CDC_NCM gadget driver
2,241件の閲覧回数
amit251291
Dear team,
We are working on imx8qm-mek running on Android 9. We are working on CarPlay functionality.
For the same reason,
i) How do we enable CDC_NCM gadget driver and its functionality ?
ii) How do we test it ?
Any guidance will be much appreciated.
ラベル(2)
タグ(1)
2 返答(返信)
2,116件の閲覧回数
jamesbone
You need to add the following modules if you want to support the following modules
CONFIG_USB_USBNET, CONFIG_USB_NET_CDC_NCM, CONFIG_USB_GADGET
USB Gadget Drivers, CONFIG_USB_ETH, CONFIG_USB_G_NCM.
2,116件の閲覧回数
amit251291
Thank you jamesbone for your reply.
I will do above changes.
How do i test this feature after doing above changes ?
