HI All,
I want to change imx6 DL DDR clk frequency to 410MHz, is it possible? can you pl. give example bare-metal ?
Is it possible to change DDR clk frequency run time?
Hi DHANUNJAY
it can be changed running code from iRAM for changing system PLL,
check sect.18.5.1.3.3 System PLL, sect.18.5.1.5.3 PLL clock change
i.MX6DQ Reference Manual: http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6DQRM.pdf.
In runtime the same procedure can be used. For example bare-metal please
create service request.
