Cross compile Opencv for IMX53.
10,275 次查看
hoanganhngo
Hi everybody,I need to build Opencv2.2 for LTIB.I found it in FTF_CON_F0321_OpenCVontheimx53QuickStartBoard.pdf by eric gregori but it's not cleary.Can anyone else help me this problem?.I have been search all topic on imxcommunity,but it have no result.
11 回复数
7,751 次查看
FranciscoCarril
can you post that file?
7,751 次查看
hoanganhngo
Hi FranciscoCarrillo
I found some information in this document:
http://www.google.com.vn/url?sa=t&rct=j&q=&esrc=s&source=web&cd=10&ved=0CGcQFjAJ&url=http%3A%2F%2Fww...
At slide 69,70,71,there're some guides to Cross compile Opencv2.2 for imx53 QSB LTIB,but it's not cleary.imxcommunity.org changed there interface,so that I could't find what Eric Gregori said in slide 70.
I have been search all disscusion in IMX53 QSB topic but i'm still stuck in this.
Please help me in this problem,thank you so much.
7,751 次查看
FranciscoCarril
Take a look to this post
Re: Missing Content "Cross Compiling Opencv2.2 for I.MX53 QSB"
This might help  to solve your issue.
7,751 次查看
hoanganhngo
Thanks Francisco Alberto Carrillo Dominguez,I have been try this so many time.But It doesn't work.It cross about 58% when i run "make",there're an error in module high gui,i think.
7,751 次查看
FranciscoCarril
Ok, I am going to try myself and keep you posted.
7,751 次查看
hoanganhngo
Ohhhh yeahhhh....Thank you so much Francisco,thank you!!!....From the bottom of my heart.
7,751 次查看
FranciscoCarril
Re: Cross compile Opencv for IMX53.
hoanganh ngoLevel 1
Building CXX object modules/ml/CMakeFiles/opencv_ml.dir/src/gbt.o
/home/windows/Downloads/OpenCV-2.2.0/modules/ml/src/gbt.cpp: In member function 'virtual void CvGBTrees::find_gradient(int)':
/home/windows/Downloads/OpenCV-2.2.0/modules/ml/src/gbt.cpp:474: error: 'expl' was not declared in this scope
make[2]: *** [modules/ml/CMakeFiles/opencv_ml.dir/src/gbt.o] Error 1
make[1]: *** [modules/ml/CMakeFiles/opencv_ml.dir/all] Error 2
make: *** [all] Error 2
windows@ubuntu:~/Downloads/OpenCV-2.2.0$
This can be fixed with the following modification:
> Change line 14 ofOpenCV-2.2.0/modules/ml/src/gbt.cppfrom "Android" to "1"
- before -
#if Android
#define expl(x) exp(x)
#endif
- after -
#if 1
#endif
With this Change it should work for 100%
Good luck!!
Francisco
7,751 次查看
hoanganhngo
Hi Francisco.Thank you very much for your help,but I saw this errors in highgui at 58%.
pp:49:27: error: dc1394/dc1394.h: No such file or directory
/home/lucid/OpenCV22_CrossBuild/OpenCV-2.2.0/modules/highgui/src/cap_dc1394_v2.cpp:53: error: 'dc1394error_t' does not name a type
/home/lucid/OpenCV22_CrossBuild/OpenCV-2.2.0/modules/highgui/src/cap_dc1394_v2.cpp:126: error: 'dc1394error_t' does not name a type
/home/lucid/OpenCV22_CrossBuild/OpenCV-2.2.0/modules/highgui/src/cap_dc1394_v2.cpp:157: error: 'dc1394camera_t' was not declared in this scope
/home/lucid/OpenCV22_CrossBuild/OpenCV-2.2.0/modules/highgui/src/cap_dc1394_v2.cpp:157: error: 'camera' was not declared in this scope
I guess because I'm missing 2 patch. An error occurred when I try to down 2 patch from the link
wget http://imxcommunity.org/group/computervisionusingtheimx/forum/attachment/download?id=4103961%3AUploa...
Can you attach two patch used to build opencv for arm.Thank you so much.:D.
7,751 次查看
FranciscoCarril
This looks different, the patch will not fix your error.
  I think you have other problem.   What is your CMAKE line you are using?
7,751 次查看
hoanganhngo
This is CMAKE line i used:
cmake -DCMAKE_BUILD_TYPE=RELEASE -DCMAKE_INSTALL_PREFIX=/home/lucid/ltib/rootfs/usr/ -DCMAKE_TOOLCHAIN_FILE:PATH=${PWD}/../imx53.cmake -DCMAKE_FIND_ROOT_PATH=/home/lucid/ltib/rootfs/ -DWITH_FFMPEG=OFF -DWITH_GSTREAMER=OFF -DWITH_PYTHON=OFF -DWITH_GTK=OFF -DBUILD_EXAMPLES=ON ..
Where can i put imx53.cmake file.Do i need to modify this file.An error occurred when systems build highgui lib i think.
7,750 次查看
FranciscoCarril
Hello!
The patch #2 is lost
but I generated this new one, this should help.
Please put it in:
Go to directory
run:
patch < gbt.patch
