DDR clk value
DDR clk value
582件の閲覧回数
dhanunjay
HI All,
I want to change imx6 DL DDR clk frequency to 410MHz, is it possible? can you pl. give example bare-metal ?
Is it possible to change DDR clk frequency run time?
ラベル(3)
455件の閲覧回数
igorpadykov
Hi DHANUNJAY
it can be changed running code from iRAM for changing system PLL,
check sect.18.5.1.3.3 System PLL, sect.18.5.1.5.3 PLL clock change
i.MX6DQ Reference Manual: http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6DQRM.pdf.
In runtime the same procedure can be used. For example bare-metal please
create service request.
