Debugging with GDB and Eclipse? expat problem?
andreaszeiler
I'm trying to setup a IDE to run and debug an application with Eclipse and the cross-compiler for iMX6 from freescale. (Debugger Version is 7.1).
I am able to cross compile my application and also run it on my target board. It is also working through a ssh terminal.
But I could't figure out how to debug my application. I've configured my buildroot to build gdb and gdbserver and copy it into my rootfs.
Over ssh terminal I can start my application and also when I start debugging eclipse starts the gdbserver with the specified port.
But the I get a Error Message:
Error in final launch sequence
Failed to execute MI command:
-break-insert -t -f main
Error message from debugger back end:
Remote 'g' packet reply is too long: 0000000028feff7e000000000000000000000000000000000000000000000000000000000000000000000000000000000000000020fdff7e00000000a0b7aa2a100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
In the eclipse console I get the error message:
warning: Can not parse XML target description; XML support was disabled at compile time
warning: Can not parse XML OS data; XML support was disabled at compile time
The target endianness is set automatically (currently little endian)
Can someone help me with this? I don't know whats wrong here and I also don't find any hint in google how to solve this.
I also tried to use my buildroot's toolchain and the freescale toolchain. (The are same version).
Andi
chris_f
Contributor V
I ran in to this problem. The cause for me was that I was launching the local x86 gdb rather than the one from my Yocto SDK (/opt/fsl-imx-fb/4.1.15-2.0.1/sysroots/x86_64-pokysdk-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-gdb).
dtran11
I am getting the same error as you. Did you solve this issue?
andreaszeiler
hello,
no I couldn't solve this. Im on other issues now.
