DM-Crypt with CAAM key Encrypted Filesystem Corrupt After Reboot
5,298 次查看
nsleung
Hello, I am using the iMX8M Mini SoC and am going through the app note (Rev 1 11/2020) Section 3.2 Usage (https://www.mouser.com/pdfDocs/AN12714.pdf). Kernel version is 5.4.70. I am able to complete everything (create tagged key, dummy image, ext4 filesystem, encrypt using dmsetup target crypt, etc). However, after the reboot and following the steps to mount the encrypted image fails. This is what is shown:
 sudo mount /dev/mapper/encrypted /mnt/encrypted/
mount: /mnt/encrypted: wrong fs type, bad option, bad superblock on /dev/mapper/encrypted, missing codepage or helper program, or other error.
 And when checking the integrity of the filesystem using fsck, it also reports bad superblock, leading me to believe something might be corrupted after rebooting.
e2fsck /dev/mapper/encrypted
e2fsck 1.44.5 (15-Dec-2018)
ext2fs_open2: Bad magic number in super-block
e2fsck: Superblock invalid, trying backup blocks...
e2fsck: Bad magic number in super-block while trying to open /dev/mapper/encrypted
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem.  If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
    e2fsck -b 8193 <device>
 or
    e2fsck -b 32768 <device>
 Any suggestions or thoughts would be appreciated!
6 回复数
2,284 次查看
woow
Hi NXP team,
We have an i.MX 8MP based device where a dm-crypt encrypted ext4 partition became unreadable after a power cycle. The exact same OS/image (same rootfs and provisioning process) is deployed across many devices, and those devices have definitely experienced power cycles without issue. We suspect a powerdown/up event may have triggered this failure on this particular device, but power cycling alone is not new in this fleet.
Unlock flow and exact commands:
# Only import key if keyhandle doesn't exist
if [ ! -f /tmp/keyhandle ]; then
    # Import key using CAAM
    caam-keygen import /uboot/black_blob.bb keyhandle
    # Add key to kernel keyring
    cat /tmp/keyhandle | keyctl padd logon logkey: @s
fi
# Create dm-crypt mapping
dmsetup -v create ${ENCRYPTED_NAME} --table "0 $(blockdev --getsz ${DEVICE}) crypt capi:tk(cbc(aes))-plain :36:logon:logkey: 0 ${DEVICE} 0 1 sector_size:512"
What we see:
  • dmsetup succeeds and mapping is ACTIVE
  • mount fails with “wrong fs type / bad superblock”
  • dmesg shows: EXT4-fs (dm-0): VFS: Can't find ext4 filesystem
  • e2fsck reports invalid superblock (no valid ext2/3/4 found)
We have verified the CAAM black blob on the device is still identical to what was flashed during manufacturing, so the key material itself does not appear to have changed. This makes us suspect either:
  • encrypted partition corruption due to power loss, or
  • a subtle CAAM/dm-crypt/driver issue that only manifests after reboot or power loss.
Environment:
  • Linux 6.6.23 (Yocto-based)
  • i.MX 8MP platform using CAAM key import
  • dm-crypt mapping created with capi:tk(cbc(aes))-plain, sector_size:512
  • ext4 filesystem
  • eMMC storage
Yocto layers / repo hashes used:
  • poky: 02eacd385eca7aa9cf25aaaa61427aa9c126e0bc
  • meta-openembedded: a72010b414ee3d73888ac9cb4e310e8f05e13aea
  • meta-arm: 8aa8a1f17f5b64bc691544f989f04fc83df98adb
  • meta-security: 11ea91192d43d7c2b0b95a93aa63ca7e73e38034
  • meta-timesys: b96d8de949939ad08094f71ed6ed4f88eaf41d5e
  • meta-virtualization: 1a547c0aa0d75c4143cbb66de6e653d51cdc8bda
  • meta-clang: 66414c17ae60e489bef9a97031323e92c247fbe1
  • meta-freescale: 41b923e59e048b9b2942ff737a4ddac386954c62
  • meta-freescale-3rdparty: 8b61684f0b1ba8bacdf3a69d993445e9791d4932
  • meta-freescale-distro: 158cc55b6ee30d09957b380859dba52c0f6af68d
  • meta-imx: 239073c47124f41f46581871afbde643f48d6a3b
  • meta-nxp-security-reference-design: 15d4eccdc503ea07634b869af0df7e4e2917ebf1
Questions for NXP:
  1. Are there known issues with CAAM + dm-crypt (CBC-AES with capi:tk(cbc(aes))-plain) that can cause irrecoverable filesystem corruption after reboot/power loss?
  2. Are there newer drivers or recommended crypt schemes/configs for CAAM-backed dm-crypt on i.MX 8MP that are more robust?
  3. Since this is eMMC, do you have any recommendations for write-reliability settings, dm-crypt block size, flush behavior, mount options, or other mitigation techniques to reduce the chance of corruption after power loss?
If you need additional logs or details, I can provide them.
5,254 次查看
Harvey021
Have you run caam-keygen import: # ./caam-keygen import /data/caam/randomkey.bb importKey
before running: # cat /data/caam/importKey | keyctl padd logon logkey2: @s
Because this key has to be re-injected every time it is powered up
Harvey
5,247 次查看
nsleung
Yes, I'm able to import the key and add to keyctl from blob after rebooting every time. I can also create the encrypted device mapper device using the same block device before the power cycle but when mounting, it will report 'corrupted filesystem'. Do I need to boot in Secure Mode? I don't believe I am doing that.
5,274 次查看
Harvey021
Hi @nsleung
I've just followed up the guide to experiment it again. there is no such issue arise.
There would be probably required tools missed liek "coreutils keyutils lvm2 e2fsprogs-mke2fs util-linux"" which states in
section 8. Add required tools to build by editing conf/local.conf file and appending.
Harvey
5,260 次查看
nsleung
Thanks for the suggestion, I do have those additional utilities built in
4,699 次查看
lfant
Hello @nsleung ,
were you ever able to solve the problem? I see the exact same issue when using CAAM+dmcrypt on a iMX8MP running Yocto kirkstone & kernel 5.15.x
%3CLINGO-SUB%20id%3D%22lingo-sub-1529848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20CAAM%20%E5%AF%86%E9%92%A5%E5%8A%A0%E5%AF%86%E7%9A%84%20DM-Crypt%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%9C%A8%E9%87%8D%E5%90%AF%E5%90%8E%E6%8D%9F%E5%9D%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1529848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20iMX8M%20Mini%20SoC%EF%BC%8C%E6%AD%A3%E5%9C%A8%E9%98%85%E8%AF%BB%E5%BA%94%E7%94%A8%E8%AF%B4%E6%98%8E%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%201%2011%2F2020%EF%BC%89%E7%AC%AC%203.2%20%E8%8A%82%E7%94%A8%E6%B3%95%3CA%20href%3D%22https%3A%2F%2Fwww.mouser.com%2FpdfDocs%2FAN12714.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E(https%3A%2F%2Fwww.mouser.com%2FpdfDocs%2FAN12714.pdf)%3C%2FA%3E%E3%80%82%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E4%B8%BA%205.4.70%E3%80%82%E6%88%91%E8%83%BD%E5%A4%9F%E5%AE%8C%E6%88%90%E6%89%80%E6%9C%89%E6%93%8D%E4%BD%9C%EF%BC%88%E5%88%9B%E5%BB%BA%E6%A0%87%E8%AE%B0%E5%AF%86%E9%92%A5%E3%80%81%E8%99%9A%E6%8B%9F%E6%98%A0%E5%83%8F%E3%80%81ext4%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%81%E4%BD%BF%E7%94%A8%20dmsetup%20target%20crypt%20%E5%8A%A0%E5%AF%86%E7%AD%89%EF%BC%89%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E9%87%8D%E5%90%AF%E5%90%8E%EF%BC%8C%E6%8C%89%E7%85%A7%E6%AD%A5%E9%AA%A4%E5%8A%A0%E8%BD%BD%E5%8A%A0%E5%AF%86%E6%98%A0%E5%83%8F%E6%97%B6%E5%8D%B4%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%E8%BF%99%E5%B0%B1%E6%98%AF%E6%98%BE%E7%A4%BA%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%20sudo%20mount%20%2Fdev%2Fmapper%2Fencrypted%20%2Fmnt%2Fencrypted%2F%0Amount%3A%20%2Fmnt%2Fencrypted%3A%20wrong%20fs%20type%2C%20bad%20option%2C%20bad%20superblock%20on%20%2Fdev%2Fmapper%2Fencrypted%2C%20missing%20codepage%20or%20helper%20program%2C%20or%20other%20error.%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E4%BD%BF%E7%94%A8%20fsck%20%E6%A3%80%E6%9F%A5%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E7%9A%84%E5%AE%8C%E6%95%B4%E6%80%A7%E6%97%B6%EF%BC%8C%E5%AE%83%E4%B9%9F%E6%8A%A5%E5%91%8A%E4%BA%86%E5%9D%8F%E7%9A%84%E8%B6%85%E7%BA%A7%E5%9D%97%EF%BC%8C%E8%BF%99%E8%AE%A9%E6%88%91%E7%9B%B8%E4%BF%A1%E9%87%8D%E5%90%AF%E5%90%8E%E5%8F%AF%E8%83%BD%E6%9C%89%E4%BB%80%E4%B9%88%E4%B8%9C%E8%A5%BF%E6%8D%9F%E5%9D%8F%E4%BA%86%E3%80%82%20%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ee2fsck%20%2Fdev%2Fmapper%2Fencrypted%0Ae2fsck%201.44.5%20(15-Dec-2018)%0Aext2fs_open2%3A%20Bad%20magic%20number%20in%20super-block%0Ae2fsck%3A%20Superblock%20invalid%2C%20trying%20backup%20blocks...%0Ae2fsck%3A%20Bad%20magic%20number%20in%20super-block%20while%20trying%20to%20open%20%2Fdev%2Fmapper%2Fencrypted%0A%0AThe%20superblock%20could%20not%20be%20read%20or%20does%20not%20describe%20a%20valid%20ext2%2Fext3%2Fext4%0Afilesystem.%20%20If%20the%20device%20is%20valid%20and%20it%20really%20contains%20an%20ext2%2Fext3%2Fext4%0Afilesystem%20(and%20not%20swap%20or%20ufs%20or%20something%20else)%2C%20then%20the%20superblock%0Ais%20corrupt%2C%20and%20you%20might%20try%20running%20e2fsck%20with%20an%20alternate%20superblock%3A%0A%20%20%20%20e2fsck%20-b%208193%20%3CDEVICE%3E%0A%20or%0A%20%20%20%20e2fsck%20-b%2032768%20%3CDEVICE%3E%3C%2FDEVICE%3E%3C%2FDEVICE%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E5%A6%82%E6%9C%89%E4%BB%BB%E4%BD%95%E5%BB%BA%E8%AE%AE%E6%88%96%E6%83%B3%E6%B3%95%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1529848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E5%AE%89%E5%85%A8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2316427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DM-Crypt%20with%20CAAM%20key%20Encrypted%20Filesystem%20Corrupt%20After%20Reboot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2316427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%E6%82%A8%E5%A5%BD%EF%BC%8CNXP%E5%9B%A2%E9%98%9F%EF%BC%9A%3C%2FP%3E%3CP%20class%3D%22%22%3E%E6%88%91%E4%BB%AC%E6%9C%89%E4%B8%80%E5%8F%B0%E5%9F%BA%E4%BA%8E%20i.MX%208MP%20%E7%9A%84%E8%AE%BE%E5%A4%87%EF%BC%8C%E5%85%B6%E4%B8%AD%20dm-crypt%20%E5%8A%A0%E5%AF%86%E7%9A%84%20ext4%20%E5%88%86%E5%8C%BA%E5%9C%A8%E9%87%8D%E5%90%AF%E5%90%8E%E5%8F%98%E5%BE%97%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E3%80%82%E5%9C%A8%E8%AE%B8%E5%A4%9A%E8%AE%BE%E5%A4%87%E4%B8%8A%E9%83%A8%E7%BD%B2%E4%BA%86%E5%AE%8C%E5%85%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%2F%E6%98%A0%E5%83%8F%EF%BC%88%E7%9B%B8%E5%90%8C%E7%9A%84%20rootfs%20%E5%92%8C%E9%85%8D%E7%BD%AE%E6%B5%81%E7%A8%8B%EF%BC%89%EF%BC%8C%E8%80%8C%E4%B8%94%E8%BF%99%E4%BA%9B%E8%AE%BE%E5%A4%87%E8%82%AF%E5%AE%9A%E7%BB%8F%E5%8E%86%E4%BA%86%E9%80%9A%E7%94%B5%E5%91%A8%E6%9C%9F%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%87%BA%E7%8E%B0%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E4%BB%AC%E6%80%80%E7%96%91%E5%85%B3%E6%9C%BA%2F%E5%BC%80%E6%9C%BA%E4%BA%8B%E4%BB%B6%E5%8F%AF%E8%83%BD%E8%A7%A6%E5%8F%91%E4%BA%86%E8%AF%A5%E7%89%B9%E5%AE%9A%E8%AE%BE%E5%A4%87%E7%9A%84%E6%95%85%E9%9A%9C%EF%BC%8C%E4%BD%86%E6%98%AF%E5%9C%A8%E8%BF%99%E6%89%B9%E8%AE%BE%E5%A4%87%E4%B8%AD%EF%BC%8C%E4%BB%85%E9%9D%A0%E7%94%B5%E6%BA%90%E5%BE%AA%E7%8E%AF%E5%B9%B6%E4%B8%8D%E6%98%AF%E4%BB%80%E4%B9%88%E6%96%B0%E9%B2%9C%E4%BA%8B%E3%80%82%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%E8%A7%A3%E9%94%81%E6%B5%81%E7%A8%8B%E5%92%8C%E5%87%86%E7%A1%AE%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%23%20Only%20import%20key%20if%20keyhandle%20doesn't%20exist%0Aif%20%5B%20!%20-f%20%2Ftmp%2Fkeyhandle%20%5D%3B%20then%0A%20%20%20%20%23%20Import%20key%20using%20CAAM%0A%20%20%20%20caam-keygen%20import%20%2Fuboot%2Fblack_blob.bb%20keyhandle%0A%0A%20%20%20%20%23%20Add%20key%20to%20kernel%20keyring%0A%20%20%20%20cat%20%2Ftmp%2Fkeyhandle%20%7C%20keyctl%20padd%20logon%20logkey%3A%20%40s%0Afi%0A%0A%23%20Create%20dm-crypt%20mapping%0Admsetup%20-v%20create%20%24%7BENCRYPTED_NAME%7D%20--table%20%220%20%24(blockdev%20--getsz%20%24%7BDEVICE%7D)%20crypt%20capi%3Atk(cbc(aes))-plain%20%3A36%3Alogon%3Alogkey%3A%200%20%24%7BDEVICE%7D%200%201%20sector_size%3A512%22%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%E6%88%91%E4%BB%AC%E7%9C%8B%E5%88%B0%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3Edmsetup%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E6%88%90%E5%8A%9F%EF%BC%8C%E6%98%A0%E5%B0%84%E4%B8%BA%20ACTIVE%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3Emount%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E5%A4%B1%E8%B4%A5%EF%BC%8C%E6%8F%90%E7%A4%BA%20%22FS%20%E7%B1%BB%E5%9E%8B%E9%94%99%E8%AF%AF%2F%E8%B6%85%E7%BA%A7%E5%9D%97%E6%8D%9F%E5%9D%8F%22%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3Edmesg%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E6%98%BE%E7%A4%BA%EF%BC%9A%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3EEXT4-fs%20(dm-0)%EF%BC%9AVFS%EF%BC%9A%E6%89%BE%E4%B8%8D%E5%88%B0%20ext4%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3Ee2fsck%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E6%8A%A5%E5%91%8A%E8%B6%85%E7%BA%A7%E5%9D%97%E6%97%A0%E6%95%88%EF%BC%88%E6%9C%AA%E6%89%BE%E5%88%B0%E6%9C%89%E6%95%88%E7%9A%84%20ext2%2F3%2F4%EF%BC%89%3C%2FLI%3E%3C%2FUL%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CP%20class%3D%22%22%3E%E6%88%91%E4%BB%AC%E5%B7%B2%E7%BB%8F%E9%AA%8C%E8%AF%81%E4%BA%86%E8%AE%BE%E5%A4%87%E4%B8%8A%E7%9A%84%20CAAM%20%E9%BB%91%E8%89%B2%E6%96%91%E7%82%B9%E4%BB%8D%E7%84%B6%E4%B8%8E%E5%88%B6%E9%80%A0%E8%BF%87%E7%A8%8B%E4%B8%AD%E9%97%AA%E7%83%81%E7%9A%84%E7%9B%B8%E5%90%8C%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%85%B3%E9%94%AE%E6%9D%90%E6%96%99%E6%9C%AC%E8%BA%AB%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E5%8F%98%E5%8C%96%E3%80%82%E8%BF%99%E8%AE%A9%E6%88%91%E4%BB%AC%E6%80%80%E7%96%91%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%8A%A0%E5%AF%86%E5%88%86%E5%8C%BA%E5%9B%A0%E6%96%AD%E7%94%B5%E8%80%8C%E6%8D%9F%E5%9D%8F%EF%BC%8C%E6%88%96%3C%2FLI%3E%3CLI%3E%E4%B8%80%E4%B8%AA%E5%BE%AE%E5%A6%99%E7%9A%84%20CAAM%2FDM-crypt%2F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BB%85%E5%9C%A8%E9%87%8D%E5%90%AF%E6%88%96%E6%96%AD%E7%94%B5%E5%90%8E%E6%89%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%E7%8E%AF%E5%A2%83%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3ELinux%206.6.23%EF%BC%88%E5%9F%BA%E4%BA%8E%20Yocto%EF%BC%89%3C%2FLI%3E%3CLI%3E%E4%BD%BF%E7%94%A8%20CAAM%20%E5%AF%86%E9%92%A5%E5%AF%BC%E5%85%A5%20i.MX%208MP%20%E5%B9%B3%E5%8F%B0%3C%2FLI%3E%3CLI%3E%E4%BD%BF%E7%94%A8%20c%3CSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eapi%3A%20tk%20(%E5%AF%86%E7%A0%81%E5%9D%97%E9%93%BE%E6%8E%A5(CBC)%20(aes))%20%E5%88%9B%E5%BB%BA%E7%9A%84%20dm-crypt%20%E6%98%A0%E5%B0%84-plain%EF%BC%8Csector_size%3A%3C%2FSPAN%3E%20512%3C%2FLI%3E%3CLI%3Eext4%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3C%2FLI%3E%3CLI%3EeMMC%20%E5%AD%98%E5%82%A8%E5%99%A8%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%E4%BD%BF%E7%94%A8%E7%9A%84%20Yocto%20%E5%B1%82%2F%E4%BB%93%E5%BA%93%E5%93%88%E5%B8%8C%E5%80%BC%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%20%EF%BC%9A%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%2002eacd385eca7aa9cf25aaa61427aa9c126e0bc%20126e0bc%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3Emeta-openembedded%3C%2FSPAN%3E%3A%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ea72010b414ee3d73888ac9cb4e310e8f05e13aea%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3Emeta-arm%3C%2FSPAN%3E%20%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%EF%BC%9A8aa8a1f17f5b64bc691544f989f04f04f04fc83df98db98adb%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%85%83%E5%AE%89%E5%85%A8%EF%BC%9A11ea91192d%2043d7c2b0b95a93aa63ca7e7e73e73e73e73e3e3e38034%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3Emeta-timesys%3C%2FSPAN%3E%3A%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eb96d8de949939ad08094f71ed6ed4f88eaf41d5e%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3Emeta-virtualization%3C%2FSPAN%3E%3A%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E1a547c0aa0d75c4143cbb66de6e653d51cdc8bda%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3Emeta-clang%3C%2FSPAN%3E%3A%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E66414c17ae60e489bef9a97031323e92c247fbe1%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3Emeta-freescale%3C%2FSPAN%3E%3A%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E41b923e59e048b9b2942ff737a4ddac386954c62%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3Emeta-freescale-3rdparty%3C%2FSPAN%3E%3A%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E8b61684f0b1ba8bacdf3a69d993445e9791d4932%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Emeta-freescale-%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%82%EF%BC%9A158cc55b6ee30d09957b380859dba52c0f6af68d%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3Emeta-imx%3C%2FSPAN%3E%3A%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E239073c47124f41f46581871afbde643f48d6a3b%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3Emeta-nxp-%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8-%E5%8F%82%E8%80%83%E8%AE%BE%E8%AE%A1%3C%2FSPAN%3E%3A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E15d4eccdc503ea07634b869af0df7e4e2917ebf1%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%E5%90%91%E6%81%A9%E6%99%BA%E6%B5%A6%E6%8F%90%E5%87%BA%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3COL%3E%3CLI%3ECAAM%20%2B%20dm-crypt%EF%BC%88%E5%B8%A6%E6%9C%89%20c%3CSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eapi%3A%20tk%EF%BC%88cbc%EF%BC%88aes%EF%BC%89%EF%BC%89-plain%20%E7%9A%84%20CBC-AES%EF%BC%89%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E5%B7%B2%E7%9F%A5%E9%97%AE%E9%A2%98%EF%BC%8C%E8%BF%99%E4%BA%9B%E9%97%AE%E9%A2%98%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%AF%BC%E8%87%B4%E9%87%8D%E5%90%AF%2F%E6%96%AD%E7%94%B5%E5%90%8E%E6%97%A0%E6%B3%95%E6%81%A2%E5%A4%8D%E7%9A%84%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3C%2FSPAN%3E%E6%8D%9F%E5%9D%8F%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E5%9C%A8%20i.MX%208MP%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20CAAM%20%E6%94%AF%E6%8C%81%E7%9A%84%20dm-crypt%20%E6%98%AF%E5%90%A6%E6%9C%89%E6%9B%B4%E5%BC%BA%E5%A4%A7%E7%9A%84%E6%9B%B4%E6%96%B0%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%88%96%E6%8E%A8%E8%8D%90%E5%8A%A0%E5%AF%86%E6%96%B9%E6%A1%88%2F%E9%85%8D%E7%BD%AE%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E6%97%A2%E7%84%B6%E6%98%AF%20eMMC%EF%BC%8C%E6%82%A8%E5%AF%B9%E5%86%99%E5%85%A5%E5%8F%AF%E9%9D%A0%E6%80%A7%E8%AE%BE%E7%BD%AE%E3%80%81dm-crypt%20%E5%9D%97%E5%A4%A7%E5%B0%8F%E3%80%81%E5%88%B7%E6%96%B0%E8%A1%8C%E4%B8%BA%E3%80%81%E6%8C%82%E8%BD%BD%E9%80%89%E9%A1%B9%E6%88%96%E5%85%B6%E4%BB%96%E9%99%8D%E4%BD%8E%E6%96%AD%E7%94%B5%E5%90%8E%E6%8D%9F%E5%9D%8F%E5%87%A0%E7%8E%87%E7%9A%84%E7%BC%93%E8%A7%A3%E6%8A%80%E6%9C%AF%E6%9C%89%E4%BB%80%E4%B9%88%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%3C%2FLI%3E%3C%2FOL%3E%3CP%20class%3D%22%22%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%E6%9B%B4%E5%A4%9A%E6%97%A5%E5%BF%97%E6%88%96%E7%BB%86%E8%8A%82%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E6%8F%90%E4%BE%9B%E3%80%82%3C%2FP%3E%3CP%20class%3D%22%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1799951%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DM-Crypt%20with%20CAAM%20key%20Encrypted%20Filesystem%20Corrupt%20After%20Reboot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1799951%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206957%22%20target%3D%22_blank%22%3E%40nsleung%3C%2FA%3E%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E4%BD%A0%E8%83%BD%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E5%9C%A8%E8%BF%90%E8%A1%8C%20Yocto%20kirkstone%26amp%3B%20%E5%86%85%E6%A0%B8%205.15.x%20%E7%9A%84%20iMX8MP%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20CAAM%2Bdmcrypt%20%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%E4%BA%86%E5%AE%8C%E5%85%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1536419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DM-Crypt%20with%20CAAM%20key%20Encrypted%20Filesystem%20Corrupt%20After%20Reboot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1536419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%AF%8F%E6%AC%A1%E9%87%8D%E5%90%AF%E5%90%8E%EF%BC%8C%E6%88%91%E9%83%BD%E8%83%BD%E4%BB%8E%20blob%20%E4%B8%AD%E5%AF%BC%E5%85%A5%E5%AF%86%E9%92%A5%E5%B9%B6%E6%B7%BB%E5%8A%A0%E5%88%B0%20keyctl%20%E4%B8%AD%E3%80%82%E6%88%91%E8%BF%98%E5%8F%AF%E4%BB%A5%E5%9C%A8%E9%87%8D%E5%90%AF%E4%B9%8B%E5%89%8D%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E5%9D%97%E8%AE%BE%E5%A4%87%E5%88%9B%E5%BB%BA%E5%8A%A0%E5%AF%86%E7%9A%84%E8%AE%BE%E5%A4%87%E6%98%A0%E5%B0%84%E5%99%A8%E8%AE%BE%E5%A4%87%EF%BC%8C%E4%BD%86%E6%98%AF%E5%9C%A8%E5%AE%89%E8%A3%85%E6%97%B6%EF%BC%8C%E5%AE%83%E4%BC%9A%E6%8A%A5%E5%91%8A%20%E2%80%9C%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E6%8D%9F%E5%9D%8F%E2%80%9D%E3%80%82%E6%88%91%E9%9C%80%E8%A6%81%E5%9C%A8%E5%AE%89%E5%85%A8%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%90%AF%E5%8A%A8%E5%90%97%EF%BC%9F%E6%88%91%E4%B8%8D%E8%AE%A4%E4%B8%BA%E6%88%91%E5%9C%A8%E8%BF%99%E6%A0%B7%E5%81%9A%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1535969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DM-Crypt%20with%20CAAM%20key%20Encrypted%20Filesystem%20Corrupt%20After%20Reboot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1535969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E8%BF%90%E8%A1%8C%E4%BA%86%20caam-keygen%20%E5%AF%BC%E5%85%A5%EF%BC%9A%23%20.%2Fcaam-keygen%E5%AF%BC%E5%85%A5%20%2Fdata%2Fcaam%2Frandomkey.bb%20importKey%3C%2FP%3E%0A%3CP%3E%E8%BF%90%E8%A1%8C%E5%89%8D%23%20cat%20%2Fdata%2Fcaam%2FimportKey%20%7C%20keyctl%20padd%20logon%20logkey2%EF%BC%9A%40s%20%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E4%B8%BA%E6%AF%8F%E6%AC%A1%E5%BC%80%E6%9C%BA%E6%97%B6%E9%83%BD%E5%BF%85%E9%A1%BB%E9%87%8D%E6%96%B0%E6%B3%A8%E5%85%A5%E8%AF%A5%E5%AF%86%E9%92%A5%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%93%88%E7%BB%B4%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1535851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DM-Crypt%20with%20CAAM%20key%20Encrypted%20Filesystem%20Corrupt%20After%20Reboot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1535851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E6%88%91%E7%A1%AE%E5%AE%9E%E5%86%85%E7%BD%AE%E4%BA%86%E9%82%A3%E4%BA%9B%E9%A2%9D%E5%A4%96%E7%9A%84%E5%AE%9E%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1532434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DM-Crypt%20with%20CAAM%20key%20Encrypted%20Filesystem%20Corrupt%20After%20Reboot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1532434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206957%22%20target%3D%22_blank%22%3E%40nsleung%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%88%9A%E5%88%9A%E6%8C%89%E7%85%A7%E6%8C%87%E5%8D%97%E5%86%8D%E6%AC%A1%E8%BF%9B%E8%A1%8C%E4%BA%86%E5%AE%9E%E9%AA%8C%E3%80%82%E4%B8%8D%E5%AD%98%E5%9C%A8%E8%BF%99%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%BC%8F%E6%8E%89%E4%B8%80%E4%BA%9B%E5%BF%85%E8%A6%81%E7%9A%84%E5%B7%A5%E5%85%B7%EF%BC%8C%E5%A6%82%22coreutils%20keyutils%20lvm2%20e2fsprogs-mke2fs%20util-linux%22%22%20%EF%BC%8C%E5%85%B6%E4%B8%AD%E6%8C%87%E5%87%BA%3C%2FP%3E%0A%3CP%3E%E7%AC%AC%208%20%E9%83%A8%E5%88%86%E3%80%82%E9%80%9A%E8%BF%87%E7%BC%96%E8%BE%91%20conf%2Flocal.conf%20%E6%96%87%E4%BB%B6%E5%B9%B6%E8%BF%BD%E5%8A%A0%EF%BC%8C%E6%B7%BB%E5%8A%A0%E6%89%80%E9%9C%80%E7%9A%84%E7%89%88%E6%9C%AC%E5%B7%A5%E5%85%B7%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%93%88%E7%BB%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E
