Debian: Bluetooth Not Showing in GUI
Neha_V
On my i.MX8MP board running Debian, Bluetooth works properly through the command line. After installing pulseaudio-module-bluetooth, I am able to pair, connect, trust devices but a2dp sink and source is failing and even file transfer is failing.
through GUI not able to on the bluetooth .
how can I fix the Bluetooth GUI on Debian for the i.MX8MP board? and the a2dp and file transfer issue
joanxie
already mailed to you, pls check it
%3CLINGO-SUB%20id%3D%22lingo-sub-2205767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDebian%3A%20Bluetooth%20Not%20Showing%20in%20GUI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2205767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOn%20my%20i.MX8MP%20board%20running%20Debian%2C%20Bluetooth%20works%20properly%20through%20the%20command%20line.%20After%20installing%20pulseaudio-module-bluetooth%2C%20I%20am%20able%20to%20pair%2C%20connect%2C%20trust%20devices%20but%20a2dp%20sink%20and%20source%20is%20failing%20and%20even%20file%20transfer%20is%20failing.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ethrough%20GUI%20not%20able%20to%20on%20the%20bluetooth%20.%3C%2FP%3E%3CP%3Ehow%20can%20I%20fix%20the%20Bluetooth%20GUI%20on%20Debian%20for%20the%20i.MX8MP%20board%3F%20and%20the%20a2dp%20and%20file%20transfer%20issue%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2206274%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debian%3A%20Bluetooth%20Not%20Showing%20in%20GUI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2206274%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ealready%20mailed%20to%20you%2C%20pls%20check%20it%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
