Camera streaming issue for imx8mp in debian
2,620件の閲覧回数
Neha_V
I am validating ov5640 camera in Debian 12 for imx8mp .
&i2c3 { /* MIPI_CSI0: OV5640 Camera */
ov5640_0: ov5640_mipi@3c {
compatible = "ovti,ov5640";
reg = <0x3c>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_csi0_rst>, <&pinctrl_csi_mclk>;
clocks = <&clk IMX8MP_CLK_IPP_DO_CLKO1>;
clock-names = "xclk";
assigned-clocks = <&clk IMX8MP_CLK_IPP_DO_CLKO1>;
assigned-clock-parents = <&clk IMX8MP_CLK_24M>;
assigned-clock-rates = <24000000>;
csi_id = <0>;
reset-gpios = <&gpio1 10 GPIO_ACTIVE_LOW>;
mclk = <24000000>;
mclk_source = <0>;
mipi_csi;
status = "okay";
port {
ov5640_mipi_0_ep: endpoint {
remote-endpoint = <&mipi_csi0_ep>;
data-lanes = <1 2>;
clock-lanes = <0>;
&i2c2 {
sgtl5000_codec: sgtl5000@a { /* SGTL5000: Audio Codec */
compatible = "fsl,sgtl5000";
reg = <0xa>;
#sound-dai-cells = <0>;
clocks = <&audioclk>;
VDDA-supply = <&reg_1p8v>;
VDDIO-supply = <&reg_1p8v>;
VDDD-supply = <&reg_1p5v>;
status = "okay";
ov5640_1: ov5640_mipi@3c {
reg = <0x3c>;
csi_id = <0>;
mclk = <24000000>;
mclk_source = <0>;
mipi_csi;
status = "okay";
port {
ov5640_mipi_1_ep: endpoint {
remote-endpoint = <&mipi_csi1_ep>;
data-lanes = <1 2>;
clock-lanes = <0>;
i have added the dts nodes
in my debug terminal below prints are observed
root@unknown:~# dmesg | grep "csi"
[ 0.064823] platform 32e40000.csi: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a40000/ov5640_mipi@3c
[ 0.065165] platform 32e50000.csi: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a30000/ov5640_mipi@3c
[ 1.996245] mxc-mipi-csi2-sam 32e40000.csi: supply mipi-phy not found, using dummy regulator
[ 2.005128] : mipi_csis_imx8mp_phy_reset, No remote pad found!
[ 2.017646] mxc-mipi-csi2-sam 32e40000.csi: lanes: 2, hs_settle: 13, clk_settle: 2, wclk: 1, freq: 500000000
[ 2.027763] mxc-mipi-csi2-sam 32e50000.csi: supply mipi-phy not found, using dummy regulator
[ 2.036544] : mipi_csis_imx8mp_phy_reset, No remote pad found!
[ 2.042435] mxc-mipi-csi2-sam 32e50000.csi: lanes: 2, hs_settle: 13, clk_settle: 2, wclk: 1, freq: 266000000
root@unknown:~# dmesg | grep "ov56"
[ 2.474968] ov5640 1-003c: supply DOVDD not found, using dummy regulator
[ 2.481826] ov5640 1-003c: supply AVDD not found, using dummy regulator
[ 2.488491] ov5640 1-003c: supply DVDD not found, using dummy regulator
[ 2.495702] ov5640 1-003c: ov5640_write_reg: error: reg=3008, val=82
[ 2.528236] ov5640 1-003c: ov5640_read_reg: error: reg=300a
[ 2.533833] ov5640 1-003c: ov5640_check_chip_id: failed to read chip identifier
[ 2.548572] ov5640 2-003c: supply DOVDD not found, using dummy regulator
[ 2.555433] ov5640 2-003c: supply AVDD not found, using dummy regulator
[ 2.562095] ov5640 2-003c: supply DVDD not found, using dummy regulator
[ 2.569525] ov5640 2-003c: ov5640_write_reg: error: reg=3008, val=82
[ 2.602054] ov5640 2-003c: ov5640_read_reg: error: reg=300a
[ 2.607645] ov5640 2-003c: ov5640_check_chip_id: failed to read chip identifier
root@unknown:~#
even in the i2c the camera slave is not detecting
5 返答(返信)
2,192件の閲覧回数
Neha_V
i am working on debian 12 based on Linux 6.6.52 kernel
2,192件の閲覧回数
Neha_V
i am using imx8mp processor based custom board. The above error prints are solved.
i am testing ov5640 camera on imx8mp .I tried the cheese application for this camera but i am getting the below prints
[ 172.691637] mxc-mipi-csi2.0: unsupported csi-sam command -1068476902
i tried through command line
but it is not streaming the below error is observed
debian@unknown:~$ gst-launch-1.0 v4l2src device=/dev/video4 ! videoconvert ! ximagesink
Authorization required, but no authorization protocol specified
ERROR: from element /GstPipeline:pipeline0/GstXImageSink:ximagesink0: Could not initialise X output
Additional debug info:
../sys/ximage/ximagesink.c(1150): gst_x_image_sink_xcontext_get (): /GstPipeline:pipeline0/GstXImageSink:ximagesink0:
Could not open display
ERROR: pipeline doesn't want to preroll.
Failed to set pipeline to PAUSED.
Setting pipeline to NULL ...
Freeing pipeline ...
but if i start Weston the camera streaming is working but i don't want this method
i want to test the camera through cheese application and and through commmand line normally
2,502件の閲覧回数
Neha_V
Hello
We are using the imx8mp evk based custom board . The same source with the linux it is working but only with the debian it is not working.
Regards ,
Neha
2,549件の閲覧回数
mary58
The failure to detect the OV5640 camera in Debian on i.MX8MP, indicated by the critical errors supply DOVDD not found and failed to read chip identifier, stems from an incomplete Device Tree Source (DTS) configuration. The sensor is not responding on the I2C bus because it is likely not powered up. To fix this, you must explicitly define and link the OV5640's required voltage rails (DOVDD-supply, AVDD-supply, DVDD-supply) to the appropriate regulator nodes (e.g., &reg_1p8v, &reg_2p8v) within both camera nodes in the DTS file, ensuring the sensor receives power before the driver attempts I2C communication.
2,575件の閲覧回数
AldoG
Are you using EVK/FRDM board?
We already have support for the OV5640 by default on our Debian release, so no modification should be needed if using EVK/FRDM.
Best regards/Saludos,
Aldo.
%3CLINGO-SUB%20id%3D%22lingo-sub-2203482%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDebian%20%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%20imx8mp%20%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203482%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AFDebian%2012%E3%81%A7imx8mp%E7%94%A8%E3%81%AEov5640%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%26amp%3Bi2c3%20%7B%20%2F*%20MIPI_CSI0%3A%20OV5640%20%E3%82%AB%E3%83%A1%E3%83%A9%20*%2F%3CBR%20%2F%3E%20ov5640_0%3A%20ov5640_mipi%403c%20%7B%3CBR%20%2F%3E%20%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22ovti%E3%80%81ov5640%22%3B%3CBR%20%2F%3E%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%26lt%3B0x3c%26gt%3B%20%EF%BF%BD%3B%3CBR%20%2F%3E%20pinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%3B%3CBR%20%2F%3E%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_csi0_rst%26gt%3B%E3%80%81%26lt%3B%26amp%3Bpinctrl_csi_mclk%26gt%3B%3B%3CBR%20%2F%3E%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_IPP_DO_CLKO1%26gt%3B%3B%3CBR%20%2F%3E%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%90%8D%3CBR%20%2F%3E%20%3D%20%22xclk%22%3B%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_IPP_DO_CLKO1%26gt%3B%3B%3CBR%20%2F%3E%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A6%AA%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_24M%26gt%3B%3B%3CBR%20%2F%3E%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%88%26lt%3B24000000%26gt%3B%20%3D%3B%3CBR%20%2F%3E%20csi_id%20%3D%3B%26lt%3B0%26gt%3B%20%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88gpios%20%3D%20%26lt%3B%26amp%3Bgpio1%2010%20GPIO_ACTIVE_LOW%26gt%3B%3B%3CBR%20%2F%3E%20mclk%26lt%3B24000000%26gt%3B%20%3D%3B%3CBR%20%2F%3E%20mclk_source%26lt%3B0%26gt%3B%20%3D%3B%3CBR%20%2F%3E%20mipi_csi%3B%3CBR%20%2F%3E%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FP%3E%3CP%3E%E3%83%9D%E3%83%BC%E3%83%88%20%7B%3CBR%20%2F%3E%20ov5640_mipi_0_ep%3A%20%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%7B%3CBR%20%2F%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%20%26lt%3B%26amp%3Bmipi_csi0_ep%26gt%3B%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%B3%20%3D%20%26lt%3B1%202%26gt%3B%3B%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%B3%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%26amp%3Bi2c2%20%7B%3CBR%20%2F%3E%20sgtl5000_codec%3A%20sgtl5000%40a%20%7B%20%2F*%20SGTL5000%3A%20%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%20*%2F%3CBR%20%2F%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22fsl%2Csgtl5000%22%3B%3CBR%20%2F%3E%20reg%20%3D%20%26lt%3B0xa%26gt%3B%3B%3CBR%20%2F%3E%20%23sound-dai-cells%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Baudioclk%26gt%3B%3B%3CBR%20%2F%3E%20VDDA%E9%9B%BB%E6%BA%90%20%3D%20%26lt%3B%26amp%3Breg_1p8v%26gt%3B%3B%3CBR%20%2F%3E%20VDDIO%E9%9B%BB%E6%BA%90%20%3D%20%26lt%3B%26amp%3Breg_1p8v%26gt%3B%3B%3CBR%20%2F%3E%20VDDD%E9%9B%BB%E6%BA%90%20%3D%20%26lt%3B%26amp%3Breg_1p5v%26gt%3B%3B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3Eov5640_1%3A%20ov5640_mipi%403c%20%7B%3CBR%20%2F%3E%20%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22ovti%E3%80%81ov5640%22%3B%3CBR%20%2F%3E%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%26lt%3B0x3c%26gt%3B%20%EF%BF%BD%3B%3CBR%20%2F%3E%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_IPP_DO_CLKO1%26gt%3B%3B%3CBR%20%2F%3E%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%90%8D%20%3D%20%22xclk%22%3B%3CBR%20%2F%3E%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_IPP_DO_CLKO1%26gt%3B%3B%3CBR%20%2F%3E%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A6%AA%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_24M%26gt%3B%3B%3CBR%20%2F%3E%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%88%26lt%3B24000000%26gt%3B%20%3CBR%20%2F%3E%26lt%3B0%26gt%3B%3CBR%20%2F%3E%3D%3B%26lt%3B24000000%26gt%3B%20%3CBR%20%2F%3E%26lt%3B0%26gt%3B%3CBR%20%2F%3E%3CBR%20%2F%3Ecsi_id%20%3D%3B%20mclk%20%3D%3B%20mclk_source%20%3D%3B%20mipi_csi%3B%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FP%3E%3CP%3E%E3%83%9D%E3%83%BC%E3%83%88%20%7B%3CBR%20%2F%3E%20ov5640_mipi_1_ep%3A%20%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%7B%3CBR%20%2F%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%20%26lt%3B%26amp%3Bmipi_csi1_ep%26gt%3B%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%B3%20%3D%20%26lt%3B1%202%26gt%3B%3B%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%B3%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3Edts%E3%83%8E%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%81%A7%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%8C%E8%A6%8B%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3Eroot%40unknown%3A~%23%20dmesg%20%7C%20grep%20%22csi%22%3CBR%20%2F%3E%20%5B%200.064823%5D%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2032e40000.csi%3A%2Fsoc%400%2Fbus%4030800000%2Fi2c%4030a40000%2Fov5640_mipi%403c%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.065165%5D%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2032e50000.csi%3A%2Fsoc%400%2Fbus%4030800000%2Fi2c%4030a30000%2Fov5640_mipi%403c%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%201.996245%5D%20mxc-mipi-csi2-sam%2032e40000.csi%3A%E9%9B%BB%E6%BA%90%20mipi-phy%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%5B%202.005128%5D%20%3A%20mipi_csis_imx8mp_phy_reset%E3%80%81%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%20%E3%83%91%E3%83%83%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%20%5B%202.017646%5D%20mxc-mipi-csi2-sam%2032e40000.csi%3A%E3%83%AC%E3%83%BC%E3%83%B3%3A%202%E3%80%81hs_settle%3A%2013%E3%80%81clk_settle%3A%202%E3%80%81wclk%3A%201%E3%80%81freq%3A%20500000000%3CBR%20%2F%3E%20%5B%202.027763%5D%20mxc-mipi-csi2-sam%2032e50000.csi%3A%E9%9B%BB%E6%BA%90%20mipi-phy%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%5B%202.036544%5D%20%3A%20mipi_csis_imx8mp_phy_reset%E3%80%81%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%20%E3%83%91%E3%83%83%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%20%5B%202.042435%5D%20mxc-mipi-csi2-sam%2032e50000.csi%3A%E3%83%AC%E3%83%BC%E3%83%B3%3A%202%E3%80%81hs_settle%3A%2013%E3%80%81clk_settle%3A%202%E3%80%81wclk%3A%201%E3%80%81freq%3A%20266000000%3CBR%20%2F%3E%20root%40unknown%3A~%23%20dmesg%20%7C%20grep%20%22ov56%22%3CBR%20%2F%3E%20%5B%200.064823%5D%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2032e40000.csi%3A%2Fsoc%400%2Fbus%4030800000%2Fi2c%4030a40000%2Fov5640_mipi%403c%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.065165%5D%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2032e50000.csi%3A%2Fsoc%400%2Fbus%4030800000%2Fi2c%4030a30000%2Fov5640_mipi%403c%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%202.474968%5D%20ov5640%201-003c%3A%20%E9%9B%BB%E6%BA%90DOVDD%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%202.481826%5D%20ov5640%201-003c%3A%20%E9%9B%BB%E6%BA%90AVDD%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%5B%202.488491%5D%20ov5640%201-003c%3A%20%E9%9B%BB%E6%BA%90DVDD%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%5B%202.495702%5D%20ov5640%201-003c%3A%20ov5640_write_reg%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20reg%3D3008%2C%20val%3D82%3CBR%20%2F%3E%20%5B%202.528236%5D%20ov5640%201-003c%3A%20ov5640_read_reg%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20reg%3D300a%3CBR%20%2F%3E%20%5B%202.533833%5D%20ov5640%201-003c%3A%20ov5640_check_chip_id%3A%20%E3%83%81%E3%83%83%E3%83%97%E8%AD%98%E5%88%A5%E5%AD%90%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%202.548572%5D%20ov5640%202-003c%3A%20%E9%9B%BB%E6%BA%90DOVDD%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%202.555433%5D%20ov5640%202-003c%3A%20%E9%9B%BB%E6%BA%90AVDD%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%5B%202.562095%5D%20ov5640%202-003c%3A%20%E9%9B%BB%E6%BA%90DVDD%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%5B%202.569525%5D%20ov5640%202-003c%3A%20ov5640_write_reg%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20reg%3D3008%E3%80%81val%3D82%3CBR%20%2F%3E%20%5B%202.602054%5D%20ov5640%202-003c%3A%20ov5640_read_reg%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20reg%3D300a%3CBR%20%2F%3E%20%5B%202.607645%5D%20ov5640%202-003c%3A%20ov5640_check_chip_id%3A%20%E3%83%81%E3%83%83%E3%83%97%E8%AD%98%E5%88%A5%E5%AD%90%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CA%20href%3D%22mailto%3Aroot%40unknown%3A~%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%83%AB%E3%83%BC%E3%83%88%40%E4%B8%8D%E6%98%8E%3A~%23%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20i2c%E3%81%A7%E3%82%82%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%AF%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2205746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Camera%20streaming%20issue%20for%20imx8mp%20in%20debian%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2205746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3C%2FP%3E%3CP%3Eimx8mp%20evk%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%90%8C%E3%81%98%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A7%20Linux%20%E3%81%A7%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81Debian%20%E3%81%A7%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%8D%E3%83%8F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2205039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Camera%20streaming%20issue%20for%20imx8mp%20in%20debian%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2205039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3Ei.MX8MP%20%E4%B8%8A%E3%81%AE%20Debian%20%E3%81%A7%20OV5640%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81DOVDD%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%9A%E3%80%81%E3%83%81%E3%83%83%E3%83%97%E8%AD%98%E5%88%A5%E5%AD%90%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E3%81%A8%E3%81%84%E3%81%86%E9%87%8D%E5%A4%A7%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%20%E3%82%BD%E3%83%BC%E3%82%B9%20(DTS)%20%E6%A7%8B%E6%88%90%E3%81%8C%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E8%B5%B7%E5%9B%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%8C%E5%85%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81I2C%E3%83%90%E3%82%B9%E4%B8%8A%E3%81%A7%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%8C%E5%BF%9C%E7%AD%94%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81DTS%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%20%E3%83%8E%E3%83%BC%E3%83%89%E5%86%85%E3%81%AE%E9%81%A9%E5%88%87%E3%81%AA%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%20%E3%83%8E%E3%83%BC%E3%83%89%20(%E4%BE%8B%3A%20%26amp%3Breg_1p8v%E3%80%81%26amp%3Breg_2p8v)%20%E3%81%AB%20OV5640%20%E3%81%AE%E5%BF%85%E8%A6%81%E3%81%AA%E9%9B%BB%E5%9C%A7%E3%83%AC%E3%83%BC%E3%83%AB%20(DOVDD%20%E9%9B%BB%E6%BA%90%E3%80%81AVDD%20%E9%9B%BB%E6%BA%90%E3%80%81DVDD%20%E9%9B%BB%E6%BA%90)%20%E3%82%92%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%A6%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%20I2C%20%E9%80%9A%E4%BF%A1%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%8C%E9%9B%BB%E5%8A%9B%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Camera%20streaming%20issue%20for%20imx8mp%20in%20debian%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%20EVK%2FFRDM%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%20Debian%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%AF%E3%80%81%E3%81%99%E3%81%A7%E3%81%AB%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%20OV5640%20%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BSO%E3%80%81EVK%2FFRDM%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%A2%E3%83%AB%E3%83%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Camera%20streaming%20issue%20for%20imx8mp%20in%20debian%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AFimx8mp%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%97%E3%83%AA%E3%83%B3%E3%83%88%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%A7%81%E3%81%AFOV5640%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92IMX8MP%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E7%94%A8%E3%81%AE%E3%83%81%E3%83%BC%E3%82%BA%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20%5B%20172.691637%5D%20mxc-mipi-csi2.0%3A%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%20csi-sam%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20-1068476902%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%9F%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AF%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%9A%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Edebian%40%E4%B8%8D%E6%98%8E%3A~%24%20gst-launch-1.0v4l2src%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3D%2Fdev%2Fvideo4%20!%E3%83%93%E3%83%87%E3%82%AA%E5%A4%89%E6%8F%9B%EF%BC%81ximagesink%3CBR%20%2F%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E6%89%BF%E8%AA%8D%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E6%89%BF%E8%AA%8D%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E8%A6%81%E7%B4%A0%20%2FGstPipeline%3Apipeline0%2FGstXImageSink%3Aximagesink0%20%E3%81%8B%E3%82%89%3A%20X%20%E5%87%BA%E5%8A%9B%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%83%85%E5%A0%B1%3A%3CBR%20%2F%3E%20..%2Fsys%2Fximage%2Fximagesink.c(1150)%3A%20gst_x_image_sink_xcontext_get()%3A%20%2FGstPipeline%3Apipeline0%2FGstXImageSink%3Aximagesink0%3A%3CBR%20%2F%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E9%96%8B%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E3%83%97%E3%83%AA%E3%83%AD%E3%83%BC%E3%83%AB%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%20PAUSED%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%20NULL%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E8%A7%A3%E6%94%BE%E3%81%97%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%A6%E3%82%A7%E3%82%B9%E3%83%88%E3%83%B3%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E6%9C%9B%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3ECheese%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A8%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Camera%20streaming%20issue%20for%20imx8mp%20in%20debian%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AFLinux%206.6.52%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%97%E3%81%9FDebian%2012%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E
