Can NXP provide some examples of artificial intelligence based on IMX8MQ?
ximenbingmeng
I saw some cases of artificial intelligence based on the IMX8MQ chip online and would like to inquire if it can be implemented? For example, facial recognition, etc; Are there any commonly used existing models? Are there any reference cases provided? So how should I modify it on the existing system? Is it necessary to compile the system through yocto?
Bio_TICFSL
You can view the Machine learning user guide document
https://www.nxp.com/docs/en/user-guide/IMX-MACHINE-LEARNING-UG.pdf
it show you hoy to use the eIQ package and use AI.
