DM-Crypt usage on i.MX Platforms without CAAM hardware IP
567件の閲覧回数
wooosaiiii
I am following a "DM-Crypt usage on i.MX Platforms without CAAM hardware IP" guide from NXP on i.MX93 board.
I am using the following steps:
modprobe dm-crypt
modprobe tee_crypto
modprobe trusted
export DEV=/dev/loop0
dd if=/dev/zero of=/data/encrypted.img bs=1M count=512
losetup -P $DEV /data/encrypted.img
export KEYNAME=dm_trustedkey
export KEY="$(keyctl add trusted $KEYNAME 'new 32' @s)"
keyctl pipe $KEY >/data/$KEYNAME.blob
keyctl list @s
export ALGO="capi:cbc-aes-tee-plain"
export BLOCKS=$(blockdev --getsz /dev/loop0)
export SECTOR_SIZE=4096
export TABLE="0 $BLOCKS crypt $ALGO :32:trusted:$KEYNAME 0 $DEV 0 1 sector_size:$SECTOR_SIZE"
dmsetup -v create encrypted --table "$TABLE"
However, my kernel crashes with the following OOPS:
[  713.174934] Unable to handle kernel paging request at virtual address ffff8000a1fca858
[  713.182908] Mem abort info:
[  713.185716]   ESR = 0x0000000096000006
[  713.189477]   EC = 0x25: DABT (current EL), IL = 32 bits
[  713.194786]   SET = 0, FnV = 0
[  713.197848]   EA = 0, S1PTW = 0
[  713.200993]   FSC = 0x06: level 2 translation fault
[  713.205873] Data abort info:
[  713.208762]   ISV = 0, ISS = 0x00000006, ISS2 = 0x00000000
[  713.214246]   CM = 0, WnR = 0, TnD = 0, TagAccess = 0
[  713.219296]   GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
[  713.224611] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000089bcd000
[  713.231309] [ffff8000a1fca858] pgd=10000000fffff003, p4d=10000000fffff003, pud=10000000ffffe003, pmd=0000000000000000
[  713.241943] Internal error: Oops: 0000000096000006 [#1] PREEMPT SMP
[  713.248199] Modules linked in: tee_crypto dm_crypt crct10dif_ce polyval_ce polyval_generic layerscape_edac_mod rtc_rv8803 at24 btnxpuart flexcan can_dev cfg80211 fuse overlay trusted
[  713.264459] CPU: 0 PID: 532 Comm: dmsetup Not tainted 6.6.52-lts-next-07235-gfdd32c7240b4 #1
[  713.272880] Hardware name: EVVA i.MX93 Gateway (DT)
[  713.277743] pstate: a0400009 (NzCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[  713.284694] pc : osq_lock+0x5c/0x134
[  713.288270] lr : __mutex_lock.constprop.0+0x1f0/0x540
[  713.293317] sp : ffff800083543750
[  713.296616] x29: ffff800083543750 x28: ffff000001e3417a x27: 0000000000000001
[  713.303743] x26: ffff000000a43e00 x25: ffff000005b7dbf0 x24: 00000000ffffffff
[  713.310864] x23: 0000000000000002 x22: fffffc000002e4c0 x21: fffffc000002e884
[  713.317988] x20: ffff800083543768 x19: fffffc000002e878 x18: 0000000000000001
[  713.325112] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[  713.332239] x14: 0000000000000000 x13: 01485ce3a37a7a58 x12: ed352f5eedb722c0
[  713.339360] x11: 0101010101010101 x10: fffffffffa67a3b3 x9 : 0000000000000000
[  713.346484] x8 : ffff800083543920 x7 : 0000000000000000 x6 : 000000000000003f
[  713.353608] x5 : 0000000000000040 x4 : 0000000003fffbff x3 : ffff800081fcc860
[  713.360732] x2 : ffff800081cf0d00 x1 : ffff00007fb98d00 x0 : fffffc000002e884
[  713.367859] Call trace:
[  713.370294]  osq_lock+0x5c/0x134
[  713.373518]  __mutex_lock.constprop.0+0x1f0/0x540
[  713.378215]  __mutex_lock_slowpath+0x14/0x20
[  713.382479]  mutex_lock+0x48/0x54
[  713.385787]  tee_device_get+0x20/0x6c
[  713.389444]  register_shm_helper+0x3c/0x2e8
[  713.393624]  tee_shm_register_kernel_buf+0x18/0x24
[  713.398408]  skcipher_setkey+0xe8/0x21c [tee_crypto]
[  713.403374]  cbc_skcipher_setkey+0x38/0x7c [tee_crypto]
[  713.408589]  crypto_skcipher_setkey+0x6c/0x124
[  713.413029]  crypt_setkey+0x104/0x22c [dm_crypt]
[  713.417658]  crypt_set_key+0x248/0x360 [dm_crypt]
[  713.422354]  crypt_ctr+0x634/0xfb8 [dm_crypt]
[  713.426705]  dm_table_add_target+0x218/0x380
[  713.430969]  table_load+0x140/0x3f0
[  713.434453]  ctl_ioctl+0x378/0x648
[  713.437851]  dm_ctl_ioctl+0x10/0x20
[  713.441334]  __arm64_sys_ioctl+0xac/0xf0
[  713.445252]  invoke_syscall+0x48/0x114
[  713.448996]  el0_svc_common.constprop.0+0xc0/0xe0
[  713.453693]  do_el0_svc+0x1c/0x28
[  713.457001]  el0_svc+0x40/0xe4
[  713.460055]  el0t_64_sync_handler+0x120/0x12c
[  713.464402]  el0t_64_sync+0x190/0x194
[  713.468066] Code: 340005c4 51000484 d000f723 91218063 (f864d863)
[  713.474147] ---[ end trace 0000000000000000 ]---
[  713.478800] note: dmsetup[532] exited with preempt_count 1
I am using 6.6.52_2.2.2 scarthgap release.
I think the problematic driver is drivers/tee/crypto/tee_skcipher.c.
Here is the output when loading the kernel module:
[  665.731673] tee_client_open_session failed, err: ffff0008
[  665.737206] tee_crypt algorithms registered in /proc/crypto
[  665.742835] driver 1.0 loaded.
The prerequisites from the document have been fulfilled in our BSP:
Prerequisites:
Ensure that a region of OCRAM is reserved to be accessed by Secure World only. This region is used to save cryptographic keys. Current OCRAM reserved regions:
For i.MX 93: 0x20518000 - 0x2051C000
For i.MX 95: 0x204BC000 - 0x204C0000
For i.MX 91: 0x204A0000 - 0x204A4000
For i.MX 943: 0x204BC000 - 0x204C0000
Make sure the following configurations are enabled in the kernel:
CONFIG_TEE_CRYPTO = m
CONFIG_DM_CRYPT = m
CONFIG_TRUSTED_KEYS = m
CONFIG_TRUSTED_KEYS_CAAM = n
CONFIG_TRUSTED_KEYS_TEE = y
In OP-TEE, check whether the following flags in the core/arch/arm/plat-imx/conf.mk platform specific section for which DM-crypt are enabled or not:
CFG_IMX_TRUSTED_ARM_CE = y
CFG_IN_TREE_EARLY_TAS += trusted_keys/f04a0fe7-1f5d-4b9b-abf7-619b85b4ce8c
Any ideas what might be an issue here?
タグ(4)
549件の閲覧回数
wooosaiiii
Fixed it. I forgot to update optee blob when rebuilding with CFG_IMX_TRUSTED_ARM_CE = y.
Can be closed.
%3CLINGO-SUB%20id%3D%22lingo-sub-2366863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECAAM%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2IP%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84i.MX%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E3%81%AEDM-Crypt%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2366863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFNXP%E3%81%AE%E3%80%8CCAAM%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2IP%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84i.MX%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E3%81%AEDM-Crypt%E3%81%AE%E4%BD%BF%E7%94%A8%E3%80%8D%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81i.MX93%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E4%BD%9C%E6%A5%AD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Emodprobe%20dm-crypt%0Amodprobe%20tee_crypto%0Amodprobe%20trusted%0A%0Aexport%20DEV%3D%2Fdev%2Floop0%0Add%20if%3D%2Fdev%2Fzero%20of%3D%2Fdata%2Fencrypted.img%20bs%3D1M%20count%3D512%0Alosetup%20-P%20%24DEV%20%2Fdata%2Fencrypted.img%0A%0Aexport%20KEYNAME%3Ddm_trustedkey%0Aexport%20KEY%3D%22%24(keyctl%20add%20trusted%20%24KEYNAME%20'new%2032'%20%40s)%22%0Akeyctl%20pipe%20%24KEY%20%26gt%3B%2Fdata%2F%24KEYNAME.blob%0Akeyctl%20list%20%40s%0A%0Aexport%20ALGO%3D%22capi%3Acbc-aes-tee-plain%22%0Aexport%20BLOCKS%3D%24(blockdev%20--getsz%20%2Fdev%2Floop0)%0Aexport%20SECTOR_SIZE%3D4096%0Aexport%20TABLE%3D%220%20%24BLOCKS%20crypt%20%24ALGO%20%3A32%3Atrusted%3A%24KEYNAME%200%20%24DEV%200%201%20sector_size%3A%24SECTOR_SIZE%22%0A%0Admsetup%20-v%20create%20encrypted%20--table%20%22%24TABLE%22%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%8C%E4%BB%A5%E4%B8%8B%E3%81%AEOOPS%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5B%20%20713.174934%5D%20Unable%20to%20handle%20kernel%20paging%20request%20at%20virtual%20address%20ffff8000a1fca858%0A%5B%20%20713.182908%5D%20Mem%20abort%20info%3A%0A%5B%20%20713.185716%5D%20%20%20ESR%20%3D%200x0000000096000006%0A%5B%20%20713.189477%5D%20%20%20EC%20%3D%200x25%3A%20DABT%20(current%20EL)%2C%20IL%20%3D%2032%20bits%0A%5B%20%20713.194786%5D%20%20%20SET%20%3D%200%2C%20FnV%20%3D%200%0A%5B%20%20713.197848%5D%20%20%20EA%20%3D%200%2C%20S1PTW%20%3D%200%0A%5B%20%20713.200993%5D%20%20%20FSC%20%3D%200x06%3A%20level%202%20translation%20fault%0A%5B%20%20713.205873%5D%20Data%20abort%20info%3A%0A%5B%20%20713.208762%5D%20%20%20ISV%20%3D%200%2C%20ISS%20%3D%200x00000006%2C%20ISS2%20%3D%200x00000000%0A%5B%20%20713.214246%5D%20%20%20CM%20%3D%200%2C%20WnR%20%3D%200%2C%20TnD%20%3D%200%2C%20TagAccess%20%3D%200%0A%5B%20%20713.219296%5D%20%20%20GCS%20%3D%200%2C%20Overlay%20%3D%200%2C%20DirtyBit%20%3D%200%2C%20Xs%20%3D%200%0A%5B%20%20713.224611%5D%20swapper%20pgtable%3A%204k%20pages%2C%2048-bit%20VAs%2C%20pgdp%3D0000000089bcd000%0A%5B%20%20713.231309%5D%20%5Bffff8000a1fca858%5D%20pgd%3D10000000fffff003%2C%20p4d%3D10000000fffff003%2C%20pud%3D10000000ffffe003%2C%20pmd%3D0000000000000000%0A%5B%20%20713.241943%5D%20Internal%20error%3A%20Oops%3A%200000000096000006%20%5B%231%5D%20PREEMPT%20SMP%0A%5B%20%20713.248199%5D%20Modules%20linked%20in%3A%20tee_crypto%20dm_crypt%20crct10dif_ce%20polyval_ce%20polyval_generic%20layerscape_edac_mod%20rtc_rv8803%20at24%20btnxpuart%20flexcan%20can_dev%20cfg80211%20fuse%20overlay%20trusted%0A%5B%20%20713.264459%5D%20CPU%3A%200%20PID%3A%20532%20Comm%3A%20dmsetup%20Not%20tainted%206.6.52-lts-next-07235-gfdd32c7240b4%20%231%0A%5B%20%20713.272880%5D%20Hardware%20name%3A%20EVVA%20i.MX93%20Gateway%20(DT)%0A%5B%20%20713.277743%5D%20pstate%3A%20a0400009%20(NzCv%20daif%20%2BPAN%20-UAO%20-TCO%20-DIT%20-SSBS%20BTYPE%3D--)%0A%5B%20%20713.284694%5D%20pc%20%3A%20osq_lock%2B0x5c%2F0x134%0A%5B%20%20713.288270%5D%20lr%20%3A%20__mutex_lock.constprop.0%2B0x1f0%2F0x540%0A%5B%20%20713.293317%5D%20sp%20%3A%20ffff800083543750%0A%5B%20%20713.296616%5D%20x29%3A%20ffff800083543750%20x28%3A%20ffff000001e3417a%20x27%3A%200000000000000001%0A%5B%20%20713.303743%5D%20x26%3A%20ffff000000a43e00%20x25%3A%20ffff000005b7dbf0%20x24%3A%2000000000ffffffff%0A%5B%20%20713.310864%5D%20x23%3A%200000000000000002%20x22%3A%20fffffc000002e4c0%20x21%3A%20fffffc000002e884%0A%5B%20%20713.317988%5D%20x20%3A%20ffff800083543768%20x19%3A%20fffffc000002e878%20x18%3A%200000000000000001%0A%5B%20%20713.325112%5D%20x17%3A%200000000000000000%20x16%3A%200000000000000000%20x15%3A%200000000000000000%0A%5B%20%20713.332239%5D%20x14%3A%200000000000000000%20x13%3A%2001485ce3a37a7a58%20x12%3A%20ed352f5eedb722c0%0A%5B%20%20713.339360%5D%20x11%3A%200101010101010101%20x10%3A%20fffffffffa67a3b3%20x9%20%3A%200000000000000000%0A%5B%20%20713.346484%5D%20x8%20%3A%20ffff800083543920%20x7%20%3A%200000000000000000%20x6%20%3A%20000000000000003f%0A%5B%20%20713.353608%5D%20x5%20%3A%200000000000000040%20x4%20%3A%200000000003fffbff%20x3%20%3A%20ffff800081fcc860%0A%5B%20%20713.360732%5D%20x2%20%3A%20ffff800081cf0d00%20x1%20%3A%20ffff00007fb98d00%20x0%20%3A%20fffffc000002e884%0A%5B%20%20713.367859%5D%20Call%20trace%3A%0A%5B%20%20713.370294%5D%20%20osq_lock%2B0x5c%2F0x134%0A%5B%20%20713.373518%5D%20%20__mutex_lock.constprop.0%2B0x1f0%2F0x540%0A%5B%20%20713.378215%5D%20%20__mutex_lock_slowpath%2B0x14%2F0x20%0A%5B%20%20713.382479%5D%20%20mutex_lock%2B0x48%2F0x54%0A%5B%20%20713.385787%5D%20%20tee_device_get%2B0x20%2F0x6c%0A%5B%20%20713.389444%5D%20%20register_shm_helper%2B0x3c%2F0x2e8%0A%5B%20%20713.393624%5D%20%20tee_shm_register_kernel_buf%2B0x18%2F0x24%0A%5B%20%20713.398408%5D%20%20skcipher_setkey%2B0xe8%2F0x21c%20%5Btee_crypto%5D%0A%5B%20%20713.403374%5D%20%20cbc_skcipher_setkey%2B0x38%2F0x7c%20%5Btee_crypto%5D%0A%5B%20%20713.408589%5D%20%20crypto_skcipher_setkey%2B0x6c%2F0x124%0A%5B%20%20713.413029%5D%20%20crypt_setkey%2B0x104%2F0x22c%20%5Bdm_crypt%5D%0A%5B%20%20713.417658%5D%20%20crypt_set_key%2B0x248%2F0x360%20%5Bdm_crypt%5D%0A%5B%20%20713.422354%5D%20%20crypt_ctr%2B0x634%2F0xfb8%20%5Bdm_crypt%5D%0A%5B%20%20713.426705%5D%20%20dm_table_add_target%2B0x218%2F0x380%0A%5B%20%20713.430969%5D%20%20table_load%2B0x140%2F0x3f0%0A%5B%20%20713.434453%5D%20%20ctl_ioctl%2B0x378%2F0x648%0A%5B%20%20713.437851%5D%20%20dm_ctl_ioctl%2B0x10%2F0x20%0A%5B%20%20713.441334%5D%20%20__arm64_sys_ioctl%2B0xac%2F0xf0%0A%5B%20%20713.445252%5D%20%20invoke_syscall%2B0x48%2F0x114%0A%5B%20%20713.448996%5D%20%20el0_svc_common.constprop.0%2B0xc0%2F0xe0%0A%5B%20%20713.453693%5D%20%20do_el0_svc%2B0x1c%2F0x28%0A%5B%20%20713.457001%5D%20%20el0_svc%2B0x40%2F0xe4%0A%5B%20%20713.460055%5D%20%20el0t_64_sync_handler%2B0x120%2F0x12c%0A%5B%20%20713.464402%5D%20%20el0t_64_sync%2B0x190%2F0x194%0A%5B%20%20713.468066%5D%20Code%3A%20340005c4%2051000484%20d000f723%2091218063%20(f864d863)%20%0A%5B%20%20713.474147%5D%20---%5B%20end%20trace%200000000000000000%20%5D---%0A%5B%20%20713.478800%5D%20note%3A%20dmsetup%5B532%5D%20exited%20with%20preempt_count%201%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AF6.6.52_2.2.2%E3%81%AEscarthgap%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AE%E3%81%82%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%20drivers%2Ftee%2Fcrypto%2Ftee_skcipher.c%20%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E9%9A%9B%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%5B%20%20665.731673%5D%20tee_client_open_session%20failed%2C%20err%3A%20ffff0008%0A%5B%20%20665.737206%5D%20tee_crypt%20algorithms%20registered%20in%20%2Fproc%2Fcrypto%0A%5B%20%20665.742835%5D%20driver%201.0%20loaded.%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E6%96%87%E6%9B%B8%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%89%8D%E6%8F%90%E6%9D%A1%E4%BB%B6%E3%81%AF%E3%80%81%E5%BD%93%E7%A4%BE%E3%81%AEBSP%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%E6%BA%80%E3%81%9F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%89%8D%E6%8F%90%E6%9D%A1%E4%BB%B6%EF%BC%9A%3CBR%20%2F%3E%20OCRAM%E3%81%AE%E4%B8%80%E9%83%A8%E9%A0%98%E5%9F%9F%E3%82%92Secure%20World%E3%81%AE%E3%81%BF%E3%81%8C%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E4%BA%88%E7%B4%84%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%81%AE%E9%A0%98%E5%9F%9F%E3%81%AF%E6%9A%97%E5%8F%B7%E9%8D%B5%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%81%AEOCRAM%E4%BA%88%E7%B4%84%E9%A0%98%E5%9F%9F%EF%BC%9A%3C%2FP%3E%3CP%3Ei.MX%2093%E3%81%AE%E5%A0%B4%E5%90%88%EF%BC%9A0x20518000%20-%200x2051C000%3CBR%20%2F%3E%20i.MX%2095%E3%81%AE%E5%A0%B4%E5%90%88%EF%BC%9A0x204BC000%20-%200x204C0000%3CBR%20%2F%3E%20i.MX%2091%E3%81%AE%E5%A0%B4%E5%90%88%EF%BC%9A0x204A0000%20-%200x204A4000%3CBR%20%2F%3E%20i.MX%20943%E3%81%AE%E5%A0%B4%E5%90%88%EF%BC%9A0x204BC000%20-%200x204C0000%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%20CONFIG_TEE_CRYPTO%20%3D%20m%3CBR%20%2F%3E%20CONFIG_DM_CRYPT%20%3D%20m%3CBR%20%2F%3E%20CONFIG_TRUSTED_KEYS%20%3D%20m%3CBR%20%2F%3E%20CONFIG_TRUSTED_KEYS_CAAM%20%3D%20n%3CBR%20%2F%3E%20CONFIG_TRUSTED_KEYS_TEE%20%3D%20y%3C%2FP%3E%3CP%3EOP-TEE%E3%81%A7%E3%80%81DM-crypt%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E5%9B%BA%E6%9C%89%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%82%E3%82%8Bcore%2Farch%2Farm%2Fplat-imx%2Fconf.mk%E5%86%85%E3%81%AE%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%95%E3%83%A9%E3%82%B0%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20CFG_IMX_TRUSTED_ARM_CE%20%3D%20y%3CBR%20%2F%3E%20CFG_IN_TREE_EARLY_TAS%20%2B%3D%20trusted_keys%2Ff04a0fe7-1f5d-4b9b-abf7-619b85b4ce8c%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%8B%E3%80%81%E4%BD%95%E3%81%8B%E5%BF%83%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2366958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DM-Crypt%20usage%20on%20i.MX%20Platforms%20without%20CAAM%20hardware%20IP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2366958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CSPAN%3ECFG_IMX_TRUSTED_ARM_CE%20%3D%20y%20%E3%81%A7%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81optee%20blob%20%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E5%BF%98%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%96%89%E3%81%98%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
