CAN_CLOCK_CHECK_NO_AFFECTS assert FAILED On MIMXRT1064CVL5B
max_yang1
MIMXRT1064CVL5B MCU
I had some CAN code worked on MIMXRT1064L6A EVAL. On my design board we have MIMXRT1064CVL5B MCU.
The clock configuration has not been changed much except code frequency from 600M to 528M i the Config Tool *.MEX file.
Now I have this assert failure assert(CAN_CLOCK_CHECK_NO_AFFECTS) in fsl_flexcan.c I have no idea where should I check for it.
Thanks in advance.
Max
Kan_Li
Hi @max_yang1 ,
You may find the following definition in fsl_clock.h, please check if your CCM configuration meets either of the cases.
Kan
