Debugging M33 on imx8ulp
bushlit
Hi!
How does debugging and running M33 code happen on evkmimx8ulp board?
I've found resources that I need to bake the m33 app binary to flash.bin using the imx-mkimage before I can debug it and I've found resources where you just connect segger with vscode extension and press debug.
I tried debugging the hello world example with vscode extension and segger and everything freezes. I'm running the demo images the board came with.
I have tried finding the binary files from "Linux release package" needed for imx-mkimage with no luck. I don't have yocto build setup yet.
Can the M core be programmed and debugged with just vscode extension or do I need to make the image container?
BL
%3CLINGO-SUB%20id%3D%22lingo-sub-2250216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDebugging%20M33%20on%20imx8ulp%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi!%3C%2FP%3E%3CP%3EHow%20does%20debugging%20and%20running%20M33%20code%20happen%20on%20evkmimx8ulp%20board%3F%3C%2FP%3E%3CP%3EI've%20found%20resources%20that%20I%20need%20to%20bake%20the%20m33%20app%20binary%20to%20flash.bin%20using%20the%20imx-mkimage%20before%20I%20can%20debug%20it%20and%20I've%20found%20resources%20where%20you%20just%20connect%20segger%20with%20vscode%20extension%20and%20press%20debug.%3C%2FP%3E%3CP%3EI%20tried%20debugging%20the%20hello%20world%20example%20with%20vscode%20extension%20and%20segger%20and%20everything%20freezes.%20I'm%20running%20the%20demo%20images%20the%20board%20came%20with.%3C%2FP%3E%3CP%3EI%20have%20tried%20finding%20the%20binary%20files%20from%20%22%3CSPAN%3ELinux%20release%20package%22%3C%2FSPAN%3E%20needed%20for%20imx-mkimage%20with%20no%20luck.%20I%20don't%20have%20yocto%20build%20setup%20yet.%3C%2FP%3E%3CP%3ECan%20the%20M%20core%20be%20programmed%20and%20debugged%20with%20just%20vscode%20extension%20or%20do%20I%20need%20to%20make%20the%20image%20container%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3CP%3EBL%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2250216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX8ULP%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
