Compilation Error for SABERSD_6DQ
vinothpenati
Hi all,
      I am working on Android marshmallow BSP 6.0.1_2.1.0, I am getting the following error while compiling the BSP.
make: *** No rule to make target `out/target/product/sabresd_6dq/obj/SHARED_LIBRARIES/libstlport_intermediates/export_includes', needed by `out/target/product/sabresd_6dq/obj/EXECUTABLES/powerdebug_intermediates/import_includes'.  Stop.
      I followed the same BSP version 6.0.1_2.1.0 document for make procedure and all. If any one having idea about this kind of error please reply me.
VINOTH P B
Labels (2)
gusarambula
Hello Vinoth Penati,
Are you still having this issue? I would like to confirm that you’re following the Android User’s Guide for this BSP. Did you received an error when patching the source code? Sometimes there are permission issues and the patching script still outputs a success message so it’s always good to be careful with that.
In the meantime I’ll try to replicate this issue just to make sure it’s not a problem with the repository.
