DDR3 clock connection
1,233件の閲覧回数
celiley
Which of the DRAM_SDCLK[1:0] pins should be used to use 2 blocks of ram (D0 to D31) in the imxqp ddr3 connection? Would it be enough to use DRAM_SDCLK_0 pins for both blocks?
1,197件の閲覧回数
nxf63675
Hi celiley,
The recommendation is to use both pins, you can check the hardware developers guide and our EVK's to check the configuration of both pins.
Israel.
