Data Reading from the SD CARD
1,781件の閲覧回数
Shashi_ranjan_14
Hello all,
I want to read data from an SD card. I can read the display, but they only print the "char" value. Can anyone teach me how to read a float or decimal value and print it? now i am using imxrt1050 board using mcuXpresso.
iMXRT1050 @nxp @IMXRT1050
タグ(1)
3 返答(返信)
1,725件の閲覧回数
Shashi_ranjan_14
We successfully write on the SD card and read from the SD card, while reading from SD card we were able get data via "char" only. To get the data we are receiving by using sprintf and fscanf function.
In SD card file we have provided integer data and we want to read data such as double and float.
For above technical support u provide solution as use float pointer for that can provide a example to execute?
1,707件の閲覧回数
jingpan
Hi @Shashi_ranjan_14 ,
Like these code
    char ch;
    float *p;
    char data[4];
    float i=3.14159;
    char *pd;
    PRINTF("%f\r\n",i);
    pd = (char*)&i;
    for(ch=0;ch<4;ch++)
    	data[ch]=*pd++;
    p=(float*)&data[0];
    PRINTF("%f\r\n",*p);
https://community.nxp.com/t5/i-MX-RT/How-to-print-the-quot-negative-float-point-number-quot-to-show/...
Jing
1,762件の閲覧回数
jingpan
You can use a float pointer to do this.
Jing
