DDR3 - Swapping data lines + IMX6Q
9,997件の閲覧回数
stevenshi
hi Freescale:
our board design is base on SDB board,the OS is Android4.4.2.
my problem is in DDR3 Configration. our HW engineers
relayout the board for DDR3, the freeescale "Hareware
development guide" had said that "Swapping data lines"(please
check attachment_1). i found the SDB board has swap the data
lines in freescale board. but our HW engineers swap more data
lines. I want to konw the "flash_header.S" or other file need to
change in uboot??
how to change the software code to adjust the "If byte lane swapping was done, target DDR IC register read value must be
transposed according to the data line swapping"
the DDR3 is very important for our board, please give me some
suggest, thank you!
our board DDR3 chip is same as SDB. the data line different please check attachment_2/attachment_3/attachment_4/attachment_5
ラベル(7)
タグ(4)
5 返答(返信)
9,452件の閲覧回数
Yuri
  No need to change the software code in the case.
Yuri
9,452件の閲覧回数
stevenshi
hi Yuri Muhin:
    thank you for your reply, can you kindly give me explain about "If byte lane swapping was done, target DDR IC register read value must be transposed according to the data line swapping". in hardware develop guide it seem to need change code. but your reply is not need change code. i am very puzzled. otherwise other file need to modify??
9,452件の閲覧回数
stevenshi
hi Yuri Muhin:
       can you kindly give me some explains, thank you!
9,452件の閲覧回数
Yuri
   I did not hear about DDR IC using ( at least till now).
Yuri.
9,452件の閲覧回数
stevenshi
OK, thank you for your support!
