Custom Service is not running on IMX8QM-Android 9
10,543件の閲覧回数
vinothkumars
Senior Contributor IV
Dear NXP,
I am working on IMX8QM with Android 9. Currently, I am using imx-p9.0.0_2.1.1-auto-ga source. I added new service but, the service is not started automatically. So, I start the service manually then I got error,
mek_8q:/ #
mek_8q:/ # start usb-update
[ 192.968153] init: Received control message 'start' for 'usb-update' from pid: 3747 (start usb-update)
[ 192.977574] init: No such service 'usb-update' for ctl.start
Thanks & Regards,
VinothS,
Vinothkumar Sekar
ラベル(2)
9,778件の閲覧回数
vinothkumars
This is the final configuration working for me,
1. Set Selinux policy to permissive mode,
   Path : device/fsl/imx8q/mek_8q/BoardConfig.mk
   BOARD_KERNEL_CMDLINE += androidboot.selinux=permissive
 2. Create the service,
Path :  device/fsl/imx8q/mek_8q/init_car.rc
  # Start the service
  start usb-update
   # Provide the root permission to the script
  exec - root root system -- /system/bin/usb-update.sh
   # start the usb-update service
  service usb-update /system/bin/usb-update.sh
   class main
   user root
   oneshot
   seclabel u:r:init:s0
3. For Adding the custom service,
   Path : device/fsl/imx8q/mek_8q/mek_8q.mk
    PRODUCT_FULL_TREBLE_OVERRIDE := false
4. For execute the service,
    Path : device/fsl/imx8q/sepolicy/file_contexts
     /system/bin/usb-update.sh       u:object_r:init_exec:s0
Thanks & Regards,
VinothS,
Vinothkumar Sekar
8 返答(返信)
9,779件の閲覧回数
vinothkumars
  # Start the service
  start usb-update
   class main
   user root
   oneshot
Thanks & Regards,
VinothS,
Vinothkumar Sekar
9,778件の閲覧回数
vinothkumars
This is my configuration for lunch 36 ,
diff --git a/imx8q/mek_8q/BoardConfig.mk b/imx8q/mek_8q/BoardConfig.mk
index 1c681ed..5308567 100644
--- a/imx8q/mek_8q/BoardConfig.mk
+++ b/imx8q/mek_8q/BoardConfig.mk
@@ -165,6 +165,8 @@ else
BOARD_KERNEL_CMDLINE += androidboot.console=ttyLP0
endif
+BOARD_KERNEL_CMDLINE += androidboot.selinux=permissive
ifeq ($(TARGET_USERIMAGES_USE_UBIFS),true)
ifeq ($(TARGET_USERIMAGES_USE_EXT4),true)
$(error "TARGET_USERIMAGES_USE_UBIFS and TARGET_USERIMAGES_USE_EXT4 config open in same time, please only choose one target file system image")
diff --git a/imx8q/mek_8q/init_car.rc b/imx8q/mek_8q/init_car.rc
index aed7c7a..6a0becf 100644
--- a/imx8q/mek_8q/init_car.rc
+++ b/imx8q/mek_8q/init_car.rc
@@ -16,6 +16,9 @@ on early-init
on init
start watchdogd
# Support legacy paths
symlink /sdcard /mnt/sdcard
symlink /sdcard /storage/sdcard0
@@ -287,6 +290,15 @@ on property:sys.boot_completed=1
write /sys/class/drm/card0-HDMI-A-2/status on
write /sys/class/drm/card1-HDMI-A-2/status on
+# start the usb-update service
+service usb-update /system/bin/usb-update.sh
+ class main
+ user root
+ oneshot
+ seclabel u:r:usb-update:s0
on post-fs-data
# Set netd memlock rlimit to 8MB
setrlimit 8 8388608 8388608
diff --git a/imx8q/mek_8q/mek_8q.mk b/imx8q/mek_8q/mek_8q.mk
index 3d0263b..453581a 100644
--- a/imx8q/mek_8q/mek_8q.mk
+++ b/imx8q/mek_8q/mek_8q.mk
@@ -18,7 +18,7 @@ endif
PRODUCT_NAME := mek_8q
PRODUCT_DEVICE := mek_8q
-PRODUCT_FULL_TREBLE_OVERRIDE := true
+PRODUCT_FULL_TREBLE_OVERRIDE := false
# Copy device related config and binary to board
PRODUCT_COPY_FILES += \
@@ -33,8 +33,8 @@ PRODUCT_COPY_FILES += \
$(IMX_DEVICE_PATH)/privapp-permissions-imx.xml:$(TARGET_COPY_OUT_SYSTEM)/etc/permissions/privapp-permissions-imx.xml \
device/fsl/common/init/init.insmod.sh:$(TARGET_COPY_OUT_VENDOR)/bin/init.insmod.sh \
device/fsl/common/wifi/p2p_supplicant_overlay.conf:$(TARGET_COPY_OUT_VENDOR)/etc/wifi/p2p_supplicant_overlay.conf \
- device/fsl/common/wifi/wpa_supplicant_overlay.conf:$(TARGET_COPY_OUT_VENDOR)/etc/wifi/wpa_supplicant_overlay.conf
+ device/fsl/common/wifi/wpa_supplicant_overlay.conf:$(TARGET_COPY_OUT_VENDOR)/etc/wifi/wpa_supplicant_overlay.conf \
+ device/fsl/imx8q/mek_8q/usb-update.sh:/system/bin/usb-update.sh
ifeq ($(PRODUCT_IMX_CAR),true)
diff --git a/imx8q/sepolicy/init.te b/imx8q/sepolicy/init.te
index 9d2b22c..55645ef 100644
--- a/imx8q/sepolicy/init.te
+++ b/imx8q/sepolicy/init.te
@@ -19,3 +19,4 @@ allow init boot_block_device:lnk_file { relabelto };
allow init vbmeta_block_device:lnk_file { relabelto };
allow init sysfs_dm:file { write open };
allow init sysfs_devices_system_cpu:file { write };
+allow init usb-update_exec:process {transition};
diff --git a/imx8q/sepolicy/shell.te b/imx8q/sepolicy/shell.te
index ac32503..ba6188b 100644
--- a/imx8q/sepolicy/shell.te
+++ b/imx8q/sepolicy/shell.te
@@ -8,3 +8,4 @@ allow shell kernel:process { setsched };
dontaudit shell self:capability { dac_override };
allow shell vendor_file:file { read execute open getattr };
allow shell system_prop:property_service { set };
+allow shell usb-update_exec:file {read open};
Define sepolicy for usb-update ,
usb-update.te
# OBD service
type usb-update, domain;
type usb-update_exec, exec_type, file_type;
init_daemon_domain(usb-update)
domain_auto_trans(init, usb-update_exec, usb-update)
allow init usb-update:process transition;
Thanks & Regards,
VinothS.
Vinothkumar Sekar
9,778件の閲覧回数
vinothkumars
Please check the updated one,
emb-vinosek@IndVm:~/Documents/VINOTH/IndiEV-IMX8-A9/source/device/fsl/imx8q$ git diff
endif
index aed7c7a..697556a 100644
@@ -287,6 +287,16 @@ on property:sys.boot_completed=1
+ exec u:r:shell:s0 shell shell input log adb sdcard_rw sdcard_r net_bt_admin net_bt inet net_bw_stats -- /system/bin/sh /system/bin/usb-update.sh start -n com.example.package/com.example.package.MainActivity
+on post-fs
+ class main
+ user root
+ oneshot
on post-fs-data
diff --git a/imx8q/sepolicy/file_contexts b/imx8q/sepolicy/file_contexts
index e281b5c..25a68dc 100644
--- a/imx8q/sepolicy/file_contexts
+++ b/imx8q/sepolicy/file_contexts
@@ -19,6 +19,7 @@
/dev/diag u:object_r:diag_device:s0
/vendor/bin/wcnss_filter u:object_r:wcnss_filter_exec:s0
/vendor/app(/.*)? u:object_r:same_process_hal_file:s0
+/system/bin/usb-update.sh u:object_r: usb-update_exec:s0
/data/vendor/ss(/.*)? u:object_r:tee_data_file:s0
/data/vendor/.opencl-cache(/.*)? u:object_r:opencl_cache_file:s0
usb-update.te
# OBD service
Thanks & Regards,
VinothS.
Vinothkumar Sekar
9,778件の閲覧回数
vinothkumars
Still I am in the same issue. Let me know if I miss anything
Thanks & Regards,
VinothS,
Vinothkumar Sekar
9,778件の閲覧回数
vinothkumars
Custom service started probably but, I got error and service exit.
SELinux:  Context u:object_r:usb-update_exec:s0 is not valid (left unmapped)
[ 442.362348] init: Received control message 'start' for 'usb-update' from pid: 3538 (start usb-update)
[ 442.371635] init: starting service 'usb-update'...
[ 442.377693] init: cannot setexeccon('u:r:usb-update:s0') for usb-update: Invalid argument
mek_8q:/ # [ 442.386918] init: Service 'usb-update' (pid 3539) exited with status 6
Thanks & Regards,
VinothS,
Vinothkumar Sekar
9,778件の閲覧回数
vinothkumars
I am using "lunch 36". Is it give problem ?
VinothS,
Vinothkumar Sekar
9,778件の閲覧回数
diegoadrian
Unfortunately, the creation and implementation of Android services are out of the scope of our free support. You could go with professional service support. They could help you with this problem. I apologize for the inconvenience this could give you.
Professional Support for Processors and Microcontrollers | NXP
Diego.
9,778件の閲覧回数
vinothkumars
Thank you Diego.
VinothS,
Vinothkumar Sekar
