Check available functionality of DSP block - imx8ulp
1,788 次查看
dhruvinrajpura
I am using imx8ulp 9x9 and working on audio processing stuffs, I want to check which in build audio processing functionality imx8ulp's DSP block is providing? and if I want to test some audio processing example what are ways? Can I do it from M-Core ot A-Core and how I can perform? how it process audio and what it can do with audio?
5 回复数
1,766 次查看
JorgeCas
For DSP testing please take a look in the next link:
i.MX DSP User's Guide
Best regards.
1,763 次查看
dhruvinrajpura
Hello @JorgeCas
Thanks for reply, I already checked dsp guide, but instead I want list of functionality that support on dsp block for audio processing, like wake word detection etc, can you provide list of functionality that dsp block is supporting for audio processing?
1,745 次查看
JorgeCas
Please check the Voice Intelligent Technology (VIT) library and voice control software package that is delivered via the MCUXpresso SDK or Linux BSP.
Voice Intelligent Technology | NXP Semiconductors
For VIT User Guide, you can find it in the next link.
Best regards.
1,714 次查看
dhruvinrajpura
@JorgeCas
Thanks for sharing, I checked that VIT can help in controlling IOT device mainly,
In my project I want audio processing capabilities like audio to text <> text to audio conversion, and chatbot kind of thing I want to implement, Do we have that kind of solution available or that type of functionality is there?
1,708 次查看
JorgeCas
As you mention, for Voice applications NXP develops a complete environment that helps customers to control IoT devices using WakeWords.
Here is a fact sheet that will help you to get familiarized with these products.
NXP Software For Voice Processing at the Edge
For your application speech to text NXP does not provide any specific library or product that can help you. However, I think you can use the product VoiceSeeker or VIT API's, these libraries will help you to achieve a great source with acoustic echo cancellation to feed your speech to text conversion library.
In case, you consider using VoiceSeeker with AEC, please contact with the Voice specialized team at the following mail:
[email protected]
Best regards.
