Burning eFuses on i.MX8M Mini
1,385 次查看
akoch
I'm trying to implement Secure Boot on an i.MX8M Mini board using HABv4. An important step for this is burning the SRK hashes to eFuses.
I have tried programming the fuses via U-Boot and the operation seems successful at first, but a read shows that the fuse value has actually not changed:
u-boot=> fuse prog 7 3 0xD5DC4A43
Programming bank 7 word 0x00000003 to 0xd5dc4a43...
Warning: Programming fuses is an irreversible operation!
         This may brick your system.
         Use this command only if you are sure of what you are doing!
Really perform this fuse programming? <y/N> y
u-boot=> fuse read 7 3
Reading bank 7:
Word 0x00000003: 00000000
This is using U-Boot 2024.01 (mainline, not u-boot-imx). I have read a lot of contradicting articles, some of them claiming that mainline U-Boot does not support eFuses on i.MX8 and some that it should be implemented.
Can someone give me a definitive statement on that?
If U-Boot is not an option, can I burn the fuses from Linux? I've got Kernel 6.18.19 LTS (mainline, not linux-imx) running on the board with a userland generated using PTXdist.
I have also tried using `uuu` to run a U-Boot-imx build but it seems the board does not offer the USB port required for this.
Thanks in advance!
标记 (3)
1,358 次查看
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
Fist recommendation is use NXP BSP (U-boot and Kernel are the key components that are continuously improved based on our devices).
There is a guide for enabling secure boot, therefore how to fuse SRK values in the fuses with u-boot-imx and fuse tool, you can refer to it and use u-boot-imx.
https://github.com/nxp-imx/uboot-imx/blob/lf_v2025.04/doc/imx/habv4/guides/mx8m_secure_boot.txt
Otherwise, there is a way to burn them in Linux, you can check full u-boot/linux fuse reference in this application note.
https://www.nxp.com/docs/en/application-note/AN14954.pdf
Finally, I have tried pwrite and pread functions in i.MX 93 with LF-6.12.49, there is a reference with i.MX 8M Plus that is worth trying,
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/how-to-fuse-mac-address-via-uboot-or-ker...
1,113 次查看
akoch
I have tried switching to Uboot-imx as you have suggested.
However I cannot seem to get the i.MX8MM EVK build to work:
In doc/board/nxp/imx8mm_evk.rst it is stated to follow just the usual steps to build U-Boot:
$ export CROSS_COMPILE=aarch64-poky-linux-
$ make imx8mm_evk_fspi_defconfig
$ make
The build is successful but there is no 'flash.bin' created.
Calling that make target manually fails with an unmet dependency to the FIT image:
$ make flash.bin
  UPD     include/generated/timestamp_autogenerated.h
  CC      spl/common/spl/spl.o
  AR      spl/common/spl/built-in.o
  KSL     spl/keep-syms-lto.c
  KSLCC   spl/keep-syms-lto.o
  LTO     spl/u-boot-spl
  OBJCOPY spl/u-boot-spl-nodtb.bin
  COPY    spl/u-boot-spl.bin
  SYM     spl/u-boot-spl.sym
make: *** No rule to make target 'u-boot.itb', needed by 'flash.bin'.  Stop.
How am I supposed to build U-boot-imx for the i.MX8MM EVK? This is uboot-imx lf_v2025.04 (99518e6) by the way.
1,345 次查看
akoch
Thank you for your answer!
I understand your recommendation but switching to linux-imx is just not an option for us as we need up-to-date Kernel versions and the one from the NXP BSP is just too old.
I have seen this document but it contains the exact same instructions that I have already tried (fuse prog ...).
Does this mean that there is code in u-boot-imx that is not upstreamed in mainline u-boot and that is required for fuse prog to work?
Thank you, this looks promising, I will look into this next.
This looks to me like the same mechanism as above but implemented in C instead of using dd to write the payload. Thanks anyway, I will check it out as well.
Alex
%3CLINGO-SUB%20id%3D%22lingo-sub-2339316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20i.MX8M%20Mini%20%E4%B8%8A%E7%83%A7%E6%AF%81%20eFuse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20HabV4%20%E5%9C%A8%20i.MX8M%20%E8%BF%B7%E4%BD%A0%E6%9D%BF%E4%B8%8A%E5%AE%9E%E7%8E%B0%E5%AE%89%E5%85%A8%E5%90%AF%E5%8A%A8%E3%80%82%E5%85%B6%E4%B8%AD%E4%B8%80%E4%B8%AA%E9%87%8D%E8%A6%81%E6%AD%A5%E9%AA%A4%E5%B0%B1%E6%98%AF%E5%B0%86%20SRK%20%E5%93%88%E5%B8%8C%E5%80%BC%E7%83%A7%E5%BD%95%E5%88%B0%20eFuses%20%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%AF%95%E8%BF%87%E9%80%9A%E8%BF%87U-Boot%E5%AF%B9%E7%86%94%E4%B8%9D%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%EF%BC%8C%E8%B5%B7%E5%88%9D%E6%93%8D%E4%BD%9C%E4%BC%BC%E4%B9%8E%E5%BE%88%E6%88%90%E5%8A%9F%EF%BC%8C%E4%BD%86%E6%98%AF%E8%AF%BB%E5%8F%96%E5%90%8E%E6%98%BE%E7%A4%BA%E7%86%94%E4%B8%9D%E7%9A%84%E5%80%BC%E5%AE%9E%E9%99%85%E4%B8%8A%E6%B2%A1%E6%9C%89%E6%94%B9%E5%8F%98%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Eu-boot%3D%26gt%3B%20fuse%20prog%207%203%200xD5DC4A43%0AProgramming%20bank%207%20word%200x00000003%20to%200xd5dc4a43...%0AWarning%3A%20Programming%20fuses%20is%20an%20irreversible%20operation!%0A%20%20%20%20%20%20%20%20%20This%20may%20brick%20your%20system.%0A%20%20%20%20%20%20%20%20%20Use%20this%20command%20only%20if%20you%20are%20sure%20of%20what%20you%20are%20doing!%0A%0AReally%20perform%20this%20fuse%20programming%3F%20%3CY%3E%20y%3C%2FY%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Eu-boot%3D%26gt%3B%20fuse%20read%207%203%0AReading%20bank%207%3A%0A%0AWord%200x00000003%3A%2000000000%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E6%98%AF%E4%BD%BF%E7%94%A8%20%3CSTRONG%3EU-Boot%202024.01%3C%2FSTRONG%3E%EF%BC%88%E4%B8%BB%E7%BA%BF%EF%BC%8C%E4%B8%8D%E6%98%AF%20u-boot-imx%EF%BC%89%E3%80%82%E6%88%91%E8%AF%BB%E8%BF%87%E5%BE%88%E5%A4%9A%E7%9B%B8%E4%BA%92%E7%9F%9B%E7%9B%BE%E7%9A%84%E6%96%87%E7%AB%A0%EF%BC%8C%E5%85%B6%E4%B8%AD%E4%B8%80%E4%BA%9B%E5%A3%B0%E7%A7%B0%E4%B8%BB%E7%BA%BF%20U-Boot%20%E4%B8%8D%E6%94%AF%E6%8C%81%20i.MX8%20%E4%B8%8A%E7%9A%84%20eFuse%EF%BC%8C%E6%9C%89%E4%BA%9B%E5%88%99%E8%AE%A4%E4%B8%BA%E5%BA%94%E8%AF%A5%E5%AE%9E%E7%8E%B0%E5%AE%83%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%81%E8%83%BD%E7%BB%99%E6%88%91%E4%B8%80%E4%B8%AA%E6%98%8E%E7%A1%AE%E7%9A%84%E8%AF%B4%E6%B3%95%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%97%A0%E6%B3%95%E9%80%89%E6%8B%A9%20U-Boot%EF%BC%8C%E6%88%91%E8%83%BD%E7%83%A7%E6%8E%89%20Linux%20%E7%9A%84%E7%86%94%E4%B8%9D%E5%90%97%EF%BC%9F%E6%88%91%E5%B7%B2%E7%BB%8F%E5%9C%A8%E4%B8%BB%E6%9D%BF%E4%B8%8A%E8%BF%90%E8%A1%8C%E4%BA%86%E5%86%85%E6%A0%B8%206.18.19%20LTS%EF%BC%88%E4%B8%BB%E7%BA%BF%EF%BC%8C%E4%B8%8D%E6%98%AF%20linux-imx%EF%BC%89%EF%BC%8C%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4%E4%BD%BF%E7%94%A8%20ptxDist%20%E7%94%9F%E6%88%90%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%9F%E5%B0%9D%E8%AF%95%E8%BF%87%E4%BD%BF%E7%94%A8%20%60uuu%60%20%E6%9D%A5%E8%BF%90%E8%A1%8C%20U-boot-imx%20%E7%89%88%E6%9C%AC%EF%BC%8C%E4%BD%86%E7%9C%8B%E6%9D%A5%E4%B8%BB%E6%9D%BF%E6%B2%A1%E6%9C%89%E6%8F%90%E4%BE%9B%E8%BF%99%E6%96%B9%E9%9D%A2%E6%89%80%E9%9C%80%E7%9A%84%20USB%20%E7%AB%AF%E5%8F%A3%E3%80%82%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2339316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2339844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Burning%20eFuses%20on%20i.MX8M%20Mini%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E7%AD%94%EF%BC%81%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%BB%BA%E8%AE%AE%E6%98%AF%E4%BD%BF%E7%94%A8%E6%81%A9%E6%99%BA%E6%B5%A6%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%EF%BC%88U-%E5%90%AF%E5%8A%A8%E5%92%8C%E5%86%85%E6%A0%B8%E6%98%AF%E6%A0%B9%E6%8D%AE%E6%88%91%E4%BB%AC%E7%9A%84%E8%AE%BE%E5%A4%87%E4%B8%8D%E6%96%AD%E6%94%B9%E8%BF%9B%E7%9A%84%E5%85%B3%E9%94%AE%E5%85%83%E5%99%A8%E4%BB%B6%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%88%91%E7%90%86%E8%A7%A3%E4%BD%A0%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E4%BD%86%E6%98%AF%E5%88%87%E6%8D%A2%E5%88%B0linux-imx%E5%AF%B9%E6%88%91%E4%BB%AC%E6%9D%A5%E8%AF%B4%E4%B8%8D%E6%98%AF%E4%B8%80%E4%B8%AA%E9%80%89%E6%8B%A9%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E6%9C%80%E6%96%B0%E7%9A%84%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%EF%BC%8C%E8%80%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E7%9A%84%E7%89%88%E6%9C%AC%E5%A4%AA%E6%97%A7%E4%BA%86%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBLOCKQUOTE%3E%3CP%3E%E6%9C%89%E4%B8%80%E4%BB%BD%E5%90%AF%E7%94%A8%E5%AE%89%E5%85%A8%E5%90%AF%E5%8A%A8%E7%9A%84%E6%8C%87%E5%8D%97%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20u-boot-imx%20%E5%92%8C%20%E7%86%94%E4%B8%9D%E5%B7%A5%E5%85%B7%E8%9E%8D%E5%90%88%E7%86%94%E4%B8%9D%E4%B8%AD%E7%9A%84%20SRK%20%E5%80%BC%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E5%B9%B6%E4%BD%BF%E7%94%A8%20u-boot-imx%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fuboot-imx%2Fblob%2Flf_v2025.04%2Fdoc%2Fimx%2Fhabv4%2Fguides%2Fmx8m_secure_boot.txt%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fuboot-imx%2Fblob%2Flf_v2025.04%2Fdoc%2Fimx%2Fhabv4%2Fguides%2Fmx8m_secure_boot.tx%3C%2FA%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%88%91%E7%9C%8B%E8%BF%87%E8%BF%99%E7%AF%87%E6%96%87%E6%A1%A3%EF%BC%8C%E4%BD%86%E5%AE%83%E5%8C%85%E5%90%AB%E7%9A%84%E8%AF%B4%E6%98%8E%E4%B8%8E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%B0%9D%E8%AF%95%E8%BF%87%E7%9A%84%E5%AE%8C%E5%85%A8%E7%9B%B8%E5%90%8C%EF%BC%88%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E7%86%94%E4%B8%9D%20prog...%3C%2FFONT%3E%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E8%BF%99%E6%98%AF%E5%90%A6%E6%84%8F%E5%91%B3%E7%9D%80%20u-boot-imx%20%E4%B8%AD%E6%9C%89%E4%B8%80%E4%BA%9B%E4%BB%A3%E7%A0%81%E4%B8%8D%E6%98%AF%E5%9C%A8%E4%B8%BB%E7%BA%BF%20u-boot%20%E4%B8%AD%E5%90%91%E4%B8%8A%E6%B5%81%E5%BC%8F%E4%BC%A0%E8%BE%93%E7%9A%84%EF%BC%8C%E8%80%8C%E8%BF%99%E4%BA%9B%E4%BB%A3%E7%A0%81%E6%98%AF%E7%86%94%E4%B8%9D%E7%A8%8B%E5%BA%8F%E8%BF%90%E8%A1%8C%E6%89%80%E5%BF%85%E9%9C%80%E7%9A%84%EF%BC%9F%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBLOCKQUOTE%3E%3CP%3E%E5%90%A6%E5%88%99%EF%BC%8C%E6%9C%89%E5%8A%9E%E6%B3%95%E5%9C%A8%20Linux%20%E4%B8%AD%E7%83%A7%E5%BD%95%E5%AE%83%E4%BB%AC%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%9C%AC%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%E4%B8%AD%E6%9F%A5%E7%9C%8B%E5%AE%8C%E6%95%B4%E7%9A%84%20u-boot%2Flinux%20%E7%86%94%E4%B8%9D%E5%8F%82%E8%80%83%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14954.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14954.pdf%3C%2FA%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%E8%BF%99%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%BE%88%E6%9C%89%E5%B8%8C%E6%9C%9B%EF%BC%8C%E6%88%91%E6%8E%A5%E4%B8%8B%E6%9D%A5%E4%BC%9A%E7%A0%94%E7%A9%B6%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBLOCKQUOTE%3E%3CP%3E%E6%9C%80%E5%90%8E%EF%BC%8C%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E5%B8%A6%E6%9C%89%20LF-6.12.49%20%E7%9A%84%20i.MX%2093%20%E4%B8%AD%E7%9A%84%20pwrite%20%E5%92%8C%20pread%20%E5%87%BD%E6%95%B0%EF%BC%8C%E6%9C%89%E4%B8%80%E4%B8%AA%20i.MX%208M%20Plus%20%E7%9A%84%E5%8F%82%E8%80%83%E5%80%BC%E5%BE%97%E4%B8%80%E8%AF%95%EF%BC%8C%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fhow-to-fuse-mac-address-via-uboot-or-kernel-on-imx8mp%2Fta-p%2F2123532%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fhow-to-fuse-mac-address-via-uboot-or-ker...%3C%2FA%3E%20%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E5%9C%A8%E6%88%91%E7%9C%8B%E6%9D%A5%EF%BC%8C%E8%BF%99%E4%B8%8E%E4%B8%8A%E8%BF%B0%E6%9C%BA%E5%88%B6%E7%9B%B8%E5%90%8C%EF%BC%8C%E5%8F%AA%E6%98%AF%E7%94%A8%20C%20%E8%AF%AD%E8%A8%80%E5%AE%9E%E7%8E%B0%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E4%BD%BF%E7%94%A8%20dd%20%E6%9D%A5%E5%86%99%E5%85%A5%E6%9C%89%E6%95%88%E8%BD%BD%E8%8D%B7%E3%80%82%E6%80%BB%E4%B9%8B%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%8C%E6%88%91%E4%B9%9F%E4%BC%9A%E5%8E%BB%E7%9C%8B%E7%9C%8B%E7%9A%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E4%BA%9A%E5%8E%86%E5%85%8B%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2339623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Burning%20eFuses%20on%20i.MX8M%20Mini%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%AF%B9%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%E4%BA%A7%E5%93%81%E7%9A%84%E5%85%B3%E6%B3%A8%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%BB%BA%E8%AE%AE%E6%98%AF%E4%BD%BF%E7%94%A8%E6%81%A9%E6%99%BA%E6%B5%A6%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%EF%BC%88U-%E5%90%AF%E5%8A%A8%E5%92%8C%E5%86%85%E6%A0%B8%E6%98%AF%E6%A0%B9%E6%8D%AE%E6%88%91%E4%BB%AC%E7%9A%84%E8%AE%BE%E5%A4%87%E4%B8%8D%E6%96%AD%E6%94%B9%E8%BF%9B%E7%9A%84%E5%85%B3%E9%94%AE%E5%85%83%E5%99%A8%E4%BB%B6%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%9C%89%E4%B8%80%E4%BB%BD%E5%90%AF%E7%94%A8%E5%AE%89%E5%85%A8%E5%90%AF%E5%8A%A8%E7%9A%84%E6%8C%87%E5%8D%97%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20u-boot-imx%20%E5%92%8C%20%E7%86%94%E4%B8%9D%E5%B7%A5%E5%85%B7%E8%9E%8D%E5%90%88%E7%86%94%E4%B8%9D%E4%B8%AD%E7%9A%84%20SRK%20%E5%80%BC%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E5%B9%B6%E4%BD%BF%E7%94%A8%20u-boot-imx%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fuboot-imx%2Fblob%2Flf_v2025.04%2Fdoc%2Fimx%2Fhabv4%2Fguides%2Fmx8m_secure_boot.txt%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fuboot-imx%2Fblob%2Flf_v2025.04%2Fdoc%2Fimx%2Fhabv4%2Fguides%2Fmx8m_secure_boot.txt%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%90%A6%E5%88%99%EF%BC%8C%E6%9C%89%E5%8A%9E%E6%B3%95%E5%9C%A8%20Linux%20%E4%B8%AD%E7%83%A7%E5%BD%95%E5%AE%83%E4%BB%AC%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%9C%AC%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%E4%B8%AD%E6%9F%A5%E7%9C%8B%E5%AE%8C%E6%95%B4%E7%9A%84%20u-boot%2Flinux%20%E7%86%94%E4%B8%9D%E5%8F%82%E8%80%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14954.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14954.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E5%90%8E%EF%BC%8C%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E5%B8%A6%E6%9C%89%20LF-6.12.49%20%E7%9A%84%20i.MX%2093%20%E4%B8%AD%E7%9A%84%20pwrite%20%E5%92%8C%20pread%20%E5%87%BD%E6%95%B0%EF%BC%8C%E6%9C%89%E4%B8%80%E4%B8%AA%20i.MX%208M%20Plus%20%E7%9A%84%E5%8F%82%E8%80%83%E5%80%BC%E5%BE%97%E4%B8%80%E8%AF%95%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fhow-to-fuse-mac-address-via-uboot-or-kernel-on-imx8mp%2Fta-p%2F2123532%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fhow-to-fuse-mac-address-via-uboot-or-kernel-on-imx8mp%2Fta-p%2F2123532%3C%2FA%3E%20%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346512%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Burning%20eFuses%20on%20i.MX8M%20Mini%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346512%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E8%AF%95%E7%9D%80%E6%8C%89%E7%85%A7%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%E6%94%B9%E7%94%A8%20Uboot-imx%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E6%88%91%E4%BC%BC%E4%B9%8E%E6%97%A0%E6%B3%95%E8%AE%A9%20i.MX8MM%20EVK%20%E7%89%88%E6%9C%AC%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%9C%A8%20%3CEM%3Edoc%2F%E6%9D%BF%2Fnxp%2Fimx8mm_evk.%3C%2FEM%3E%20rst%20%E4%B8%AD%EF%BC%8C%E6%8D%AE%E8%AF%B4%E5%8F%AA%E8%83%BD%E6%8C%89%E7%85%A7%E9%80%9A%E5%B8%B8%E7%9A%84%E6%AD%A5%E9%AA%A4%E6%9E%84%E5%BB%BA%20U-Boot%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20export%20CROSS_COMPILE%3Daarch64-poky-linux-%0A%24%20make%20imx8mm_evk_fspi_defconfig%0A%24%20make%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E7%BC%96%E8%AF%91%E6%88%90%E5%8A%9F%E4%BD%86%E6%B2%A1%E6%9C%89%20%E2%80%9Cflash.bin%E2%80%9D%E5%88%9B%E5%BB%BA%E3%80%82%3C%2FP%3E%3CP%3E%E6%89%8B%E5%8A%A8%E8%B0%83%E7%94%A8%20make%20target%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AF%B9%20FIT%20%E6%98%A0%E5%83%8F%E7%9A%84%E4%BE%9D%E8%B5%96%E6%80%A7%E6%9C%AA%E6%BB%A1%E8%B6%B3%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20make%20flash.bin%0A%20%20UPD%20%20%20%20%20include%2Fgenerated%2Ftimestamp_autogenerated.h%0A%20%20CC%20%20%20%20%20%20spl%2Fcommon%2Fspl%2Fspl.o%0A%20%20AR%20%20%20%20%20%20spl%2Fcommon%2Fspl%2Fbuilt-in.o%0A%20%20KSL%20%20%20%20%20spl%2Fkeep-syms-lto.c%0A%20%20KSLCC%20%20%20spl%2Fkeep-syms-lto.o%0A%20%20LTO%20%20%20%20%20spl%2Fu-boot-spl%0A%20%20OBJCOPY%20spl%2Fu-boot-spl-nodtb.bin%0A%20%20COPY%20%20%20%20spl%2Fu-boot-spl.bin%0A%20%20SYM%20%20%20%20%20spl%2Fu-boot-spl.sym%0Amake%3A%20***%20No%20rule%20to%20make%20target%20'u-boot.itb'%2C%20needed%20by%20'flash.bin'.%20%20Stop.%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E5%BA%94%E8%AF%A5%E5%A6%82%E4%BD%95%E4%B8%BA%20i.mx8mm%20EVK%20%E6%9E%84%E5%BB%BA%20u-boot-imx%EF%BC%9F%E9%A1%BA%E4%BE%BF%E8%AF%B4%E4%B8%80%E4%B8%8B%EF%BC%8C%E8%BF%99%E6%98%AF%20uboot-imx%20lf_v2025.04%20(99518e6)%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
