Config Tools v26.06
Config Tools v26.06
906件の閲覧回数
simonng
Hi NXP,
I upgraded the Config Tools from v25.3 to v25.6.
When I ran the DDR Test, I got the following error. It has no problem if I use v25.3 to run the test. How to solve this problem with the latest v25.6?
Simon
################### Result for: phy_init ###### Run 1 #############################################Microsoft Windows [Version 10.0.26100.4652]
(c) Microsoft Corporation. All rights reserved.
C:\nxp\i.MX_CFG_25.06\bin>prompt test-prefix :
test-prefix : "C:/nxp/i.MX_CFG_25.06/bin/python3/python" "C:/nxp/i.MX_CFG_25.06/bin/python3/memtool/memtool_entry.py" -t "runtest" -d "C:/ProgramData/NXP/mcu_data_25.06/processors/MIMX9596xxxxN/ksdk2_0/mem_validation/ddrc" -p "C:/Users/eg_fw/AppData/Local/Temp/mem_validation/phy_training_phy_test_0_0_.log" -l INFO "C:/Users/eg_fw/AppData/Local/Temp/mem_validation/connect.json" "C:/Users/eg_fw/AppData/Local/Temp/mem_validation/test.json" "C:/Users/eg_fw/AppData/Local/Temp/mem_validation/phy.json" "C:/Users/eg_fw/AppData/Local/Temp/mem_validation/ddrc_registers.json" "C:/Users/eg_fw/AppData/Local/Temp/mem_validation/ddrc_config.json" "C:/Users/eg_fw/AppData/Local/Temp/mem_validation/ddrc_config_in.json"
INFO memtool.utils.helper *****C:/Users/eg_fw/AppData/Local/Temp/mem_validation/connect.json
INFO memtool.utils.helper *****C:/Users/eg_fw/AppData/Local/Temp/mem_validation/test.json
INFO memtool.utils.helper *****C:/Users/eg_fw/AppData/Local/Temp/mem_validation/phy.json
INFO memtool.utils.helper *****C:/Users/eg_fw/AppData/Local/Temp/mem_validation/ddrc_registers.json
INFO memtool.utils.helper *****C:/Users/eg_fw/AppData/Local/Temp/mem_validation/ddrc_config.json
INFO memtool.utils.helper *****C:/Users/eg_fw/AppData/Local/Temp/mem_validation/ddrc_config_in.json
INFO memtool.processor.imx9.imx9_processor Xls mapping load time 0.037542
INFO memtool.processor.imx9.imx9_processor Config time 0.000289
INFO memtool.processor.imx9.imx9_processor DS file time 0.281771
INFO memtool.phyinit.phy_init Run phyinit for 2024.09\lpddr5
INFO memtool.comm.serial_channel Using serial: COM27
ERROR memtool.common.base_test Application load ended with exception: Download incomplete due to configuration error!
892件の閲覧回数
pengyong_zhang
Hi @simonng
For the latest Config Tool version 25.06, we only support imx95 chip B0 version, i think your chip is also A1 or A0 version, you need to use the before version tool run the DDR relate test of i.MX95.
B.R
%3CLINGO-SUB%20id%3D%22lingo-sub-2138789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%A8%AD%E5%AE%9A%E3%83%84%E3%83%BC%E3%83%AB%20v26.06%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3EConfig%20Tools%20%E3%82%92%20v25.3%20%E3%81%8B%E3%82%89%20v25.6%20%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EDDR%20%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82v25.3%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%9C%80%E6%96%B0%E3%81%AE%20v25.6%20%E3%81%A7%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B5%E3%82%A4%E3%83%A2%E3%83%B3%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%23%23%20Result%20for%3A%20phy_init%20%23%23%20%23%23%20%23%23%20Run%201%20%23%23%20%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23Microsoft%20Windows%20%5B%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%2010.0.26100.4652%5D%3C%2FP%3E%3CP%3E(c)%20%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%BD%E3%83%95%E3%83%88%E3%82%B3%E3%83%BC%E3%83%9D%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%82%E7%84%A1%E6%96%AD%E8%BB%A2%E8%BC%89%E3%82%92%E7%A6%81%E3%81%98%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EC%3A%5Cnxp%5Ci.MX_CFG_25.06%5Cbin%26gt%3B%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%83%86%E3%82%B9%E3%83%88%E3%83%97%E3%83%AC%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%3A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E3%83%97%E3%83%AC%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%3A%20%22C%3A%2Fnxp%2Fi.MX_CFG_25.06%2Fbin%2Fpython3%2Fpython%22%E3%80%8CC%3A%2Fnxp%2Fi.MX_CFG_25.06%2Fbin%2Fpython3%2Fmemtool%2Fmemtool_entry.py%E3%80%8D-t%20%22runtest%22%20-d%20%22C%3A%2FProgramData%2FNXP%2Fmcu_data_25.06%2Fprocessors%2FMIMX9596xxxxN%2Fksdk2_0%2Fmem_validation%2Fddrc%22-p%20%22C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fphy_training_phy_test_0_0_.log%22-l%20INFO%20%22C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fconnect.json%22%20%22C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Ftest.json%22%22C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fphy.json%22%22C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_registers.json%22%22C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config.json%22%22C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config_in.json%22%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.utils.helper%20*****C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fconnect.json%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.utils.helper%20*****C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Ftest.json%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.utils.helper%20*****C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fphy.json%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.utils.helper%20*****C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_registers.json%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.utils.helper%20*****C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config.json%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.utils.helper%20*****C%3A%2FUsers%2Feg_fw%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config_in.json%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.processor.imx9.imx9_processorXls%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E6%99%82%E9%96%93%200.037542%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.processor.imx9.imx9_processor%E8%A8%AD%E5%AE%9A%E6%99%82%E9%96%93%200.000289%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.processor.imx9.imx9_processorDS%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E6%99%82%E9%96%93%200.281771%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.phyinit.phy_init2024.09%5Clpddr5%20%E3%81%AE%20phyinit%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.comm.serial_channel%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E4%BD%BF%E7%94%A8%3A%20COM27%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%20memtool.common.base_test%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E4%BE%8B%E5%A4%96%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%E6%A7%8B%E6%88%90%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%81%9F%E3%82%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Config%20Tools%20v26.06%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F105311%22%20target%3D%22_blank%22%3E%40simonng%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%9C%80%E6%96%B0%E3%81%AE%20Config%20Tool%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%2025.06%20%E3%81%A7%E3%81%AF%E3%80%81imx95%20%E3%83%81%E3%83%83%E3%83%97%20B0%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%81%BF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%81%E3%83%83%E3%83%97%E3%82%82%20A1%20%E3%81%BE%E3%81%9F%E3%81%AF%20A0%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E4%BB%A5%E5%89%8D%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20i.MX95%20%E3%81%AE%20DDR%20%E9%96%A2%E9%80%A3%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
