Concurrent DDR writes from SDMA and AP Core
rolfw
how are concurrent writes from SDMA FU Bursts and writes from A9 Core to non-cached memory  are arbitrated? Is it possible to give SDMA writes prio over A9 Core writes?
Rolf
Hi Rolf
arbitration is handled by nic-301 (its documentation can be found on arm.com)
please check Chapter 45 Network Interconnect Bus System (NIC-301) i.MX6DQ Reference Manual
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6DQRM.pdf
rolfw
Perfect!
Great thanks!
Rolf
Hi Rolf
