Cortex-M33 iMX93-EVK canfd example
1,066件の閲覧回数
Daniel_D1
Initial configuration:
BMODE - M33 Infinite Loop
I am trying to run mcimx93evk_canfd_interrupt_transfer example.
I have a problem when sending data from node A, the code stops for me on the line:
            while (!txComplete)
After a more detailed analysis, I noticed that the callback function was not called:
 * @brief FlexCAN Call Back function
static FLEXCAN_CALLBACK(flexcan_callback)
Why this example doesn't work?
1,032件の閲覧回数
joanxie
did you disable CAN in the dts file before you use this for M core?
