBR%20%2F%3Eigor%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1364120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Device%20Tree%20for%20new%20Audio%20codec%20under%20imx8qm%20Custom%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1364120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E4%BC%8A%E6%88%88%E5%B0%94%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%BF%AB%E9%80%9F%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%A7%81%E8%BF%87%E8%BF%99%E4%B8%AA%20MCLK_OUT0%20%E4%B8%8E%20MEK%20%E6%9D%BF%E4%B8%AD%E7%9A%84%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%20MCLK%20%E5%BC%95%E8%84%9A%E7%9B%B8%E8%BF%9E%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%E6%A1%88%E4%BE%8B%E4%B8%AD%E6%B2%A1%E6%9C%89%E8%BF%9E%E6%8E%A5%E5%90%8C%E6%A0%B7%E7%9A%84%E8%AE%BE%E5%A4%87%EF%BC%8C%E5%9B%A0%E6%AD%A4%E8%A6%81%E8%8E%B7%E5%BE%97%E9%80%82%E5%BD%93%E7%9A%84%E6%97%B6%E9%92%9F%E5%B9%B6%E4%BD%BF%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%B0%86%20MCLK_OUT0%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E7%9A%84%20MCLK%20%E5%BC%95%E8%84%9A%E4%B8%8A%EF%BC%8C%E6%88%96%E8%80%85%E8%BF%99%E4%B8%8D%E6%98%AF%E5%BF%85%E9%A1%BB%E7%9A%84%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%20sai1%20%E4%B8%8E%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E8%BF%9E%E6%8E%A5%EF%BC%8C%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E6%98%AF%20nau8810%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1364116%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Device%20Tree%20for%20new%20Audio%20codec%20under%20imx8qm%20Custom%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1364116%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%26gt%3B%20%E4%BD%A0%E8%83%BD%E5%90%A6%E4%B8%8E%E6%88%91%E4%BB%AC%E8%81%94%E7%B3%BB%EF%BC%8C%E4%BA%86%E8%A7%A3%20%3CSTRONG%3ESOC%3C%2FSTRONG%3E%20%E7%9A%84%20MC%20%3CSTRONG%3ELK_OUT0%3C%2FSTRONG%3E%20%E9%9C%80%E8%A6%81%E8%BF%9E%E6%8E%A5%3C%2FP%3E%0A%3CP%3E%26gt%3B%3CSTRONG%3E%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%20MCLK%3C%2FSTRONG%3E%E5%BC%95%E8%84%9A%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20SAI1_TXC_CODEC%20%E5%BC%95%E8%84%9A%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%85%B3%E4%BA%8E%20MCLK_OUT0%20%E8%BF%9E%E6%8E%A5%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%A7%81%E7%AC%AC%2012%20%E9%A1%B5%E5%92%8C%E7%AC%AC%2031%20%E9%A1%B5%20U43%20NC7WV16%EF%BC%8C%E7%AC%AC%2024%20%E9%A1%B5%3C%2FP%3E%0A%3CP%3EU29%20WM8960%20SPF-29420%20%3CA%20id%3D%22docsAndSoftware_designResultTitle1_1%22%20class%3D%22dtmcustomrulelink%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DSCH-29420_C7%22%20data-dtmaction%3D%22Documents%20and%20Software%20Results%20-%20Software%20Link%20click%22%20data-dtmsubaction%3D%22MCIMX8QM-CPU%20MEK%20%E2%80%93%20Schematics%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E6%8D%A2%E6%88%90%E4%BA%A7%E5%93%81%E5%90%8D%EF%BC%8C%E5%A6%82%E2%80%9Ci.mx8-mek%E6%98%AF%E2%80%A6%E2%80%A6%E2%80%9D%20%E2%80%93%20%E5%8E%9F%E7%90%86%E5%9B%BE%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%97%AE%E5%80%99%3CBR%20%2F%3Eigor%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1363669%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Device%20Tree%20for%20new%20Audio%20codec%20under%20imx8qm%20Custom%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1363669%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%9B%A2%E9%98%9F%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%81%9A%E5%90%8C%E6%A0%B7%E7%9A%84%E5%B7%A5%E4%BD%9C%E3%80%82%E6%88%91%E4%BB%AC%E5%88%86%E4%BA%AB%E4%BA%86%E9%83%A8%E5%88%86%E5%8E%9F%E7%90%86%E5%9B%BE%EF%BC%8C%E8%AE%A9%E5%A4%A7%E5%AE%B6%E4%BA%86%E8%A7%A3%20SOC%20SAI1%20%E5%92%8C%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E5%BC%95%E8%84%9A%E6%98%AF%E5%A6%82%E4%BD%95%E8%BF%9E%E6%8E%A5%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%85%E6%8F%90%E4%BE%9B%E6%9C%89%E5%85%B3%E6%9C%BA%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%8C%E4%BB%A5%E5%8F%8A%E4%B8%80%E4%BA%9B%E6%9B%B4%E8%AF%A6%E7%BB%86%E7%9A%84%E4%BF%A1%E6%81%AF%3C%2FP%3E%3CP%3E%E6%96%87%E4%BB%B6%EF%BC%9Asound%2Fsoc%2Ffsl%2Ffsl-asoc-card.c%3C%2FP%3E%3CP%3E%E9%80%9A%E8%BF%87%E8%BF%99%E7%A7%8D%E6%8E%A5%E5%8F%A3%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E5%9C%A8%20SAI1_TXC_CODEC%20%E5%92%8C%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E7%9A%84%20MCLK%20%E5%BC%95%E8%84%9A%E4%B8%8A%E7%9C%8B%E5%88%B0%E5%A6%82%E4%B8%8B%E6%97%B6%E9%92%9F%E4%BF%A1%E5%8F%B7%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%B0%86%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E9%85%8D%E7%BD%AE%E4%B8%BA%E4%BB%8E%E5%B1%9E%E8%AE%BE%E5%A4%87%EF%BC%8C%E6%A0%BC%E5%BC%8F%E4%B8%BA%20I2S%20(SND_SOC_DAIFMT_I2S)%3CUL%3E%3CLI%3E%E6%A0%BC%E5%BC%8F%20S16_LE%20%E5%92%8C%E5%8F%8C%E9%80%9A%E9%81%93%3C%2FLI%3E%3CLI%3E%E9%87%87%E6%A0%B7%E7%8E%87%E6%97%B6%E9%92%9F%208k%20%3D%20256000HZ%3C%2FLI%3E%3CLI%3E%E9%87%87%E6%A0%B7%E7%8E%87%2048k%20%3D%201536000HZ%20%E6%97%B6%E9%92%9F%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E9%9F%B3%E9%A2%91%E8%BE%93%E5%87%BA%20%3D%20%E5%8F%AA%E6%9C%89%E5%99%AA%E9%9F%B3%E6%B2%A1%E6%9C%89%E9%9F%B3%E9%A2%91%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CUL%3E%3CLI%3E%E5%B0%86%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E9%85%8D%E7%BD%AE%E4%B8%BA%E4%BB%8E%E5%B1%9E%E8%AE%BE%E5%A4%87%EF%BC%8C%E6%A0%BC%E5%BC%8F%E4%B8%BA%20PCM%20(SND_SOC_DAIFMT_DSP_A)%3CUL%3E%3CLI%3E%E6%A0%BC%E5%BC%8F%20S16_LE%20%E5%92%8C%E5%8F%8C%E9%80%9A%E9%81%93%3C%2FLI%3E%3CLI%3E%E9%87%87%E6%A0%B7%E7%8E%87%E6%97%B6%E9%92%9F%208k%20%3D%20512000HZ%3C%2FLI%3E%3CLI%3E%E9%87%87%E6%A0%B7%E7%8E%87%2048k%20%3D%203072000HZ%20%E6%97%B6%E9%92%9F%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E9%9F%B3%E9%A2%91%E8%BE%93%E5%87%BA%20%3D%20%E5%8F%AA%E6%9C%89%E5%99%AA%E9%9F%B3%E6%B2%A1%E6%9C%89%E9%9F%B3%E9%A2%91%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%90%A6%E4%B8%8E%E6%88%91%E4%BB%AC%E8%81%94%E7%B3%BB%EF%BC%8C%3CSTRONG%3ESOC%3C%2FSTRONG%3E%20%E7%9A%84%20MC%20%3CSTRONG%3ELK_OUT0%3C%2FSTRONG%3E%20%E9%9C%80%E8%A6%81%E8%BF%9E%E6%8E%A5%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%20MCL%20%3CSTRONG%3EK%20%E5%BC%95%E8%84%9A%E8%80%8C%E4%B8%8D%E6%98%AF%20SAI1_TXC_CODEC%3C%2FSTRONG%3E%20%E5%BC%95%E8%84%9A%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E8%92%99%E6%8C%87%E7%82%B9%EF%BC%8C%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1349751%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Device%20Tree%20for%20new%20Audio%20codec%20under%20imx8qm%20Custom%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1349751%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%98%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37066%22%20target%3D%22_blank%22%3E%40igorpadykov%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9F%B3%E9%A2%91%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E7%9A%84%E6%98%AF%E5%99%AA%E9%9F%B3%E8%80%8C%E4%B8%8D%E6%98%AF%E6%AD%A3%E5%B8%B8%E7%9A%84%E5%A3%B0%E9%9F%B3%EF%BC%8C%E8%AF%B7%E4%BD%A0%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E8%AE%BE%E5%A4%87%E6%A0%91%E5%92%8C%E5%8E%9F%E7%90%86%E5%9B%BE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1347569%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Device%20Tree%20for%20new%20Audio%20codec%20under%20imx8qm%20Custom%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1347569%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37066%22%20target%3D%22_blank%22%3E%40igorpadykov%3C%2FA%3E%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%81%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E9%9F%B3%E9%A2%91%E8%A7%A3%E7%A0%81%E5%99%A8%20DTS%20%3C%2FSTRONG%3E%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CSTRONG%3E%2F*%20Connected%20with%20I2C0%20*%2F%3C%2FSTRONG%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20nau8810%3A%20nau8810%401a%20%7B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%23sound-dai-cells%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20compatible%20%3D%20%22nuvoton%2Cnau8810%22%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20reg%20%3D%20%26lt%3B0x1a%26gt%3B%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20clocks%20%3D%20%26lt%3B%26amp%3Bmclkout0_lpcg%200%26gt%3B%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20clock-names%20%3D%20%22mclk%22%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20assigned-clocks%20%3D%20%26lt%3B%26amp%3Bclk%20IMX_SC_R_AUDIO_PLL_0%20IMX_SC_PM_CLK_PLL%26gt%3B%2C%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26lt%3B%26amp%3Bclk%20IMX_SC_R_AUDIO_PLL_0%20IMX_SC_PM_CLK_SLV_BUS%26gt%3B%2C%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26lt%3B%26amp%3Bclk%20IMX_SC_R_AUDIO_PLL_0%20IMX_SC_PM_CLK_MST_BUS%26gt%3B%2C%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26lt%3B%26amp%3Bmclkout0_lpcg%200%26gt%3B%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20assigned-clock-rates%20%3D%20%26lt%3B786432000%26gt%3B%2C%20%26lt%3B49152000%26gt%3B%2C%20%26lt%3B12288000%26gt%3B%2C%20%26lt%3B12288000%26gt%3B%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3E%2F*%20Connected%20with%20SAI1%20*%2F%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20sound-nau8810%7B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20compatible%20%3D%20%22simple-audio-card%22%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20lable%20%3D%20%22nau8810-audio%22%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20simple-audio-card%2Cframe-master%20%3D%20%26lt%3B%26amp%3Bnacpu%26gt%3B%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20simple-audio-card%2Cbitclock-master%20%3D%20%26lt%3B%26amp%3Bnacpu%26gt%3B%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20simple-audio-card%2Cwidgets%20%3D%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%22Speaker%22%2C%20%22Ext%20Spk%22%2C%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%22Microphone%22%2C%20%22Mic%20Jack%22%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20simple-audio-card%2Crouting%20%3D%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%22Ext%20Spk%22%2C%20%22MONOOUT%22%2C%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%22Ext%20Spk%22%2C%20%22SPKOUTP%22%2C%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%22Ext%20Spk%22%2C%20%22SPKOUTN%22%2C%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%22MICN%22%2C%20%22Mic%20Jack%22%2C%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%22MICP%22%2C%20%22Mic%20Jack%22%2C%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%22Mic%20Jack%22%2C%20%22Mic%20Bias%22%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20simple-audio-card%2Cdai-link%20%7B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20format%20%3D%20%22i2s%22%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20cpu%20%7B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20sound-dai%20%3D%20%26lt%3B%26amp%3Bsai1%26gt%3B%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20nacpu%3A%20codec%20%7B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20sound-dai%20%3D%20%26lt%3B%26amp%3Bnau8810%26gt%3B%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FPRE%3E%3CP%3E%E4%BD%86%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E6%88%91%3CSTRONG%3E%E6%B2%A1%E6%9C%89%20MCLK%20%E7%BA%BF%E8%B7%AF%3C%2FSTRONG%3E%E3%80%82MCLK%20%E5%92%8C%20BCLK%20%E7%9F%AD%E8%B7%AF%E3%80%82%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vinothkumars_1-1632829284504.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vinothkumars_1-1632829284504.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F157730i1D4D4C63C562B9BD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vinothkumars_1-1632829284504.png%22%20alt%3D%22vinothkumars_1-1632829284504.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%3CSTRONG%3E%E6%B2%A1%E6%9C%89%E5%8D%95%E7%8B%AC%E7%9A%84%20MCLK%20%E5%92%8C%20BCLK%3C%2FSTRONG%3E%E3%80%82%20%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1346089%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Device%20Tree%20for%20new%20Audio%20codec%20under%20imx8qm%20Custom%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1346089%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37066%22%20target%3D%22_blank%22%3E%40igorpadykov%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E5%B7%B2%E7%BB%8F%E5%AE%8C%E6%88%90%E4%BA%86%E9%85%8D%E7%BD%AE%E5%92%8C%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E6%A3%80%E6%B5%8B%EF%BC%8C%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E5%9C%A8%E6%8D%95%E8%8E%B7%E5%92%8C%E6%92%AD%E6%94%BE%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E9%94%99%E8%AF%AF%E3%80%82%E6%89%AC%E5%A3%B0%E5%99%A8%E4%B9%9F%E6%B2%A1%E6%9C%89%E5%A3%B0%E9%9F%B3%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20translate%3D%22no%22%3Eroot%40root%3A~%23%20%3CSTRONG%3Ecat%20%2Fproc%2Fasound%2Fcards%3C%2FSTRONG%3E%3CBR%20%2F%3E0%20%5BD59050000sainau%5D%3A%2059050000_sai-na%20-%2059050000.sai-nau8810-hifi%3CBR%20%2F%3E59050000.sai-nau8810-hifi%3CBR%20%2F%3E%3CBR%20%2F%3Eroot%40root%3A~%23%20%3CSTRONG%3Earecord%20-d%200%20-f%20u8%20viz.wav%3C%2FSTRONG%3E%3CBR%20%2F%3ERecording%20WAVE%20'viz.wav'%20%3A%20Unsigned%208%20bit%2C%20Rate%208000%20Hz%2C%20Mono%3CBR%20%2F%3E%5B%201066.472264%5D%20nau8810%203-001a%3A%20ASoC%3A%20error%20at%20snd_soc_component_update_bits%20on%20nau8810.3-001a%3A%20-110%3CBR%20%2F%3E%5B%201067.488257%5D%20nau8810%203-001a%3A%20ASoC%3A%20error%20at%20snd_soc_component_update_bits%20on%20nau8810.3-001a%3A%20-110%3CBR%20%2F%3E%5B%201068.504247%5D%20nau8810%203-001a%3A%20ASoC%3A%20error%20at%20snd_soc_component_update_bits%20on%20nau8810.3-001a%3A%20-110%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3Eroot%40root%3A~%23%20%3CSTRONG%3Eaplay%20viz.wav%3C%2FSTRONG%3E%3CBR%20%2F%3EPlaying%20WAVE%20'viz.wav'%20%3A%20Unsigned%208%20bit%2C%20Rate%208000%20Hz%2C%20Mono%3CBR%20%2F%3E%5B%201670.316265%5D%20nau8810%203-001a%3A%20ASoC%3A%20error%20at%20snd_soc_component_update_bits%20on%20nau8810.3-001a%3A%20-110%3CBR%20%2F%3E%5B%201671.332247%5D%20nau8810%203-001a%3A%20ASoC%3A%20error%20at%20snd_soc_component_update_bits%20on%20nau8810.3-001a%3A%20-110%3CBR%20%2F%3E%5B%201672.348247%5D%20nau8810%203-001a%3A%20ASoC%3A%20error%20at%20snd_soc_component_update_bits%20on%20nau8810.3-001a%3A%20-110%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1344477%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Device%20Tree%20for%20new%20Audio%20codec%20under%20imx8qm%20Custom%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1344477%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E7%BB%B4%E8%AF%BA%E6%96%AF%E5%BA%93%E9%A9%AC%E5%B0%94%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%A6%81%E7%A7%BB%E6%A4%8D%E6%96%B0%E7%9A%84%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%EF%BC%8C%E5%8F%AF%E5%8F%82%E9%98%85%E7%AC%AC%2016%20%E7%AB%A0%E3%80%8A%E7%A7%BB%E6%A4%8D%E9%9F%B3%E9%A2%91%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%20i%3CA%20style%3D%22box-sizing%3A%20border-box%3B%20background-color%3A%20transparent%3B%20color%3A%20%23215bd6%3B%20text-decoration%3A%20none%3B%20cursor%3A%20pointer%3B%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FIMX_PORTING_GUIDE.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E.MX%20%E7%A7%BB%E6%A4%8D%E6%8C%87%E5%8D%97%E3%80%8B%3C%2FA%3E%E3%80%82%20%20%20%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E5%8F%8A%E7%AC%AC%207%20%E7%AB%A0%20Audio%20%3CA%20style%3D%22box-sizing%3A%20border-box%3B%20background-color%3A%20transparent%3B%20color%3A%20%23215bd6%3B%20text-decoration%3A%20none%3B%20cursor%3A%20pointer%3B%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Freference-manual%2FIMX_REFERENCE_MANUAL.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ei.MX%20Linux%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%97%AE%E5%80%99%3CBR%20%2F%3Eigor%3C%2FP%3E%3C%2FLINGO-BODY%3E
