DART-MX95 DPDK bring up
已解决
跳至解决方案
1,895 次查看
dmonge
I am working on bringing up DPDK on the DART-MX95. I have been following the instructions in the i.MX Linux Reference Manual, specifically Chapter 10: Data Plane Development Kit (DPDK).
In section 10.5.2.2, the manual specifies the device tree (dtb) to be used for the i.MX 95 EVK. However, I couldn’t find any mention of a DPDK-supported device tree for the DART-MX95. Are there any recommended device tree configurations or specific modifications required for this platform?
Related Information:
  • I am using the nanbield release of Yocto.
  • The Yocto DPDK recipe comes from this source.
Additionally, I’ve encountered the following issues:
  1. In section 10.5.4.2.1, the command below results in an error:
# devlink dev param set pci/0002:00:08.0 name si_num_rings cmode driverinit value 0106
/tmp/devlink dev param set pci/0002:00:08.0 name si_num_rings cmode driverinit value 0106 kernel answers: No such device
  1. When attempting to set VF trust mode using the command:
# ip link set eth0 vf 0 trust on
RTNETLINK answers: Operation not supported
  1. My primary issue is that DPDK does not recognize the port bonded for DPDK usage. To test DPDK functionality, I follow these steps:
# dpdk-devbind.py --bind=uio_pci_generic 0002:00:00.0
# dpdk-devbind.py -s
Network devices using DPDK-compatible driver
0002:00:00.0 'Device e101' drv=uio_pci_generic unused=vfio-pci
Network devices using kernel driver
0002:00:08.0 'Device e101' if=eth1 drv=fsl_enetc4 unused=vfio-pci,uio_pci_generic *Active*
Other Network devices
0002:00:10.0 'Device e101' unused=vfio-pci,uio_pci_generic
No 'Baseband' devices detected
No 'Crypto' devices detected
No 'DMA' devices detected
No 'Eventdev' devices detected
No 'Mempool' devices detected
No 'Compress' devices detected
No 'Misc (rawdev)' devices detected
No 'Regex' devices detected
# /usr/share/dpdk/examples/dpdk-l2fwd
EAL: Detected CPU lcores: 6
EAL: Detected NUMA nodes: 1
EAL: Detected static linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: Scan for (fslmc) bus failed.
EAL: Selected IOVA mode 'PA'
EAL: VFIO support initialized
TELEMETRY: No legacy callbacks, legacy socket not created
MAC updating enabled
EAL: Error - exiting with code: 1
 Cause: No Ethernet ports - bye
Could you provide guidance on resolving these issues? Are there additional configurations or dependencies I need to address?
Thank you for your support.
标记 (3)
1 解答
1,876 次查看
joanxie
i.mx95 is still under preproduction, we don't have further information can share, pls contact local representative to get further help
Distributor Network | NXP Semiconductors
在原帖中查看解决方案
1 回复
1,877 次查看
joanxie
%3CLINGO-SUB%20id%3D%22lingo-sub-2010531%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDART-MX95%20DPDK%20%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2010531%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHi%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%8A%AA%E5%8A%9B%E5%9C%A8%20DART-MX95%20%E4%B8%8A%E5%90%AF%E5%8A%A8%20DPDK%E3%80%82%E6%88%91%E4%B8%80%E7%9B%B4%E9%81%B5%E5%BE%AA%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Freference-manual%2FIMX_REFERENCE_MANUAL.pdf%3F_gl%3D1*1epe6y1*_ga*ODM5MjIxMzM1LjE3MjkxMjA0ODU.*_ga_WM5LE0KMSH*MTczMzI1Njc4Ny4yNy4xLjE3MzMyNTkwNDYuMC4wLjA.%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CSPAN%3Ei.MX%20Linux%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%3C%2FSPAN%3E%3C%2FA%3E%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%3CSPAN%3E%EF%BC%8C%E7%89%B9%E5%88%AB%E6%98%AF%E7%AC%AC%2010%20%E7%AB%A0%EF%BC%9A%E6%95%B0%E6%8D%AE%E5%B9%B3%E9%9D%A2%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%20(DPDK)%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%9C%A8%E7%AC%AC%2010.5.2.2%20%E8%8A%82%E4%B8%AD%EF%BC%8C%E6%89%8B%E5%86%8C%E6%8C%87%E5%AE%9A%E4%BA%86%E7%94%A8%E4%BA%8E%20i.MX%2095%20EVK%20%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%20(dtb)%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E4%BB%BB%E4%BD%95%E5%85%B3%E4%BA%8E%20DART-MX95%20%E6%94%AF%E6%8C%81%20DPDK%20%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%E7%9A%84%E6%8F%90%E5%8F%8A%E3%80%82%E8%AF%A5%E5%B9%B3%E5%8F%B0%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E6%8E%A8%E8%8D%90%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%E9%85%8D%E7%BD%AE%E6%88%96%E6%89%80%E9%9C%80%E7%9A%84%E7%89%B9%E5%AE%9A%E4%BF%AE%E6%94%B9%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%9B%B8%E5%85%B3%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3CSPAN%3E%20Yocto%20%E7%9A%84%3C%2FSPAN%3E%3CI%3E%3CSPAN%3E%20nanbield%20%E7%89%88%E6%9C%AC%E3%80%82%3C%2FSPAN%3E%3C%2FI%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EYocto%20DPDK%20%E9%85%8D%E6%96%B9%E6%9D%A5%E8%87%AA%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmeta-imx%2Fblob%2Frel_imx_6.6.3_1.0.0%2Fmeta-imx-sdk%2Frecipes-extended%2Fdpdk%2Fdpdk_22.11.bb%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CSPAN%3E%E6%AD%A4%E6%9D%A5%E6%BA%90%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%88%91%E8%BF%98%E9%81%87%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CSPAN%3E%E5%9C%A8%E7%AC%AC%2010.5.4.2.1%20%E8%8A%82%E4%B8%AD%EF%BC%8C%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E5%AF%BC%E8%87%B4%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CBR%20%2F%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3E%23%20devlink%20dev%20param%20set%20pci%2F0002%3A00%3A08.0%20name%20si_num_rings%20cmode%20driverinit%20value%200106%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%2Ftmp%2Fdevlink%20dev%20param%20set%20pci%2F0002%3A00%3A08.0%20name%20si_num_rings%20cmode%20driverinit%20value%200106%20%3C%2FSPAN%3E%3CSPAN%3Ekernel%20answers%3A%20No%20such%20device%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CSPAN%3E%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E8%AE%BE%E7%BD%AE%20VF%20%E4%BF%A1%E4%BB%BB%E6%A8%A1%E5%BC%8F%E6%97%B6%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3E%23%20ip%20link%20set%20eth0%20vf%200%20trust%20on%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ERTNETLINK%20answers%3A%20Operation%20not%20supported%3C%2FSPAN%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3COL%3E%3CLI%3E%3CSPAN%3E%E6%88%91%E7%9A%84%E4%B8%BB%E8%A6%81%E9%97%AE%E9%A2%98%E6%98%AF%20DPDK%20%E6%97%A0%E6%B3%95%E8%AF%86%E5%88%AB%E4%B8%BA%20DPDK%20%E4%BD%BF%E7%94%A8%E8%80%8C%E7%BB%91%E5%AE%9A%E7%9A%84%E7%AB%AF%E5%8F%A3%E3%80%82%E4%B8%BA%E4%BA%86%E6%B5%8B%E8%AF%95%20DPDK%20%E5%8A%9F%E8%83%BD%EF%BC%8C%E6%88%91%E9%81%B5%E5%BE%AA%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CBR%20%2F%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3E%23%20dpdk-devbind.py%20--bind%3Duio_pci_generic%200002%3A00%3A00.0%3C%2FSPAN%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3E%23%20dpdk-devbind.py%20-s%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ENetwork%20devices%20using%20DPDK-compatible%20driver%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E0002%3A00%3A00.0%20'Device%20e101'%20drv%3Duio_pci_generic%20unused%3Dvfio-pci%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ENetwork%20devices%20using%20kernel%20driver%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E0002%3A00%3A08.0%20'Device%20e101'%20if%3Deth1%20drv%3Dfsl_enetc4%20unused%3Dvfio-pci%2Cuio_pci_generic%20*Active*%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EOther%20Network%20devices%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E0002%3A00%3A10.0%20'Device%20e101'%20unused%3Dvfio-pci%2Cuio_pci_generic%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ENo%20'Baseband'%20devices%20detected%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ENo%20'Crypto'%20devices%20detected%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ENo%20'DMA'%20devices%20detected%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ENo%20'Eventdev'%20devices%20detected%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ENo%20'Mempool'%20devices%20detected%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ENo%20'Compress'%20devices%20detected%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ENo%20'Misc%20(rawdev)'%20devices%20detected%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ENo%20'Regex'%20devices%20detected%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3E%23%20%2Fusr%2Fshare%2Fdpdk%2Fexamples%2Fdpdk-l2fwd%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EEAL%3A%20Detected%20CPU%20lcores%3A%206%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EEAL%3A%20Detected%20NUMA%20nodes%3A%201%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EEAL%3A%20Detected%20static%20linkage%20of%20DPDK%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EEAL%3A%20Multi-process%20socket%20%2Fvar%2Frun%2Fdpdk%2Frte%2Fmp_socket%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EEAL%3A%20Scan%20for%20(fslmc)%20bus%20failed.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EEAL%3A%20Selected%20IOVA%20mode%20'PA'%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EEAL%3A%20VFIO%20support%20initialized%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ETELEMETRY%3A%20No%20legacy%20callbacks%2C%20legacy%20socket%20not%20created%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EMAC%20updating%20enabled%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EEAL%3A%20Error%20-%20exiting%20with%20code%3A%201%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%26nbsp%3BCause%3A%20No%20Ethernet%20ports%20-%20bye%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%82%A8%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E8%A7%A3%E5%86%B3%E8%BF%99%E4%BA%9B%E9%97%AE%E9%A2%98%E7%9A%84%E6%8C%87%E5%AF%BC%EF%BC%9F%E6%88%91%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E8%A7%A3%E5%86%B3%E5%85%B6%E4%BB%96%E9%85%8D%E7%BD%AE%E6%88%96%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2010785%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ADART-MX95%20DPDK%20%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2010785%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ei.mx95%20%E4%BB%8D%E5%9C%A8%E9%A2%84%E7%94%9F%E4%BA%A7%E9%98%B6%E6%AE%B5%EF%BC%8C%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%E5%8F%AF%E4%BB%A5%E5%88%86%E4%BA%AB%EF%BC%8C%E8%AF%B7%E8%81%94%E7%B3%BB%E5%BD%93%E5%9C%B0%E4%BB%A3%E8%A1%A8%E4%BB%A5%E8%8E%B7%E5%8F%96%E8%BF%9B%E4%B8%80%E6%AD%A5%E5%B8%AE%E5%8A%A9%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fsample-and-buy%2Fdistributor-network%3ADISTRIBUTORS%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E5%88%86%E9%94%80%E5%95%86%E7%BD%91%E7%BB%9C%20%7C%20%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
