CTS result has errors. Android.os.cts.Seccomp....
satoshiazami
Hi ALL,
I am debugging Android 6.0.1 on original board (SoC = i.MX6 DualLitte). OS is work fine now.
Then, I tested OS using CTS ( 6.0 r28 ). and I have fail status on this result.
I cannot fix this issue now. please advise!
* Kernel has configuration below.
  CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
  CONFIG_SECCOMP_FILTER=y
  CONFIG_SECCOMP=y
* CTS result snippet ..-----------------------------------------------------------------------------
            <Test name="testViolateIsolatedServicePolicy" result="fail" starttime="豌エ 7 04 18:27:41 JST 2018" endtime="豌エ 7 04 18:27:41 JST 2018">
              <FailedScene message="junit.framework.AssertionFailedError&#13;&#10;at junit.framework.Assert.fail(Assert.java:48)&#13;">
                <StackTrace>junit.framework.AssertionFailedError
at junit.framework.Assert.assertTrue(Assert.java:20)
at junit.framework.Assert.assertTrue(Assert.java:27)
at android.os.cts.SeccompTest.testViolateIsolatedServicePolicy(SeccompTest.java:239)
at java.lang.reflect.Method.invoke(Native Method)
at junit.framework.TestCase.runTest(TestCase.java:168)
at junit.framework.TestCase.runBare(TestCase.java:134)
at junit.framework.TestResult$1.protect(TestResult.java:115)
at android.support.test.internal.runner.junit3.AndroidTestResult.runProtected(AndroidTestResult.java:77)
at junit.framework.TestResult.run(TestResult.java:118)
at android.support.test.internal.runner.junit3.AndroidTestResult.run(AndroidTestResult.java:55)
at junit.framework.TestCase.run(TestCase.java:124)
at android.support.test.internal.runner.junit3.NonLeakyTestSuite$NonLeakyTest.run(NonLeakyTestSuite.java:63)
at android.support.test.internal.runner.junit3.AndroidTestSuite$1.run(AndroidTestSuite.java:98)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:423)
at java.util.concurrent.FutureTask.run(FutureTask.java:237)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1113)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:588)
at java.lang.Thread.run(Thread.java:818)
</StackTrace>
              </FailedScene>
            </Test>
            <Test name="testAndroidTestCaseSetupProperly" result="pass" starttime="豌エ 7 04 18:27:41 JST 2018" endtime="豌エ 7 04 18:27:41 JST 2018" />
          </TestCase>
          <TestCase name="SecurityFeaturesTest" priority="">
            <Test name="testNoNewPrivs" result="fail" starttime="豌エ 7 04 18:27:41 JST 2018" endtime="豌エ 7 04 18:27:41 JST 2018">
at android.os.cts.SecurityFeaturesTest.testNoNewPrivs(SecurityFeaturesTest.java:31)
</StackTrace>
              </FailedScene>
            </Test>
            <Test name="testPrCapbsetEmpty" result="fail" starttime="豌エ 7 04 18:27:41 JST 2018" endtime="豌エ 7 04 18:27:41 JST 2018">
              <FailedScene message="junit.framework.AssertionFailedError: capability 0 is still in the bounding set expected:&lt;0&gt; but was:&lt;1&gt;&#13;&#10;at junit.framework.Assert.fail(Assert.java:50)&#13;">
                <StackTrace>junit.framework.AssertionFailedError: capability 0 is still in the bounding set expected:&lt;0&gt; but was:&lt;1&gt;
at junit.framework.Assert.failNotEquals(Assert.java:287)
at junit.framework.Assert.assertEquals(Assert.java:67)
at junit.framework.Assert.assertEquals(Assert.java:199)
at android.os.cts.SecurityFeaturesTest.testPrCapbsetEmpty(SecurityFeaturesTest.java:50)
</StackTrace>
              </FailedScene>
            </Test>
Labels (2)
satoshiazami
Self reply.
My using code base has issue.
my previous engineer was commented out below.
I want to say I'm sorry for community.
diff --git a/IMX6Q_6DL/frameworks/base/cmds/app_process/app_main.cpp b/IMX6Q_6DL/frameworks/base/cmds/app_process/app_main.cpp
index c5bee57..035c9e2 100644
--- a/IMX6Q_6DL/frameworks/base/cmds/app_process/app_main.cpp
+++ b/IMX6Q_6DL/frameworks/base/cmds/app_process/app_main.cpp
@@ -12,6 +12,7 @@
 #include <sys/prctl.h>
 #include <sys/stat.h>
 #include <unistd.h>
+#include <sys/prctl.h>
 #include <binder/IPCThreadState.h>
 #include <binder/ProcessState.h>
@@ -185,7 +186,6 @@ static const char ZYGOTE_NICE_NAME[] = "zygote";
 int main(int argc, char* const argv[])
-    /* comment out to give root privileges for APP
     if (prctl(PR_SET_NO_NEW_PRIVS, 1, 0, 0, 0) < 0) {
         // Older kernels don't understand PR_SET_NO_NEW_PRIVS and return
         // EINVAL. Don't die on such kernels.
@@ -194,7 +194,6 @@ int main(int argc, char* const argv[])
             return 12;
     AppRuntime runtime(argv[0], computeArgBlockSize(argc, argv));
     // Process command line arguments
Thank you for your time if you are checking this issues.
Azami
satoshiazami
so, I want to close this board.
How can I do that ? please help.  m(_ _)m
